show manufacturer logo in product details
WebIm
WebIm posted this 01 April 2021
I want to show the product manufacturer logo with link to manufacturer products in my product details in virtuemart can you help me ?
15 Comments
Support Team posted this 01 April 2021
Themler supports only showing Manufacturer name on product details page. You can try adding this code to Product Details page via Insert -> CMS Code > Edit CMS Code:
<a href="<?php echo JRoute::_('index.php?option=com_virtuemart&view=category&virtuemart_category_id=0&virtuemart_manufacturer_id=' . $this->product->virtuemart_manufacturer_id[0], false); ?>"><?php echo $manufacturer->images[0]->displayMediaThumb(false,false);?></a>
Hello, Themler supports only showing Manufacturer name on product details page. You can try adding this code to Product Details page via Insert -> CMS Code > Edit CMS Code: <a href="<?php echo JRoute::_('index.php?option=com_virtuemart&view=category&virtuemart_category_id=0&virtuemart_manufacturer_id=' . $this->product->virtuemart_manufacturer_id[0], false); ?>"><?php echo $manufacturer->images[0]->displayMediaThumb(false,false);?></a> Gina Themler Support
WebIm
WebIm posted this 02 April 2021
Thank you for your answer.
I used the CMS code control and I entered the code
however i get this error.
0 - Call to a member function displayMediaThumb() on null
How can I solve?
thank you very much
tks.
daniela
Hello Thank you for your answer. I used the CMS code control and I entered the code however i get this error. **0 - Call to a member function displayMediaThumb() on null** How can I solve? thank you very much tks. daniela
Support Team posted this 04 April 2021
Could you please try editing VM file directly as suggested here https://www.media-division.com/virtuemart-show-manufacturer-logo-in-product-details/
GIna
Themler support
Could you please try editing VM file directly as suggested here https://www.media-division.com/virtuemart-show-manufacturer-logo-in-product-details/ GIna Themler support
WebIm
WebIm posted this 05 April 2021
I tried the procedure described in the link that he pointed out to me; however it refers to version 1.1.3 and 1.1.4. and it doesn't work.
Do you have any other suggestions?
tks
daniela
Thank you for your answer. I tried the procedure described in the link that he pointed out to me; however it refers to version 1.1.3 and 1.1.4. and it doesn't work. Do you have any other suggestions? tks daniela
Support Team posted this 05 April 2021
Add this code to CMS Code control:
<?php if(!empty($product->virtuemart_manufacturer_id))
    $model = VmModel::getModel('manufacturer');
    foreach($product->virtuemart_manufacturer_id as $manufacturer_id)
        $model->setId($manufacturer_id);
        $manufacturer = $model->getManufacturer();
        $model->addImages($manufacturer);
        $thumbnail_image = $manufacturer->images[0]->displayMediaThumb('class="mfg-thumbnail-image"', false);
It works on my end:
But as you can see I have also added Manufacturer's Name control. You can try without it first.
Add this code to CMS Code control: <?php if(!empty($product->virtuemart_manufacturer_id)) { $model = VmModel::getModel('manufacturer'); foreach($product->virtuemart_manufacturer_id as $manufacturer_id) { $model->setId($manufacturer_id); $manufacturer = $model->getManufacturer(); $model->addImages($manufacturer); $thumbnail_image = $manufacturer->images[0]->displayMediaThumb('class="mfg-thumbnail-image"', false); } } ?> <a href="<?php echo JRoute::_('index.php?option=com_virtuemart&view=category&virtuemart_category_id=0&virtuemart_manufacturer_id=' . $this->product->virtuemart_manufacturer_id[0], false); ?>"><?php echo $manufacturer->images[0]->displayMediaThumb(false,false);?></a> It works on my end: !Screenshot-1.png! But as you can see I have also added Manufacturer's Name control. You can try without it first. Gina
WebIm
Thanks.
The code works. However it is necessary to add the instruction if the producer is not inserted as the error "0 - Call to a member function displayMediaThumb() on null" it is generated if the manufacturer is not indicated for the product.
many thanks for your support
Daniela
Thanks. **The code works.** However it is necessary to add the instruction if the producer is not inserted as the error "**0 - Call to a member function displayMediaThumb() on null**" it is generated if the manufacturer is not indicated for the product. many thanks for your support Daniela
Sorry, I haven't tested this code without a manufacturer.
Sorry, I haven't tested this code without a manufacturer. Gina Themler Support
WebIm
WebIm posted this 06 April 2021
Hi Gina. Thanks for your patience and support.
Did you take a look at the code?
Daniela
Hi Gina. Thanks for your patience and support. Did you take a look at the code? Regards Daniela
Support Team posted this 06 April 2021
I had to assign this to the developers to adjust the code and avoid the error for products without manufacturers. Still waiting for the reply.
If this error is a PHP Warning or Notice (not ERROR), you can disable php warning on Joomla frontend, at least for now.
I had to assign this to the developers to adjust the code and avoid the error for products without manufacturers. Still waiting for the reply. If this error is a PHP Warning or Notice (not ERROR), you can disable php warning on Joomla frontend, at least for now. Gina Themler Support
WebIm
WebIm posted this 20 April 2021
Hi Gina,
how are you?
Do you have any updates on my request?
Thank you very much
daniela
Hi Gina, how are you? Do you have any updates on my request? Thank you very much daniela
WebIm
WebIm posted this 07 July 2021
Hi Gina,
how are you?
Thank you very much
daniela
Support Team posted this 09 July 2021
Hello Daniela,
I am sorry to inform that this request wasn't addressed yet. Themler is not getting much attentions at the moment, mostly key features are being fixed.
Hello Daniela, I am sorry to inform that this request wasn't addressed yet. Themler is not getting much attentions at the moment, mostly key features are being fixed. Gina Themler Support
henryashford663
henryashford663 posted this 28 September 2025
SweatyNames can make betting games more thrilling by giving players bold and competitive identities that stand out and bring extra intensity to the experience.
[SweatyNames][1] can make betting games more thrilling by giving players bold and competitive identities that stand out and bring extra intensity to the experience. [1]: https://sweatynames.com/
williumjames786
williumjames786 posted this 05 November 2025
SweatyNames definitely adds excitement to online gaming, and 777SX makes the betting game even more thrilling with secure features and fun opportunities.
SweatyNames definitely adds excitement to online gaming, and [777SX][1] makes the betting game even more thrilling with secure features and fun opportunities. [1]: https://777sx.pk/
williumjames786
williumjames786 posted this 01 December 2025
If you enjoy exploring different betting game platforms, Apkstair is also a good place to find quick and reliable options. It helps you access updated games easily and keeps the overall experience smooth for mobile users.
If you enjoy exploring different betting game platforms, [Apkstair][1] is also a good place to find quick and reliable options. It helps you access updated games easily and keeps the overall experience smooth for mobile users. [1]: https://apkstair.com.pk
