VirtueMart Captcha bug generated by Themler overwrites file.
coleoptera
coleoptera posted this 4 weeks ago
I identified a Themler file that generates a bug in VirtueMart.
This is a file generated by Themler, which formally correctly overwrites the original VirtueMart file in the "templates" directory.
However, as of VM version 3.2.3, this file does not work properly. And not only for Captcha, but also for other functions.
Watch the video in the attachment.
Please correct this in the THEMLER program.
I identified a Themler file that generates a bug in VirtueMart. This is a file generated by Themler, which formally correctly overwrites the original VirtueMart file in the "templates" directory. However, as of VM version 3.2.3, this file does not work properly. And not only for Captcha, but also for other functions. Watch the video in the attachment. **Please correct this in the THEMLER program.**
Thanks for reporting the issue. Did you notice a similar issue with previous Virtuemart versions or previous Themler versions?
Hello, Thanks for reporting the issue. Did you notice a similar issue with previous Virtuemart versions or previous Themler versions? Sincerely, Nettie
coleoptera
See Answers ID=207258
Testing results:
Themler v. 517
Joomla 3.9.24
VM 3.8.8 - bug
VM 3.6.11 - bug
VM 3.2.15 - bug
VM 3.2.10 - bug
VM 3.2.4 - bug
VM 3.2.3 - OK
See Answers ID=207258 Testing results: Themler v. 517 Joomla 3.9.24 VM 3.8.8 - bug VM 3.6.11 - bug VM 3.2.15 - bug VM 3.2.10 - bug VM 3.2.4 - bug VM 3.2.3 - OK
