Header Image
devrimbozdag
devrimbozdag posted this 21 April 2021
I don't want a picture on the homepage in the header. I want it to be transparent. However, I want pictures in the background of the post and other pages. I just couldn't. Can you help me?
8 Comments
Support Team posted this 21 April 2021
The simpliest solution would be to open the Header tab, select Show on Template and then disable it for the Home template.
Hello, The simpliest solution would be to open the Header tab, select Show on Template and then disable it for the Home template. Sincerely, Nettie
devrimbozdag
I want to have Header on all pages. There is a logo and a menu in the header. I just don't want the main page to have a header background image. The background image should only be on pages other than the home page.
I see now. For this purpose we recommend to use Homepage Style option from the Header tab >> enable Homepage Style and then choose Background and set it Transparent.
Hello, I see now. For this purpose we recommend to use Homepage Style option from the Header tab >> enable Homepage Style and then choose Background and set it Transparent. Sincerely, Nettie
devrimbozdag
I also tried what you said. It works if the background has color instead of a picture. However, if there is a picture, the transparent does not work. The picture continues to appear in the homepage header.
It would work if Opacity for the background is set to 0:
Themler support
It would work if Opacity for the background is set to 0: !Screenshot-1.png! !Screenshot-2.png! Gina Themler support
devrimbozdag
devrimbozdag posted this 24 April 2021
When I apply the last method, the logo in the header and the menu become invisible. How can I just make the picture invisible? Is it that hard to do something with HTML that we can do in two lines?
Support Team posted this 25 April 2021
Try adding this code to Home -> Settings -> Additional CSS:
.home header {
background-image:none!important;}
If it doesn't work, please, provide the link to your site.
Themler support
Try adding this code to Home -> Settings -> Additional CSS: .home header { background-image:none!important;} If it doesn't work, please, provide the link to your site. Gina Themler support
devrimbozdag
devrimbozdag posted this 25 April 2021
If anyone has the same problem, the correct solution is the last css code you wrote. This worked. Thanks...
