Scrolling issue in Firefox browser
Support Team posted this 05 May 2021
Since Firefox v.88 update there is an issue with scrolling in Firefox browser if Smooth Wheel is enabled in a theme. We recommend to disable Smooth Wheel for Firefox browser in Themler. For this please follow the steps below:
  1. Open the theme in Themler.
  2. Navigate the Home tab >> Settings.
  3. Smooth Wheel is disabled by default. If it is enabled, there is a cogwheel icon available (for settings).
  4. Click on the cogwheel icon to open the settings and choose Browsers >> Mozilla, then disable the option.
  5. Save the changes.
The issue can also happen if Parallax Background effect is active. You may need temporarily disabling this effect, for this please select the control in question, select Effects on the ribbon >> Parallax Background >> disable the effect.
Since Firefox v.88 update there is an issue with scrolling in Firefox browser if Smooth Wheel is enabled in a theme. We recommend to **disable Smooth Wheel for Firefox** browser in Themler. For this please follow the steps below: 1. Open the theme in Themler. 2. Navigate the **Home tab** >> **Settings**. 3. **Smooth Wheel** is disabled by default. If it is enabled, there is a cogwheel icon available (for settings). 4. Click on the **cogwheel icon** to open the settings and choose **Browsers** >> **Mozilla**, then **disable** the option. 5. Save the changes. !smooth-wheel.png! The issue can also happen if **Parallax Background** effect is active. You may need temporarily disabling this effect, for this please select the control in question, select **Effects** on the ribbon >> **Parallax Background** >> disable the effect.
49 Comments
kedud
kedud posted this 20 May 2021
OK, I found better solution. Problem is located in jquery.js file (test on Wordpress), when I remove this:
jQuery.each( { scrollLeft: "pageXOffset", scrollTop: "pageYOffset" }, function( method, prop ) {
var top = /Y/.test( prop );
jQuery.fn[ method ] = function( val ) {
    return access( this, function( elem, method, val ) {
        var win = getWindow( elem );
        if ( val === undefined ) {
            return win ? (prop in win) ? win[ prop ] :
                win.document.documentElement[ method ] :
                elem[ method ];
        if ( win ) {
            win.scrollTo(
                !top ? val : jQuery( win ).scrollLeft(),
                top ? val : jQuery( win ).scrollTop()
        } else {
            elem[ method ] = val;
    }, method, val, arguments.length, null );
Everything with scrool work fine on firefox 88, chears!
OK, I found better solution. Problem is located in jquery.js file (test on Wordpress), when I remove this: jQuery.each( { scrollLeft: "pageXOffset", scrollTop: "pageYOffset" }, function( method, prop ) { var top = /Y/.test( prop ); jQuery.fn[ method ] = function( val ) { return access( this, function( elem, method, val ) { var win = getWindow( elem ); if ( val === undefined ) { return win ? (prop in win) ? win[ prop ] : win.document.documentElement[ method ] : elem[ method ]; } if ( win ) { win.scrollTo( !top ? val : jQuery( win ).scrollLeft(), top ? val : jQuery( win ).scrollTop() ); } else { elem[ method ] = val; } }, method, val, arguments.length, null ); }; }); Everything with scrool work fine on firefox 88, chears!
Support Team posted this 30 May 2021
Another workaround would be to edit the script.js file (e.g. winscp).
Search for ... arrowscroll: 50, useOnWebKit: true, useOnMozilla: false, useOnIE: true} ....
and change useOnMozilla: true to useOnMozilla: false
Themler support
Hello, Another workaround would be to edit the script.js file (e.g. winscp). Search for ... arrowscroll: 50, useOnWebKit: true, useOnMozilla: false, useOnIE: true} .... and change `useOnMozilla: true` to `useOnMozilla: false` Gina Themler support
reiner6
reiner6 posted this 04 June 2021
Thanks, this solution works great for me ...
tmgarrison
tmgarrison posted this 17 June 2021
Not so fast there Gina.
I just noticed today that there is that problem. I made sure the site is updated, found an update for Themler in the site (and this only happens on 1 site where I have Themler installed), saved, then tested.
The full page scroll with only a small touch of the mouse wheel happens no matter what I do.
To be more clear, in Themler, I have never enabled "Smooth Wheel" and it is NOT enabled in the site that is having the problem nor any of my other sites where I have Themler installed and updated. In fact, I've been quite busy on a project using Joomla with Themler and have had no problems.
The site with the issue is one that I have "not" logged into for several weeks - or longer. Yet, when I visited the site today the page scrolled a from top to bottom when I only scrolled the wheel 1 detent.
I'm using Joomla, not wordpress.
Now what?!
Thank you.
Not so fast there Gina. I just noticed today that there is that problem. I made sure the site is updated, found an update for Themler in the site (and this only happens on 1 site where I have Themler installed), saved, then tested. The full page scroll with only a small touch of the mouse wheel happens no matter what I do. To be more clear, in Themler, I have never enabled "Smooth Wheel" and it is NOT enabled in the site that is having the problem nor any of my other sites where I have Themler installed and updated. In fact, I've been quite busy on a project using Joomla with Themler and have had no problems. The site with the issue is one that I have "not" logged into for several weeks - or longer. Yet, when I visited the site today the page scrolled a from top to bottom when I only scrolled the wheel 1 detent. I'm using Joomla, not wordpress. Now what?! Thank you.
Support Team posted this 17 June 2021
As written in the article, unfortunately, "The issue can also happen if Parallax Background effect is active. You may need temporarily disabling this effect, for this please select the control in question, select Effects on the ribbon >> Parallax Background >> disable the effect."
Possibly this is the reason in your case.
Hello, As written in the article, unfortunately, "The issue can also happen if Parallax Background effect is active. You may need temporarily disabling this effect, for this please select the control in question, select Effects on the ribbon >> Parallax Background >> disable the effect." Possibly this is the reason in your case. Sincerely, Nettie
tmgarrison
So, you are saying that if I "redesign" the page, then everything is functioning correctly?
If I disable Parallax, that destroys the design of the home page. Furthermore, why not get the developers to fix what they broke?!
Is this a "temporary" issue that will be fixed in a few days? Or is this something that is going to take months? Or, is management simply stating that those who pay nearly $200 a year to use Themler will simply have to find another way to design?
I can understand if an update caused something that is "being" fixed. But to simply come up with methods to not use functions, or to have to hard-code files in Themler is not acceptable.
What is being done to fix the issue?
Hello, So, you are saying that if I "redesign" the page, then everything is functioning correctly? If I disable Parallax, that destroys the design of the home page. Furthermore, why not get the developers to fix what they broke?! Is this a "temporary" issue that will be fixed in a few days? Or is this something that is going to take months? Or, is management simply stating that those who pay nearly $200 a year to use Themler will simply have to find another way to design? I can understand if an update caused something that is "being" fixed. But to simply come up with methods to not use functions, or to have to hard-code files in Themler is not acceptable. What is being done to fix the issue?
tamas
tamas posted this 29 June 2021
his colleague is right. Many basic things are missing. There are a lot of mistakes. There are no instructions for use either. I don't even dare buy the update because I don't know what it contains.
Virtuemart term view is very bad the zoom cannot be adjusted.
At least such bugs could be updated.
Hello his colleague is right. Many basic things are missing. There are a lot of mistakes. There are no instructions for use either. I don't even dare buy the update because I don't know what it contains. Virtuemart term view is very bad the zoom cannot be adjusted. At least such bugs could be updated.
pvcmloza
pvcmloza posted this 03 May 2025
3 Patti Boss is highly accessible and user-friendly. Whether you’re a beginner or an experienced player, the game offers a smooth and intuitive interface. You can start playing in just a few taps, anytime and anywhere, without needing physical cards or other players in person Check out this page. This convenience makes it appealing to a wide audience—from young adults looking for fun to older users seeking mental engagement.
3 Patti Boss is highly accessible and user-friendly. Whether you’re a beginner or an experienced player, the game offers a smooth and intuitive interface. You can start playing in just a few taps, anytime and anywhere, without needing physical cards or other players in person [Check out this page][1]. This convenience makes it appealing to a wide audience—from young adults looking for fun to older users seeking mental engagement. [1]: https://3pattibosspk.org/
chinahousehold
chinahousehold posted this 05 February 2026
https://www.xcspa.com/finger-joint-pine-plywood-for-tables-and-desks-durability-test-results/
https://naya.com.np/post/p1770036344dkcro
https://hackmd.io/@bothbest/r1eQTGRU-x
https://zybuluo.com/bothbest/note/2649327
https://comunidad.espoesia.com/bothbest/lightweight-yet-strong-why-pine-boards-are-ideal-for-diy-furniture/
https://www.auseka.com.au/blog/how-to-choose-high-quality-finger-joint-pine-plywood-for-cabinets
https://ameblo.jp/bamboofloor/entry-12955489362.html
https://www.skudci.com/forum/1209185/finger-joint-pine-board-vs-regular-pine-plywood-which-better-furniture
https://wefreeads.com/listing/finger-joint-pine-plywood-and-waterproof-coatings/
https://quickregisterhosting.com/classifieds/for-sale/home-furniture-garden/finger-joint-pine-plywood_i904686
https://mypaper.pchome.com.tw/bothbest/post/1382994935
https://www.bizthistown.com/discussions/budget-furniture-upgrade-how-pine-plywood-adds-quality-without-high-cost
https://sngine.fr/blogs/27554/The-Real-Cost-of-Finger-Joint-Pine-Boards-Are-They
https://id.carousell.com/p/the-real-cost-of-finger-joint-pine-boards-1419402969/
https://whatoplay.com/review/45455/
https://www.cssauw.org/forum/thread-41118-1-1
https://ads948.com/detail/post-642901.html
https://www.expatriates.com/cls/62487358.html
https://forumtransportu.pl/forum/temat/30003
https://arizonaadam.com/forum/topic/how-pine-plywood-adds-quality-without-high-cost/
https://kadrmaskreations.com/forum/topic/why-furniture-makers-prefer-finger-joint-pine-plywood-key-benefits-explained/
https://pad.degrowth.net/s/BtmeU7f8s
https://pad.koeln.ccc.de/s/Onk9jmib1
https://pads.zapf.in/s/GgzUHk7goy
https://pad.funkwhale.audio/s/1p0uxgBe2
https://pad.interhop.org/s/PFo9tqc78G
https://pad.medialepfade.net/s/IGG1_DSKW
https://pad.stuve.de/s/zBzb4lW66O
https://jsfiddle.net/bothbest/6czh8stx/1/
https://www.datascienceportfol.io/chinahousehold/projects/2
https://topbilliondirectory.com/author/bothbest-92540/
https://bambooflooring.alboompro.com/post/top-reasons-finger-joint-pine-boards-are-popular-for-modern-home-furniture
https://bothbest.weebly.com/blog/best-thickness-options-for-finger-joint-pine-plywood-in-furniture-production
https://www.whizolosophy.com/category/life-s-big-questions/article-column/how-to-avoid-cracking-in-pine-boards-during-furniture-assembly
https://www.srujanee.in/view/sustainability-matters-why-pine-plywood-is-a-responsible-fur-aoK1SDha
http://poster.4teachers.org/worksheet/view.php?id=195620
https://www.uscgq.com/forum/posts.php?forum=&id=648832
https://www.theconsumersfeedback.com/guestpost/how-to-identify-premium-finger-joint-pine-plywood-before-buying
https://www.hssolar.cn/news-45.html
https://chot.design/forums/ui-design/1792053/
https://www.xcspa.com/finger-joint-pine-plywood-for-tables-and-desks-durability-test-results/ https://naya.com.np/post/p1770036344dkcro https://hackmd.io/@bothbest/r1eQTGRU-x https://zybuluo.com/bothbest/note/2649327 https://comunidad.espoesia.com/bothbest/lightweight-yet-strong-why-pine-boards-are-ideal-for-diy-furniture/ https://www.auseka.com.au/blog/how-to-choose-high-quality-finger-joint-pine-plywood-for-cabinets https://ameblo.jp/bamboofloor/entry-12955489362.html https://www.skudci.com/forum/1209185/finger-joint-pine-board-vs-regular-pine-plywood-which-better-furniture https://wefreeads.com/listing/finger-joint-pine-plywood-and-waterproof-coatings/ https://quickregisterhosting.com/classifieds/for-sale/home-furniture-garden/finger-joint-pine-plywood_i904686 https://mypaper.pchome.com.tw/bothbest/post/1382994935 https://www.bizthistown.com/discussions/budget-furniture-upgrade-how-pine-plywood-adds-quality-without-high-cost https://sngine.fr/blogs/27554/The-Real-Cost-of-Finger-Joint-Pine-Boards-Are-They https://id.carousell.com/p/the-real-cost-of-finger-joint-pine-boards-1419402969/ https://whatoplay.com/review/45455/ https://www.cssauw.org/forum/thread-41118-1-1 https://ads948.com/detail/post-642901.html https://www.expatriates.com/cls/62487358.html https://forumtransportu.pl/forum/temat/30003 https://arizonaadam.com/forum/topic/how-pine-plywood-adds-quality-without-high-cost/ https://kadrmaskreations.com/forum/topic/why-furniture-makers-prefer-finger-joint-pine-plywood-key-benefits-explained/ https://pad.degrowth.net/s/BtmeU7f8s https://pad.koeln.ccc.de/s/Onk9jmib1 https://pads.zapf.in/s/GgzUHk7goy https://pad.funkwhale.audio/s/1p0uxgBe2 https://pad.interhop.org/s/PFo9tqc78G https://pad.medialepfade.net/s/IGG1_DSKW https://pad.stuve.de/s/zBzb4lW66O https://jsfiddle.net/bothbest/6czh8stx/1/ https://www.datascienceportfol.io/chinahousehold/projects/2 https://topbilliondirectory.com/author/bothbest-92540/ https://bambooflooring.alboompro.com/post/top-reasons-finger-joint-pine-boards-are-popular-for-modern-home-furniture https://bothbest.weebly.com/blog/best-thickness-options-for-finger-joint-pine-plywood-in-furniture-production https://www.whizolosophy.com/category/life-s-big-questions/article-column/how-to-avoid-cracking-in-pine-boards-during-furniture-assembly https://www.srujanee.in/view/sustainability-matters-why-pine-plywood-is-a-responsible-fur-aoK1SDha http://poster.4teachers.org/worksheet/view.php?id=195620 https://www.uscgq.com/forum/posts.php?forum=&id=648832 https://www.theconsumersfeedback.com/guestpost/how-to-identify-premium-finger-joint-pine-plywood-before-buying https://www.hssolar.cn/news-45.html https://chot.design/forums/ui-design/1792053/
backlinksseo234
backlinksseo234 posted this 31 August 2026
Awesome post. Typically the put up can affect a considerable amount of instant concerns our the community. We tend to can't be uninvolved towards such concerns. This unique put up will provide good ideas not to mention strategies. Especially instructive not to mention efficient. 바둑이 커뮤니티
Awesome post. Typically the put up can affect a considerable amount of instant concerns our the community. We tend to can't be uninvolved towards such concerns. This unique put up will provide good ideas not to mention strategies. Especially instructive not to mention efficient. [바둑이 커뮤니티](https://xn--vy7ba94z.com/pages/badugi)
backlinksseo234
backlinksseo234 posted this 05 September 2026
This is simply the info I'm discovering almost everywhere. Many thanks for the weblog, I simply sign up your site. This can be a good weblog. inch. bridal underwear
This is simply the info I'm discovering almost everywhere. Many thanks for the weblog, I simply sign up your site. This can be a good weblog. inch. [bridal underwear](https://www.amazon.com/dp/B0G873T367)
xeniko8001
xeniko8001 posted this 08 September 2026
*Spot on with this write-up, I truly think this website needs much more consideration. I’ll probably be again to read much more, thanks for that info. m88vin.pics
*Spot on with this write-up, I truly think this website needs much more consideration. I’ll probably be again to read much more, thanks for that info. [url=https://m88vin.pics/]m88vin.pics[/url]
helelox259
helelox259 posted this 08 September 2026
Hi. Cool post. There’s an issue with your site in chrome, and you may want to test this… The browser is the marketplace chief and a good element of people will omit your excellent writing because of this problem. kubets.app
Hi. Cool post. There’s an issue with your site in chrome, and you may want to test this… The browser is the marketplace chief and a good element of people will omit your excellent writing because of this problem. [kubets.app](https://kubets.app/)
gemico9251
gemico9251 posted this 10 September 2026
comforter sets really makes me me warm and comfy specially at night;; slot gacor
comforter sets really makes me me warm and comfy specially at night;; [slot gacor](https://purehealsphere.online/featured-slot-platforms/)
povage2116
povage2116 posted this 14 September 2026
What your stating is totally accurate. I know that everyone need to say the similar issue, but I just think that you set it in a way that all of us can recognize. I also really like the images you put in the following. They match so nicely with what youre hoping to say. Im certain youll achieve so many people today with what youve got to say. slot dana
What your stating is totally accurate. I know that everyone need to say the similar issue, but I just think that you set it in a way that all of us can recognize. I also really like the images you put in the following. They match so nicely with what youre hoping to say. Im certain youll achieve so many people today with what youve got to say. [slot dana](https://apk.slotdana.co.uk/)
xeniko8001
xeniko8001 posted this 15 September 2026
That is the best blog for anybody who wants to search out out about this topic. You realize so much its virtually onerous to argue with you (not that I actually would want…HaHa). You undoubtedly put a brand new spin on a topic thats been written about for years. Great stuff, just nice! situs dewa33
That is the best blog for anybody who wants to search out out about this topic. You realize so much its virtually onerous to argue with you (not that I actually would want…HaHa). You undoubtedly put a brand new spin on a topic thats been written about for years. Great stuff, just nice! [url=https://novodoba.org/]situs dewa33[/url]
povage2116
povage2116 posted this 16 September 2026
I am just commenting to let you know of the perfect experience my wife's princess encountered studying your web site. She picked up numerous details, most notably what it's like to have an ideal helping character to have many more very easily gain knowledge of selected advanced subject matter. You undoubtedly exceeded our own expectations. Thanks for offering such effective, healthy, explanatory and in addition fun thoughts on this topic to Gloria. gacor
I am just commenting to let you know of the perfect experience my wife's princess encountered studying your web site. She picked up numerous details, most notably what it's like to have an ideal helping character to have many more very easily gain knowledge of selected advanced subject matter. You undoubtedly exceeded our own expectations. Thanks for offering such effective, healthy, explanatory and in addition fun thoughts on this topic to Gloria. [gacor](https://petirkoitoto.com/)
tajogej112
tajogej112 posted this 20 September 2026
Finally, got what I was looking for!! I’ve really enjoying every small bit of this. Ecstatic I stumbled into this post! and also I’ve bookmarked to look at unique information for your blog post. IndoCair Slot
Finally, got what I was looking for!! I’ve really enjoying every small bit of this. Ecstatic I stumbled into this post! and also I’ve bookmarked to look at unique information for your blog post. [IndoCair Slot](https://indocairjp.com/indocair-slot/)
xeniko8001
xeniko8001 posted this 20 September 2026
So, is this just for men, just for women, or is it for both sexes If it s not, then do women need to do anything different to put on muscle nohu90 com
tajogej112
Thank you for sharing excellent information. Your web site is so cool. I am impressed by the info that you’ve on this web site. It reveals how nicely you perceive this subject. Bookmarked this web page, will come back for more articles. 인천출장마사지
Thank you for sharing excellent information. Your web site is so cool. I am impressed by the info that you’ve on this web site. It reveals how nicely you perceive this subject. Bookmarked this web page, will come back for more articles. [인천출장마사지](https://chinchinmassage.uriweb.kr/incheon-massage)
