Shape Divider - Wordpress Template
AureyoBoss
AureyoBoss posted this 02 June 2021
Is it possible to add Shape Divider in a WordPress template (between each section) ? Here is an example : https://elementor.com/blog/v130-shape-divider/
Thank you.
Hello, Is it possible to add Shape Divider in a WordPress template (between each section) ? Here is an example : https://elementor.com/blog/v130-shape-divider/ Thank you.
Support Team posted this 03 June 2021
Hello Yohan,
We don't have a notion of a "shape divider" but you can achieve similar effect by adding shape-like backgrounds to the sections or adding spacers between the sections with their own background. Example of backgrounds:
You can upload your own file with a shape and use "Overlap Next section" option to achieve the effect of content overflowing the shape.
Hello Yohan, We don't have a notion of a "shape divider" but you can achieve similar effect by adding shape-like backgrounds to the sections or adding spacers between the sections with their own background. Example of backgrounds: !Screenshot-1.png! You can upload your own file with a shape and use "Overlap Next section" option to achieve the effect of content overflowing the shape. Gina Themler Support
