Why is the height of the message content different. Sometimes the sentence is split, sometimes the whole article is published.
https://cyberpreventieshop.test-ararin.be/category/kinderen/
Hello Kris,
Usually it depends on how you control Read More button: it is either added directly in the post in wp-admin -> Posts, or you can set the number of characters an excerpt should be using under wp-admin -> Appearance -> Theme Options.
No its add to the content container
No its add to the content containerDo you mean you have added the text directly to that container?
From the screenshot it looks like autogenerated excerpt.
Could you please provide temporary access to the site?
Try disabling this option or change the number of characters:
Height of the post content is different refers to varying vertical dimensions within a post, which can lead to inconsistent layouts. For example, discussing the average height in Philippines may result in uneven spacing if content like text or images differs in size. Designers use CSS techniques to ensure consistent and visually balanced presentations across posts.
Height of the post content is different refers to varying vertical dimensions within a post, which can lead to inconsistent layouts. For example, discussing the [average height in Philippines][1] may result in uneven spacing if content like text or images differs in size. Designers use CSS techniques to ensure consistent and visually balanced presentations across posts. [1]: https://104fashionmag.com/average-height-in-philippines/
