Hello Themler
I have work with a themler wordpress themes and delevery a WP website to a friend.
But how can he edit (changes txt or pictures) only with login (browser) to wordpress webiste ???
Best regards
Jørgen Hansen
Denmark
Hello Themler
Best regards
Jørgen Hansen
Denmark
To make Themler option not available in WP admin, please disable "Include Themler" option on export for your theme.
You will be able to edit posts and pages, menus, widgets from WP admin.
Hello Themler.
Thanks for your reply.
I am not sure How exactly to do......... what you recommend !
I´ve think maybe there is another solution... But i am not sure !?!?
In WB - Plugin: Themler core and use disable ???
Best regards
Jørgen Hansen
Denmark
Hello Jørgen,
Where do you create themes initially - in Themler desktop or on the website?
Hello Themler.
I have a Themler desktop.
My workflow is:
Best regards
Jørgen Hansen
Denmark
Thank you for the details. In this case we recommend the following way:
1. Export the theme from your website from Themler File >> Export in two versions: one with Themler included - for your backup, one without Themler editor.
2. Install the theme without Themler editor on your website and activate it.
Hello.
Ofcourse i allways make full export Zip file (backup)
So........You mean i have to make a export - like see picture !
Best regards
Jørgen Hansen
Denmark
Hi Jørgen,
Exactly, like on your picture. Of course, including content is potional.
