Change cursor with an image
armando.gobbi2
armando.gobbi2 posted this 26 August 2021
Does anyone know if it is possible to change the mouse cursor (on hover - the "little hand") with another image?
Thank u
Hi, Does anyone know if it is possible to change the mouse cursor (on hover - the "little hand") with another image? Thank u
Support Team posted this 27 August 2021
It is possible if you have the custom image or a link to it, and then you can add custom CSS code that would use that image. The example is here https://stackoverflow.com/questions/18551277/using-external-images-for-css-custom-cursors
Hello, It is possible if you have the custom image or a link to it, and then you can add custom CSS code that would use that image. The example is here https://stackoverflow.com/questions/18551277/using-external-images-for-css-custom-cursors Gina Themler Support
