Greetings.
I have the following problem when creating a theme for wordpress:
install themler in wordpress and start creating ... on the home page there are 4 options on the left side.
1) Header 2) template 3) page - green section 4) footer
When I add a section to the page (green section) and I save the changes, it is updated and I can no longer edit the section, a green frame appears that says post.
try disabling cms and the green page section disappears from the left side of the panel, only options 1 remain heder / template page / footer
when adding sections in template they are duplicated in the other pages.
I need to create different content for each page of the website, please tell me how I can do it.
I need to enable the green page section and be able to edit the content when necessary.
I have installed wordpress again everything seemed to work fine, but as soon as I save the changes the green section disappears from all the pages.
sections are automatically converted into post content and do not allow editing
I highlight that I have not modified any page since wp-admin
I appreciate your help.
Greetings. I have the following problem when creating a theme for wordpress: install themler in wordpress and start creating ... on the home page there are 4 options on the left side. 1) Header 2) template 3) page - green section 4) footer When I add a section to the page (green section) and I save the changes, it is updated and I can no longer edit the section, a green frame appears that says post. try disabling cms and the green page section disappears from the left side of the panel, only options 1 remain heder / template page / footer when adding sections in template they are duplicated in the other pages. I need to create different content for each page of the website, please tell me how I can do it. I need to enable the green page section and be able to edit the content when necessary. I have installed wordpress again everything seemed to work fine, but as soon as I save the changes the green section disappears from all the pages. sections are automatically converted into post content and do not allow editing I highlight that I have not modified any page since wp-admin I appreciate your help.
