Hide Virtuemart header bar (filters) on category view
frederic11
frederic11 posted this 04 October 2021
i try to hide the header bar in the category view. I want this bar ONLY in products view. There is non sens to have it in categories view. See screenshots.
Is it a way to do that ?
Hello, i try to hide the header bar in the category view. I want this bar ONLY in products view. There is non sens to have it in categories view. See screenshots. Is it a way to do that ? !2021-10-04-10-21-58.jpg! !2021-10-04-10-21-20.jpg!
Support Team posted this 04 October 2021
Unfortunately, there isn't any ready way to do this, because no matter if Products or Categories are displayed, in Joomla a single VM Category Layout menu item type is used for both. So this menu item type uses Products template in Themler.
Theoretically, you may try to hide the Columns containing those controls, with custom CSS, on specific pages, however this way can be complicated. In any way, we recommend to create a backup or to try on a copy of the theme.
Also please note that the code added directly to template files, can be overwritten when a theme is saved or updated. So probably changes for the final theme version make sense. Also a code added to Home >> Settings >> Additional CSS is kept while saving.
Another theoretical way is to add a second template of the Products type in Themler like Products 2 and find a way to attach it to a specific menu item that opens categories.
Hello, Unfortunately, there isn't any ready way to do this, because no matter if Products or Categories are displayed, in Joomla a single VM Category Layout menu item type is used for both. So this menu item type uses Products template in Themler. Theoretically, you may try to hide the Columns containing those controls, with custom CSS, on specific pages, however this way can be complicated. In any way, we recommend to create a backup or to try on a copy of the theme. Also please note that the code added directly to template files, can be overwritten when a theme is saved or updated. So probably changes for the final theme version make sense. Also a code added to Home >> Settings >> Additional CSS is kept while saving. Another theoretical way is to add a second template of the Products type in Themler like Products 2 and find a way to attach it to a specific menu item that opens categories. Sincerely, Nettie
raymond515carthy
raymond515carthy posted this 09 April 2025
The PA EZ Pass login portal makes managing your toll payments and account settings easy and efficient. Whether you’re driving through the Pennsylvania Turnpike or another toll road in the state, having access to your EZ Pass account online through the EZ Pass PA login portal is incredibly convenient. ktag org
The PA EZ Pass login portal makes managing your toll payments and account settings easy and efficient. Whether you’re driving through the Pennsylvania Turnpike or another toll road in the state, having access to your EZ Pass account online through the EZ Pass PA login portal is incredibly convenient. [ktag org][1] [1]: https://www-ktag.com
henryashford663
henryashford663 posted this 11 October 2025
It seems like this issue could be handled with some targeted CSS adjustments depending on the VirtueMart layout. You might want to check tools on MySTR website portal, where developers often share Joomla and VirtueMart customization tips for hiding or modifying specific elements like header bars.
It seems like this issue could be handled with some targeted CSS adjustments depending on the VirtueMart layout. You might want to check tools on [MySTR][1] website portal, where developers often share Joomla and VirtueMart customization tips for hiding or modifying specific elements like header bars. [1]: http://esemakanstr.my/
