Have a big problem. My Hosting Provider update PLESK and now there is installed a MariaDB. I have no chance to change this, because than I have to change my provider I have now for more than 20 years :((
I found out, that I can't create or edit templates for Joomla now. If insert e.g. a modle position:
Error message comes up
* snip
Unknown named parameter $title
snip *
This effect comes up after e.g. insert and activte a new or changed modul position, if you deactivte than the 'new' position, it works, but only with the stock template installed after you upload (install) the blank joomla template from themler.com
E.g. if you have an 'old' installation, created a template before, the template works, but whenever you want to make a change .... crash with the errormessage see above :(( same effect if get a template from the themler site, import or upload.
Please HELP!
Have a big problem. My Hosting Provider update PLESK and now there is installed a MariaDB. I have no chance to change this, because than I have to change my provider I have now for more than 20 years :(( I found out, that I can't create or edit templates for Joomla now. If insert e.g. a modle position: Error message comes up *** snip *** Unknown named parameter $title *** snip *** This effect comes up after e.g. insert and activte a new or changed modul position, if you deactivte than the 'new' position, it works, but only with the stock template installed after you upload (install) the blank joomla template from themler.com E.g. if you have an 'old' installation, created a template before, the template works, but whenever you want to make a change .... crash with the errormessage see above :(( same effect if get a template from the themler site, import or upload. Please HELP!Last edited 07 October 2021 by technic.direct
