Themler Update (18-August-2015)
Support Team posted this 18 August 2015
Update
  • UI Improvements
  • Transition effects for typography elements, like Link Hover or Headings
  • Transition effects for Submenu, Cart Link, Language and Currency controls
  • Blend mode for Background
  • Texture Overlay effect
  • HTML: Date Picker for Post Date
  • HTML: Custom URL in Page Properties dialog for custom menu item url and Target property
  • Various small features and fixes
And more features at Themler Weekly Update (18-August-2015)
What is Next?
We are working on Section control that allows to add ready to use sections in one click like below:
See Also
Previous updates
### Update - UI Improvements - Transition effects for typography elements, like Link Hover or Headings - Transition effects for Submenu, Cart Link, Language and Currency controls - *Blend mode* for Background - *Texture Overlay* effect - HTML: *Date Picker* for Post Date - HTML: *Custom URL* in Page Properties dialog for custom menu item url and *Target* property - Various small features and fixes And more features at [Themler Weekly Update (18-August-2015) ](page:21218) ### What is Next? We are working on **Section** control that allows to add ready to use sections in one click like below: !overlay.jpg! ### See Also <a href="http://answers.billiondigital.com/categories/3916/">Previous updates</a>
34 Comments
ClaudiaK
ClaudiaK posted this 18 August 2015
Oh great. Thanks. A big applause...
DouzanStudio
DouzanStudio posted this 18 August 2015
WOW! Thanks a lot guys & waiting for the next feature "add ready to use sections in one click" it will be awesome.
WOW! Thanks a lot guys & waiting for the next feature "**add ready to use sections in one click**" it will be awesome.
pawel.neografix
pawel.neografix posted this 18 August 2015
Error has occured and your project will be restored... This happend in this version (today)... :/
afshar2092
afshar2092 posted this 18 August 2015
Support Team posted this 19 August 2015
Hi guys,
Thank you for your feedback. It's very important for us to keep our costumers satisfied!
Paweł, please feel free to create a separate private ticket so we can try to help you.
Ivan
Hi guys, Thank you for your feedback. It's very important for us to keep our costumers satisfied! Paweł, please feel free to create a separate private ticket so we can try to help you. Thanks, Ivan
enri.riccioli
enri.riccioli posted this 19 August 2015
please
where is the link for the upgrade ?
the home is located themler upgrade 08/10/2015 .
please where is the link for the upgrade ? the home is located themler upgrade 08/10/2015 .
There is no link for the upgrade.
Just open Themler application (online or desktop) and you'll see an option to upgrade (red '1' circle).
Ivan
Hi, There is no link for the upgrade. Just open Themler application (online or desktop) and you'll see an option to upgrade (red '1' circle). Thanks, Ivan
Stagger Lee posted this 19 August 2015
What is purpose of new Texture Overlay effect ? Usually goes some text or content inside it.
If you make it possible to insert other controls inside Texture Overlay you open for a lot of new possibilities. One of them is asked some times here on forum, captions over featured, or other, images.
And how to set height of Texture Overlay ?
I see now, it takes containers height. For some reason in Hover box (over image) it is just tiny strip of cca 10px height.
What is purpose of new Texture Overlay effect ? Usually goes some text or content inside it. If you make it possible to insert other controls inside Texture Overlay you open for a lot of new possibilities. One of them is asked some times here on forum, captions over featured, or other, images. And how to set height of Texture Overlay ? I see now, it takes containers height. For some reason in Hover box (over image) it is just tiny strip of cca 10px height.
GroovyWeb
GroovyWeb posted this 20 August 2015
After this update my Themler Menu editor (Wordpress setup) displays every page that is located on the website in the primary menu navigation area. I've tried to create new menus, manage locations, re-install Themler, etc. Nothing I do seems to change the appearance of the menu when in the editor... The good thing is that it does not upload to site this way, it only appears in the editor.
websitefixerupper
websitefixerupper posted this 20 August 2015
It happened to me too, plus my template got corrupted! the widgets went haywire and the template now shows no widgets but the domain does. anybody else?
> Error has occured and your project will be restored... This happend in this version (today)... :/ It happened to me too, plus my template got corrupted! the widgets went haywire and the template now shows no widgets but the domain does. anybody else?
edypeter
edypeter posted this 20 August 2015
After the update Drag and Drop doesn't work. (Joomla Version) I tried it with different Browsers but it doesn't make a diffrence.
Edit: Ok now it works. Don't now where the problem was.
After the update Drag and Drop doesn't work. (Joomla Version) I tried it with different Browsers but it doesn't make a diffrence. Edit: Ok now it works. Don't now where the problem was.
joshpell
joshpell posted this 20 August 2015
I have encountered the same problem as websitefixerupper, all my widgets in my theme are not showing correctly and in the outline there are no widget area's showing. It is like it does not recognise previous widget area's as when you add a new one it (at least for me) has started the widget count again saying "Area 1"
Stagger Lee posted this 20 August 2015
I noticed same problem with widgets not showing.
And in one occasion Themler cannot see what Menu Items are there. Picks some random, or just one.
Maybe it has something to do with new WP version 4.3, dont know.
I noticed same problem with widgets not showing. And in one occasion Themler cannot see what Menu Items are there. Picks some random, or just one. Maybe it has something to do with new WP version 4.3, dont know.
mmp
mmp posted this 20 August 2015
Some Virtuemart for Joomla issues: (Some new, some back.
Suddenly, cart does not update when product is added.
Asking for register on checkout. (Set in back-end to checkout without first login)
Display messed up when categories are changed to 4 in virtuemart/configuration/template - When set to 3, it's fine.
Does not display sub-categories in Virtuemart front-end
Sometimes crashes when resizing pictures.
Crashes if not saved often (IOW when Joomla logs out automatically). Intentionally don't save as it takes up to 10 min each time to save. Speed is a major issue!
Some Virtuemart for Joomla issues: (Some new, some back. Suddenly, cart does not update when product is added. Asking for register on checkout. (Set in back-end to checkout without first login) Display messed up when categories are changed to 4 in virtuemart/configuration/template - When set to 3, it's fine. !4-categories.JPG! Does not display sub-categories in Virtuemart front-end Sometimes crashes when resizing pictures. Crashes if not saved often (IOW when Joomla logs out automatically). Intentionally don't save as it takes up to 10 min each time to save. Speed is a major issue!
Support Team posted this 20 August 2015
Rayan,
Please create a new Private topic for the reported issue with access to the CMS admin panel. We'll investigate it.
Guys,
Could you please create new Private topic for the reported issues.
For the issue with widgets we need the access to the WP admin panel.
**Rayan,** Please create a new Private topic for the reported issue with access to the CMS admin panel. We'll investigate it. >>Error has occured and your project will be restored... This happend in this version (today)... :/ >It happened to me too, plus my template got corrupted! the widgets went haywire and the template now shows no widgets but the domain does. anybody else? **Guys,** Could you please create new Private topic for the reported issues. For the issue with widgets we need the access to the WP admin panel.
This is additional overlay layer of the control (created with :before css element).
The screenshot from the "What is Next?" section was created using this Extension. The darkening effect of the background image is Texture Overlay.
Here is original image:
http://billionphotos.com/Media/Detail/1902417/clipart-real-building-buildings-backgrounds-blue-photo
Note: in order to see this layer the control should have position "relative" specified under the Arrange section.
> What is purpose of new Texture Overlay effect ? This is additional overlay layer of the control (created with `:before` css element). The screenshot from the "What is Next?" section was created using this Extension. The darkening effect of the background image is Texture Overlay. Here is original image: http://billionphotos.com/Media/Detail/1902417/clipart-real-building-buildings-backgrounds-blue-photo **Note:** in order to see this layer the control should have position "relative" specified under the Arrange section.
websitefixerupper
Rayan,
Guys,
I did 10 hours ago Please help!!!
> **Rayan,** > > Please create a new Private topic for the reported issue with access to the CMS admin panel. We'll investigate it. > > >>Error has occured and your project will be restored... This happend in this version (today)... :/ > > >It happened to me too, plus my template got corrupted! the widgets went haywire and the template now shows no widgets but the domain does. anybody else? > > **Guys,** > > Could you please create new Private topic for the reported issues. > For the issue with widgets we need the access to the WP admin panel. I did 10 hours ago Please help!!!
websitefixerupper
philippe.pphantom
philippe.pphantom posted this 20 August 2015
you don't answer to private topics; your software don't work and you sell it it's not honest.
The DRUPAL plugin in completely not usable for 48$...
you don't answer to private topics; your software don't work and you sell it it's not honest. The DRUPAL plugin in completely not usable for 48$...
Support Team posted this 21 August 2015
Stephan,
have you got the reported issues in the theme used on the site http://mmponline.co.za/joomlanew1/?
1.
I see the issue and I'm passing it to review.
2.
first login)
You're asked to log in because the Cart page access is available for registered users only
http://attachments.answers.billiondigital.com/298/4298/CartRegistered.png
Also right now under VM settings the registration on checkout is required:
http://attachments.answers.billiondigital.com/299/4299/CheckoutRegistration.png
3.
I've got a problem with 4 categories per row in FF browser, the output in Chrome is OK. We'll check it too. As workaround I've added to the theme the CSS code
.col-md-6, .col-sm-6,  .col-xs-6{
padding-left:0px!important;
padding-right:0px!important;
4.
I checked the VM front page under Beez3 template and it outputs the same categories. Where exactly you expect the subcategories to be displayed?
5.
Can you provide a leats one scenario how we could reproduce this issue?
From our end we'll check the crash logs.
6.Crashes if not saved often (IOW when Joomla logs out automatically).
7.Intentionally don't save as it takes up to 10 min each time to save. Speed is a major issue!
I'm sorry but these issue are not clear. Could you please describe them in more details?
In future please submit a new topic to report about issues after the update. Thank you.
And I do not mind if you move some issues from this topic to separate new topics.
**Stephan,** have you got the reported issues in the theme used on the site http://mmponline.co.za/joomlanew1/? 1. > Suddenly, cart does not update when product is added. I see the issue and I'm passing it to review. 2. > Asking for register on checkout. (Set in back-end to checkout without > first login) You're asked to log in because the Cart page access is available for registered users only http://attachments.answers.billiondigital.com/298/4298/CartRegistered.png Also right now under VM settings the registration on checkout is required: http://attachments.answers.billiondigital.com/299/4299/CheckoutRegistration.png 3. > Display messed up when categories are changed to 4 in > virtuemart/configuration/template - When set to 3, it's fine I've got a problem with 4 categories per row in FF browser, the output in Chrome is OK. We'll check it too. As workaround I've added to the theme the CSS code .col-md-6, .col-sm-6, .col-xs-6{ padding-left:0px!important; padding-right:0px!important; } 4. > Does not display sub-categories in Virtuemart front-end I checked the VM front page under Beez3 template and it outputs the same categories. Where exactly you expect the subcategories to be displayed? 5. > Sometimes crashes when resizing pictures. Can you provide a leats one scenario how we could reproduce this issue? From our end we'll check the crash logs. > 6.Crashes if not saved often (IOW when Joomla logs out automatically). > 7.Intentionally don't save as it takes up to 10 min each time to save. Speed is a major issue! I'm sorry but these issue are not clear. Could you please describe them in more details? In future please submit a new topic to report about issues after the update. Thank you. And I do not mind if you move some issues from this topic to separate new topics. regards, Aileen
