error
AndrzejM
AndrzejM posted this 12 October 2021
I found a bug in your software.
If we add text and it contains the e-mail address with @, then it cannot be edited. You have to change the HTML Source edit option to ... (at) ........ and then you can make changes.
Is it possible to correct this error?
Hello I found a bug in your software. If we add text and it contains the e-mail address with @, then it cannot be edited. You have to change the HTML Source edit option to ... (at) ........ and then you can make changes. Is it possible to correct this error?
Support Team posted this 12 October 2021
Thanks for letting us know. Do you mean adding some text using Text control? Or in Post content? What CMS do you use?
Hello, Thanks for letting us know. Do you mean adding some text using Text control? Or in Post content? What CMS do you use? Sincerely, Nettie
AndrzejM
This even happens when making an HTML template
1. Add section
2. + add control text
3.asasdfasd@fsadsaf.com
4. Editing error
5. HTML SOURCE
6.change to (at)
7 .. OK ;-)
I was doing and working on a template in WORDPRESS
www.zodfregata.swinoujscie.pl/kontakt
This even happens when making an HTML template 1. Add section 2. + add control text 3.asasdfasd@fsadsaf.com 4. Editing error 5. HTML SOURCE 6.change to (at) 7 .. OK ;-) I was doing and working on a template in WORDPRESS www.zodfregata.swinoujscie.pl/kontakt
Support Team posted this 14 October 2021
I cannot reproduce the issue for any CMS. Is there any difference if you first add a Text control to the Template area, add the text with "asasdfasd@fsadsaf.com", then add a Section, drag the Text to the section?
Also - do you use Themler on your website or localhostm or Themler desktop?
Hello, I cannot reproduce the issue for any CMS. Is there any difference if you first add a Text control to the Template area, add the text with "asasdfasd@fsadsaf.com", then add a Section, drag the Text to the section? Also - do you use Themler on your website or localhostm or Themler desktop? Sincerely, Nettie
