Can I reset the article default height?
benjamin-der-friese
benjamin-der-friese posted this 21 October 2021
Can I reset the article default height for all mobile articles somewhere? Mobile homepage view cuts at 301 pixels but there is no such value in template.css and template.min.css. And in mobile/phone the text is cut off in the middle of the screen on every page. Where do I have to look? Help
I've looked the documentation but they don't cover my problem.
Why is nobody answering?
Can I reset the article default height for all mobile articles somewhere? Mobile homepage view cuts at 301 pixels but there is no such value in template.css and template.min.css. And in mobile/phone the text is cut off in the middle of the screen on every page. Where do I have to look? Help I've looked the documentation but they don't cover my problem. Why is nobody answering?
43 Comments
Support Team posted this 22 October 2021
Hello Benjamin,
Try to set Posts height to auto. If that doesn't help, please, provide the link to your page with the issue.
Hello Benjamin, Try to set Posts height to auto. If that doesn't help, please, provide the link to your page with the issue. Gina Themler Support
benjamin-der-friese
benjamin-der-friese posted this 22 October 2021
Thank you Gina, i will try that
benjamin-der-friese
I dont see where to set the articles height. I wrote you a private message.
Support Team posted this 23 October 2021
Thank you.
It seems like the height is applied from the Post Content - > Section -> Columns -> Column (1 and 2) -> More Options -> Height (400px).
Thank you. It seems like the height is applied from the Post Content - > Section -> Columns -> Column (1 and 2) -> More Options -> Height (400px). Gina Themler Support
eja.ge.r.m
eja.ge.r.m posted this 16 July 2024
To check the status of your SRD application or benefits, you typically need to visit the SASSA website or contact their helpline. You'll need your ID number and other relevant details used during your application process this website. The status check will inform you whether your application has been approved, denied, or is still under review.
To check the status of your SRD application or benefits, you typically need to visit the SASSA website or contact their helpline. You'll need your ID number and other relevant details used during your application process [this website][1]. The status check will inform you whether your application has been approved, denied, or is still under review. [1]: https://sassasrd-statuscheck.co.za/
pvcmloza
pvcmloza posted this 22 September 2024
Cross-border shipping can also serve as a platform for building a strong brand identity. Businesses that emphasize their commitment to customer service, sustainability trucking companies, and innovation in shipping can differentiate themselves in a competitive landscape. This identity should be communicated through marketing channels, customer interactions, and corporate social responsibility initiatives.
Cross-border shipping can also serve as a platform for building a strong brand identity. Businesses that emphasize their commitment to customer service, sustainability [trucking companies][1], and innovation in shipping can differentiate themselves in a competitive landscape. This identity should be communicated through marketing channels, customer interactions, and corporate social responsibility initiatives. [1]: https://roadlinx.com/
sasastatuscheck
sasastatuscheck posted this 21 October 2024
I am also looking for this to use it for my website. Is it possible?
I am also looking for this to use it for my [website][1]. Is it possible? [1]: https://sasastatuscheck.co.za/
ClementConway43
ClementConway43 posted this 21 October 2024
wow thats was good bro
penidora18
penidora18 posted this 05 November 2024
It sounds frustrating! You might want to check any JavaScript files or media queries in your CSS that handle mobile display—sometimes height limits are set there rather than in the main CSS. If you’re using a CMS, there may also be theme settings for mobile. I also faced this kind of issue but now I have figured it out you can check it on my website SASSA Status Check.
It sounds frustrating! You might want to check any JavaScript files or media queries in your CSS that handle mobile display—sometimes height limits are set there rather than in the main CSS. If you’re using a CMS, there may also be theme settings for mobile. I also faced this kind of issue but now I have figured it out you can check it on my website [SASSA Status Check][1]. [1]: https://srd-sassa-gov.co.za/
beckyricee
beckyricee posted this 23 November 2024
You can reset the default height of an article element in web development by using CSS. This can be done by setting specific height values like height: auto or min-height for flexibility. For more guidance on customizing article heights, check out https://sassa-status350.co.za/
orangesharyl
orangesharyl posted this 23 November 2024
It sounds like you're facing a frustrating issue with mobile article heights. Unfortunately, without specifics in the stylesheets, adjustments can be tricky. If only debugging were as easy as leveling up your skills in Pokerogue or exploring the realms of the Pokerogue Dex ! Have you tried reaching out to the community forums for unique solutions? They might have the answers you need.
It sounds like you're facing a frustrating issue with mobile article heights. Unfortunately, without specifics in the stylesheets, adjustments can be tricky. If only debugging were as easy as leveling up your skills in [Pokerogue][1] or exploring the realms of the [Pokerogue Dex][2] ! Have you tried reaching out to the community forums for unique solutions? They might have the answers you need. [1]: https://playpokerogue.com [2]: https://wiki.playpokerogue.com
gulubht
gulubht posted this 16 December 2024
To fix the mobile article height issue, check the mobile-specific CSS files for any height or max-height settings. Look for styles in mobile.css or media queries. If you're unsure, try the My Nsfas Status feature for better clarity on changes!
To fix the mobile article height issue, check the mobile-specific CSS files for any height or max-height settings. Look for styles in mobile.css or media queries. If you're unsure, try the [My Nsfas Status][1] feature for better clarity on changes! [1]: https://my-nsfas-status.co.za/
carparkingapk403
carparkingapk403 posted this 16 December 2024
Hello Benjamin,
i have same question
> Hello Benjamin, > > Try to set Posts height to auto. If that doesn't help, please, provide the link to your page with the issue. > > Gina > Themler Support i have same question
carparkingapk403
premiumyootubeapk.pro
> Thank you Gina, i will try that [premiumyootubeapk.pro][1] [1]: http://premiumyootubeapk.pro
janifer2030
janifer2030 posted this 27 December 2024
Worth checking any JavaScript files or CSS media queries that manage mobile display height restrictions are often defined there rather than in the main CSS. If you're using a CMS, there might also be theme settings specific to mobile. I had a similar issue, but I managed to resolve it. You can see the results on my website, SASSA Status Check.
Worth checking any JavaScript files or CSS media queries that manage mobile display height restrictions are often defined there rather than in the main CSS. If you're using a CMS, there might also be theme settings specific to mobile. I had a similar issue, but I managed to resolve it. You can see the results on my website, [SASSA Status Check.][1] [1]: https://sassa.net.za/
rckstar604
rckstar604 posted this 28 December 2024
Yes, it is possible to reset the default height of an article, depending on the context. For example, if you are working on a webpage, you can use CSS to adjust the height by setting it to "auto," which resets it to the default behavior. This can be done using a simple CSS rule, such as article { height: auto; }. However, if you are working within a specific platform or software, the method for resetting the height may vary. Providing more details about your specific context would help in offering a more tailored solution. Burger King Menu with Prices
Yes, it is possible to reset the default height of an article, depending on the context. For example, if you are working on a webpage, you can use CSS to adjust the height by setting it to "auto," which resets it to the default behavior. This can be done using a simple CSS rule, such as article { height: auto; }. However, if you are working within a specific platform or software, the method for resetting the height may vary. Providing more details about your specific context would help in offering a more tailored solution. [Burger King Menu with Prices][1] [1]: https://samenuprice.co.za/burger-king-menu-prices/
sasastatuscheck
sasastatuscheck posted this 19 February 2025
For those people who are looking for a tool to Check sasa350 Status free, you might visit the given link.
For those people who are looking for a tool to Check [sasa350][1] Status free, you might visit the given link. [1]: https://sasastatuscheck.co.za/
hazalmalik997
hazalmalik997 posted this 02 March 2025
I'm looking for this as well to use on my website. Is it possible? تنزيل واتساب
I'm looking for this as well to use on my website. Is it possible? [تنزيل واتساب][1] [1]: https://watsagold.net/
coloured.spoonbill.aoxd
coloured.spoonbill.aoxd posted this 05 March 2025
Hey! Check your theme's mobile-specific CSS, likely overridden somewhere. Look beyond template.css, maybe a custom CSS file or plugin settings. Have you tried using browser's developer tools to inspect the element and pinpoint where the height is defined? This sounds like a fun puzzle, almost like figuring out how to get "Life" in Infinite Craft to finally build something new! Keep us updated, others might have the same issue.
Hey! Check your theme's mobile-specific CSS, likely overridden somewhere. Look beyond template.css, maybe a custom CSS file or plugin settings. Have you tried using browser's developer tools to inspect the element and pinpoint where the height is defined? This sounds like a fun puzzle, almost like figuring out how to get "Life" in [Infinite Craft](https://infinitecrafts.io) to finally build something new! Keep us updated, others might have the same issue.
fannytomy9
fannytomy9 posted this 05 March 2025
You can try adding custom CSS to adjust the article height on mobile. Use media queries to target mobile screens and set min-height and height properties. Also, sprunki check your template settings and ensure there are no JavaScript issues.
You can try adding custom CSS to adjust the article height on mobile. Use media queries to target mobile screens and set `min-height` and `height` properties. Also, [sprunki][1] check your template settings and ensure there are no JavaScript issues. [1]: https://sprunki.today
