error saving in themler
Sifone Company
Sifone Company posted this 26 October 2021
From the website https://tp4u.com.co/feria-virtual/ it is not possible to save the changes to the template that we make from Themler, when clicking on save the text "saving ..."
11 Comments
Support Team posted this 26 October 2021
Please try the following:
1) Open this URL in Chrome:
chrome://appcache-internals
2) Open this URL in Chrome:
Hello, Please try the following: 1) Open this URL in Chrome: chrome://appcache-internals find your website and click on 'Remove Item' 2) Open this URL in Chrome: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. Sincerely, Nettie
Sifone Company
Hello !
We carry out the steps indicated more, however the error persists. It stays saving ...
We remain attentive to your orientation
Hello ! We carry out the steps indicated more, however the error persists. It stays saving ... We remain attentive to your orientation
Support Team posted this 27 October 2021
If you copy the theme via FTP, zip-compress it and import in Themler desktop, can you change it there and save changes? Also - when saving the theme on your website, what is the error message shown in F12 >> Console?
Hello, If you copy the theme via FTP, zip-compress it and import in Themler desktop, can you change it there and save changes? Also - when saving the theme on your website, what is the error message shown in F12 >> Console? Sincerely, Nettie
Sifone Company
Sifone Company posted this 22 December 2021
Hello. We tried to import a section on the home page but the following error appeared:
template is missing. standalone themes need to have a index.php template file . Child themes need to have a template header in the style.css stylesheet! enter image description here
Hello. We tried to import a section on the home page but the following error appeared: template is missing. standalone themes need to have a index.php template file . Child themes need to have a template header in the style.css stylesheet! [enter image description here][1] [1]: https://ibb.co/YTsnZz0
Support Team posted this 22 December 2021
Have you previously downloaded the section from templates.themler.io? If so, this is a separate HTML and cannot imported into a theme, only opened as HTML theme or website. Please try importing the section directly from the Insert tab >> Section >> From Library (consider finding the theme by ID).
Hello, Have you previously downloaded the section from templates.themler.io? If so, this is a separate HTML and cannot imported into a theme, only opened as HTML theme or website. Please try importing the section directly from the Insert tab >> Section >> From Library (consider finding the theme by ID). Sincerely, Nettie
Sifone Company
Perform the indicated but the error persists. When saving some setting, it keeps saving ... it never saves and the error related to the previous comment appears.
Support Team posted this 24 December 2021
For Themler on the hosted website please follow these steps:
For Themler Desktop please try the following:
1) close Themler
4) start Themler again
Hello, For Themler on the hosted website please follow these steps: 1) Open this URL in Chrome: chrome://appcache-internals find your website and click on 'Remove Item' 2) Open this URL in Chrome: chrome://settings/clearBrowserData select 'Cached images and files ' and click on 'Clear Data' (please don't check other check-boxes). 3) Reload your Themler Editor. For Themler Desktop please try the following: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Sincerely, Nettie
studwork1742
studwork1742 posted this 11 January 2026
Estava procurando algo simples para ocupar alguns momentos livres do dia. Um casino online pareceu adequado. Escolhi spinmacho casino e achei tudo bem explicado. As ofertas para Portugal incluem bónus normais e promoções ocasionais. No geral, foi tranquilo.
Estava procurando algo simples para ocupar alguns momentos livres do dia. Um casino online pareceu adequado. Escolhi [spinmacho casino][1] e achei tudo bem explicado. As ofertas para Portugal incluem bónus normais e promoções ocasionais. No geral, foi tranquilo. [1]: https://spinmacho.com.pt
chinahousehold
chinahousehold posted this 14 January 2026
https://cinderella.pro/user/255178/
https://www.bizmaker.org/new-york/energy-utilities/homesun
https://www.myvidster.com/profile/homesunsolar
https://paa.ge/hssolar
https://yamap.com/users/5023715
https://dto.to/u/3320122-chinabamboo
https://bothbest.gitbook.io/bothbest-docs
https://www.faceparty.com/bothbest
https://sdelai.ru/members/flooring/
https://aetherlink.app/users/7416726579247874048
http://jobhop.co.uk/blog/bothbest/top-10-reasons-builders-prefer-fsc-certified-bamboo-materials
https://bambooflooring.alboompro.com/post/why-strand-woven-bamboo-flooring-is-stronger-than-hardwood
https://ead.pge.rs.gov.br/tag/index.php?tc=1&tag=chinabamboo
https://arizonaadam.com/forum/topic/how-engineered-bamboo-flooring-delivers-stability-in-any-climate/
https://naya.com.np/post/p1768292805tc2t4
https://www.xcspa.com/outdoor-bamboo-decking-installation-tips-every-builder-should-know/
https://www.cssauw.org/forum/thread-41102-1-1
https://www.prosebox.net/book/97073/
https://ameblo.jp/japanbamboo/entry-12953302636.html
https://divekeeper.com/forums/discussion/general-discussion/bamboo-plywood-applications-furniture-cabinetry-and-more
https://kumu.io/bothbest/strand-woven-bamboo-for-pet-friendly-homes-scratch-and-dent-resistance
https://bothbest.multipass.com/mp/eventDetail/3207
https://forumtransportu.pl/forum/temat/27510
https://www.hssolar.cn/news-39.html
https://hssolar.tawk.help/article/bamboo-flooring-for-allergies-a-healthier-indoor-choice
https://cinderella.pro/user/255178/ https://www.bizmaker.org/new-york/energy-utilities/homesun https://www.myvidster.com/profile/homesunsolar https://paa.ge/hssolar https://yamap.com/users/5023715 https://dto.to/u/3320122-chinabamboo https://bothbest.gitbook.io/bothbest-docs https://www.faceparty.com/bothbest https://sdelai.ru/members/flooring/ https://aetherlink.app/users/7416726579247874048 http://jobhop.co.uk/blog/bothbest/top-10-reasons-builders-prefer-fsc-certified-bamboo-materials https://bambooflooring.alboompro.com/post/why-strand-woven-bamboo-flooring-is-stronger-than-hardwood https://ead.pge.rs.gov.br/tag/index.php?tc=1&tag=chinabamboo https://arizonaadam.com/forum/topic/how-engineered-bamboo-flooring-delivers-stability-in-any-climate/ https://naya.com.np/post/p1768292805tc2t4 https://www.xcspa.com/outdoor-bamboo-decking-installation-tips-every-builder-should-know/ https://www.cssauw.org/forum/thread-41102-1-1 https://www.prosebox.net/book/97073/ https://ameblo.jp/japanbamboo/entry-12953302636.html https://divekeeper.com/forums/discussion/general-discussion/bamboo-plywood-applications-furniture-cabinetry-and-more https://kumu.io/bothbest/strand-woven-bamboo-for-pet-friendly-homes-scratch-and-dent-resistance https://bothbest.multipass.com/mp/eventDetail/3207 https://forumtransportu.pl/forum/temat/27510 https://www.hssolar.cn/news-39.html https://hssolar.tawk.help/article/bamboo-flooring-for-allergies-a-healthier-indoor-choice
emmaroberts6231
emmaroberts6231 posted this 26 January 2026
The upgraded spoiler adds stability and enhances the sleek interface appeal survival race.
The upgraded spoiler adds stability and enhances the sleek interface appeal [survival race][1]. [1]: https://survival-race.io
muskrika
muskrika posted this 21 April 2026
The Piattelli Vineyards sustainability initiative is a great example of how tradition and innovation can coexist. By investing in renewable energy, water conservation, and eco‑friendly practices, they show that the wine industry can thrive while protecting the environment. I think this sets a positive precedent for other businesses aiming to balance growth with responsibility.
When I want to switch gears from thoughtful reading to something playful, I enjoy Slope game. Its fast pace and unpredictability make it a refreshing way to reset.
The Piattelli Vineyards sustainability initiative is a great example of how tradition and innovation can coexist. By investing in renewable energy, water conservation, and eco‑friendly practices, they show that the wine industry can thrive while protecting the environment. I think this sets a positive precedent for other businesses aiming to balance growth with responsibility. When I want to switch gears from thoughtful reading to something playful, I enjoy [Slope game](https://slopegameaz.io). Its fast pace and unpredictability make it a refreshing way to reset.
