Joomla 4 support is available in Beta
Support Team posted this 15 November 2021
Good news! We have added support for Joomla 4 in Beta mode. To try Themler for Joomla 4, please follow the steps below:
  1. Download the default Themler theme for Joomla 4.
  2. Install it in your Joomla from Joomla admin >> Install >> Extensions.
3. Go to System >> Templates >> Site Template Styles and activate the theme by clicking the star next to the theme name.
  1. Click on the template name there (untitled) and click on the "Edit Template" button.
Please note that Joomla 4 support is in Beta and thus minor issues are possible.
Note: Once the theme is loaded, you may need to update it to the latest Themler Beta version available, by clicking on "Updates (1)" notification* on the top. Please enable Beta update notifications in your Profile for this.
If there is no notification, you have the latest version - currently it is v.544.
Good news! We have added support for Joomla 4 in Beta mode. To try Themler for Joomla 4, please follow the steps below: 1. [Download][1] the default Themler theme for Joomla 4. 2. Install it in your Joomla from **Joomla admin** >> **Install** >> **Extensions**. !joomla4-1.png! 3. Go to **System** >> **Templates** >> **Site Template Styles** and activate the theme by clicking the star next to the theme name. !joomla4-2.png! 4. Click on the template name there (*untitled*) and click on the "Edit Template" button. !joomla4-3.png! Please note that Joomla 4 support is in Beta and thus minor issues are possible. Note: Once the theme is loaded, you may need to update it to the latest Themler Beta version available, by clicking on **"Updates (1)"** notification* on the top. Please enable Beta update notifications in your Profile for this. If there is no notification, you have the latest version - currently it is v.544. [1]: https://themler.io/Download/Joomla4
149 Comments
Scorpion Computers & Software
Scorpion Computers & Software posted this 07 December 2021
I am allready pleased to sea improvement and a Joomla4 compatible version. I also have more then 40 websites, but i am not going to rebuild them all. We have time because Joomla! 3 is not totaly end of life.
I am testing version 4 of the themler template. I changed some stuff and the base worked.
Now i have changed the name of the template and the only thing i get now is "NOT FOUND"
So i uninstalled it and installed it again. But now even the default themplate is not showing anymore. Do you have a fix for me
I am allready pleased to sea improvement and a Joomla4 compatible version. I also have more then 40 websites, but i am not going to rebuild them all. We have time because Joomla! 3 is not totaly end of life. I am testing version 4 of the themler template. I changed some stuff and the base worked. Now i have changed the name of the template and the only thing i get now is "NOT FOUND" So i uninstalled it and installed it again. But now even the default themplate is not showing anymore. Do you have a fix for me
matrix630307
matrix630307 posted this 08 December 2021
Since any weeks the beta 544 is still online. since this time, no work from themler at the beta. Good luck!
> I am allready pleased to sea improvement and a Joomla4 compatible version. I also have more then 40 websites, but i am not going to rebuild them all. We have time because Joomla! 3 is not totaly end of life. > > I am testing version 4 of the themler template. I changed some stuff and the base worked. > Now i have changed the name of the template and the only thing i get now is "NOT FOUND" > > So i uninstalled it and installed it again. But now even the default themplate is not showing anymore. Do you have a fix for me Hi Since any weeks the beta 544 is still online. since this time, no work from themler at the beta. Good luck!
Vitaliy WD
Vitaliy WD posted this 08 December 2021
Since its first beta releases we started adjusting different parts of
[software_name] to make the final implementation as smooth as
possible. And today with [software_name] you can upgrade to Joomla 4
with just a click. Everything in [software_name] will work like a
charm.
This is a quote from one of other template builder. As you can see, they started preparing early and now suggest fast upgrade from Joomla 3 to Joomla 4 with one click.
Meanwhile Themler don't offer Joomla 3 to Joomla 4 upgrade at all. Moreover, Joomla 4 support still not ready... while first beta of Joomla 4 was more than 1 year ago. So you can just guess how many years they need to make stable Joomla 4 theme :)
I'm loyal users since Artisteer... but today situations with this company is... I can't find right words... Just very sad ending of BillionDigital (Artisteer, Themler, uPage, Nicepage or how they called now).
> Since its first beta releases we started adjusting different parts of > [software_name] to make the final implementation as smooth as > possible. And today with [software_name] you can upgrade to Joomla 4 > with just a click. Everything in [software_name] will work like a > charm. This is a quote from one of other template builder. As you can see, they started preparing early and now suggest fast upgrade from Joomla 3 to Joomla 4 with one click. Meanwhile Themler don't offer Joomla 3 to Joomla 4 upgrade at all. Moreover, Joomla 4 support still not ready... while first beta of Joomla 4 was more than 1 year ago. So you can just guess how many years they need to make stable Joomla 4 theme :) I'm loyal users since Artisteer... but today situations with this company is... I can't find right words... Just very sad ending of BillionDigital (Artisteer, Themler, uPage, Nicepage or how they called now).
matrix630307
charm.
absolutely right everything! for days now I've been working on making templates with a different framework. Hopefully themler will still do joomla 3 with php 8. but there won't be anything more correct ...
> > Since its first beta releases we started adjusting different parts of > > [software_name] to make the final implementation as smooth as > > possible. And today with [software_name] you can upgrade to Joomla 4 > > with just a click. Everything in [software_name] will work like a > > charm. > > This is a quote from one of other template builder. As you can see, they started preparing early and now suggest fast upgrade from Joomla 3 to Joomla 4 with one click. > > Meanwhile Themler don't offer Joomla 3 to Joomla 4 upgrade at all. Moreover, Joomla 4 support still not ready... while first beta of Joomla 4 was more than 1 year ago. So you can just guess how many years they need to make stable Joomla 4 theme :) > > I'm loyal users since Artisteer... but today situations with this company is... I can't find right words... Just very sad ending of BillionDigital (Artisteer, Themler, uPage, Nicepage or how they called now). absolutely right everything! for days now I've been working on making templates with a different framework. Hopefully themler will still do joomla 3 with php 8. but there won't be anything more correct ...
pdg.design
pdg.design posted this 08 December 2021
I hope, support team read our post, and they transfer to developers our questions,
DaveOzric
DaveOzric posted this 08 December 2021
LOL
> I hope, support team read our post, and they transfer to developers our questions, LOL
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 08 December 2021
For me it will be the last cycle with Themler. As I said, I renewed my subscription for another year. If nothing changes, I'll be gone with my company.
I tried Nicepage, but it's not what I need. Therefore the subscription was no longer extended.
For me it will be the last cycle with Themler. As I said, I renewed my subscription for another year. If nothing changes, I'll be gone with my company. I tried Nicepage, but it's not what I need. Therefore the subscription was no longer extended.
matrix630307
With nicepage is not good work. A made the changes now with another Framework - yes, a little bit with selfmade css. but, no chance with themler for the future...
> For me it will be the last cycle with Themler. As I said, I renewed my subscription for another year. If nothing changes, I'll be gone with my company. > > I tried Nicepage, but it's not what I need. Therefore the subscription was no longer extended. With nicepage is not good work. A made the changes now with another Framework - yes, a little bit with selfmade css. but, no chance with themler for the future...
Support Team posted this 10 December 2021
Thank you all for your feedback. Just for your information - we do indeed check each reported issue about Joomla 4 theme and after the issue is confirmed forward them to developers for fixing. Sometimes additional investigation is needed, so this happens not immediately.
We thank everyone for reporting the issues found in Beta theme version and assure that we work at fixing them as well.
Hello, Thank you all for your feedback. Just for your information - we do indeed check each reported issue about Joomla 4 theme and after the issue is confirmed forward them to developers for fixing. Sometimes additional investigation is needed, so this happens not immediately. We thank everyone for reporting the issues found in Beta theme version and assure that we work at fixing them as well. Sincerely, Nettie
pdg.design
pdg.design posted this 10 December 2021
Hi, Nettie.
Thank you.
Any timetable for next versions of Themler?
Hi, Nettie. Thank you. Any timetable for next versions of Themler?
matrix630307
matrix630307 posted this 10 December 2021
Wow - great News!!
But since x weeks is only Version 544 online - no further version with bug-fixes. I have made alone 5 bug fixes for weeks...
Wow - great News!! But since x weeks is only Version 544 online - no further version with bug-fixes. I have made alone 5 bug fixes for weeks...
Sinergia Innovaciones
Sinergia Innovaciones posted this 23 December 2021
Hi, I installed the beta version of Joomla 4 but when I enter in Styles of the site template I get this error. I uninstalled, downloaded again and reinstalled, but still the same error. Maybe you can help me.
Hi, I installed the beta version of Joomla 4 but when I enter in Styles of the site template I get this error. I uninstalled, downloaded again and reinstalled, but still the same error. Maybe you can help me. Thanks
matrix630307
matrix630307 posted this 23 December 2021
Hi - read this (or other thread's) - themler only rips off customers. there will no longer be a properly functioning version.
> Hi, I installed the beta version of Joomla 4 but when I enter in Styles of the site template I get this error. I uninstalled, downloaded again and reinstalled, but still the same error. Maybe you can help me. > Thanks Hi - read this (or other thread's) - themler only rips off customers. there will no longer be a properly functioning version.
Support Team posted this 24 December 2021
Sinergia Innovaciones,
We have answered in your separate topic. Also we assure you that all issues found by now are in work and the version with the fixes is expected in the new year.
**Sinergia Innovaciones**, We have answered in your separate topic. Also we assure you that all issues found by now are in work and the version with the fixes is expected in the new year. Sincerely, Nettie
pdg.design
pdg.design posted this 24 December 2021
Hi, Nettie.
So, we can to wait fixed version in January?
Thank you.
Hi, Nettie. So, we can to wait fixed version in January? Thank you.
kverweij
kverweij posted this 17 January 2022
Please add the option to upgrade from joomla 3.x to 4. I am not going to rebuild my old themes.
Please add the option to upgrade from joomla 3.x to 4. I am not going to rebuild my old themes. Thanks
pdg.design
pdg.design posted this 19 January 2022
Hi support?
That new in new BET from today?
Hi support? That new in new BET from today?
Support Team posted this 19 January 2022
The login issue with Firefox and sometimes Chrome is fixed, as well as the issue with applying sections from the library.
Hello, The login issue with Firefox and sometimes Chrome is fixed, as well as the issue with applying sections from the library. Sincerely, Nettie
pdg.design
Thank you Nettie.
Still to wait version for J4.
It may be this month?
Thank you Nettie. Still to wait version for J4. It may be this month?
Peter L.
Peter L. posted this 22 January 2022
Hi there, - I hope there will be a way to update Jommla 3.X templates to Joomla 4.X. I maintain many Joomla installations. All of them are created with templates from Themler. Without the possibility to upgrade these templates to Joomla 4 another membership would not make sense for me anymore and I would not renew my membership. However, I really hope that you will find a way to upgrade Joomla 3 templates. Hopeful greetings - Peter
