404 error on Themler for Joomla 4
eleanor
eleanor posted this 23 November 2021
Hi there, I started creating a template in the Themler for joomla 4. I saved and exited and on going back in I now am just getting a "404 Not Found The resource requested could not be found on this server" message, even though the front of my site is using the template! Are you able to advise what the problem might be, and how I can go about fixing it? Thanks very much!
8 Comments
Support Team posted this 23 November 2021
What are steps to reproduce the issue? For example, have you added a menu? Please try to mark a menu item as Home page in Joomla admin and Refresh Content in Themler. Then click on some other pages and come back to the Home page. Is there any difference?
Hello, What are steps to reproduce the issue? For example, have you added a menu? Please try to mark a menu item as Home page in Joomla admin and Refresh Content in Themler. Then click on some other pages and come back to the Home page. Is there any difference? Sincerely, Nettie
heikom
heikom posted this 23 November 2021
I have on beta the same problem. I resolve it with the themler (not browser) refreh function some times and choose blog/post/default site in the dropdown field.
There more bugs in the beta - if you select a blog layout from templates from web, then you get an php error (i use php 7.4 and cant change the version).
I have on beta the same problem. I resolve it with the themler (not browser) refreh function some times and choose blog/post/default site in the dropdown field. There more bugs in the beta - if you select a blog layout from templates from web, then you get an php error (i use php 7.4 and cant change the version).
eleanor
Thank you this appears to have resolved it :)
> I have on beta the same problem. I resolve it with the themler (not browser) refreh function some times and choose blog/post/default site in the dropdown field. > There more bugs in the beta - if you select a blog layout from templates from web, then you get an php error (i use php 7.4 and cant change the version). > Thank you this appears to have resolved it :)
Thank you for sharing the solution. For Joomla 4 PHP 8 is recommended on their website. The issue is not reproducible for me with PHP 8. If it is for you, then please let us know, the issue must be in anything different.
Hello, Thank you for sharing the solution. For Joomla 4 PHP 8 is recommended on their website. The issue is not reproducible for me with PHP 8. If it is for you, then please let us know, the issue must be in anything different. Sincerely, Nettie
GCK
GCK posted this 04 January 2022
I have the same issue. I notice the section Pages & Posts is collapsed initially. If I click through the tabs Edit, Insert, Design, and back to Home the Pages and Posts Selection Expands. The 404 Error is still displayed until I click on Home. Then the template appears.
pdg.design
pdg.design posted this 05 January 2022
GCK - its a known bug in Beta,
After you enter to Themler in live site - you see 404,
You need to refresh templates on the themler panel, and after this you can to over to any template.
**GCK** - its a known bug in Beta, After you enter to Themler in live site - you see 404, You need to refresh templates on the themler panel, and after this you can to over to any template.
pdg.design
Click here
Click here
![Click here][1] [1]: https://forumattachments.themler.io/450/46450/404.jpg Click here
alexarafatonline
alexarafatonline posted this 19 September 2025
I had a similar issue with Themler when I was creating a template for Joomla 4. After saving and exiting, I encountered a "404 Not Found" error too. It seems like the template file path may have been altered or there's an issue with the server's routing. To fix it, try clearing the Joomla cache, checking the template settings, or even re-saving the template to make sure all links are correct. It took me some time to figure it out, but once I adjusted the file paths, everything worked fine. Make sure you’re also saving everything properly before exiting.
I had a similar issue with Themler when I was creating a template for Joomla 4. After saving and exiting, I encountered a "404 Not Found" error too. It seems like the template file path may have been altered or there's an issue with the server's routing. To fix it, try clearing the Joomla cache, checking the template settings, or even re-saving the template to make sure all links are correct. It took me some [time][1] to figure it out, but once I adjusted the file paths, everything worked fine. Make sure you’re also saving everything properly before exiting. [1]: https://calculatoradam.com/time/
