This is the error after select a blog from template library.
How can i fix it?
Joomla 4
themler for joomla 4 beta, v544
php7.4
This is the error after select a blog from template library. How can i fix it? Joomla 4 themler for joomla 4 beta, v544 php7.4 > require_once(): Failed opening required '/var/customers/webs/netpoint71/spielmannszug-biedenkopf.de/components/com_content/models/article.php' (include_path='.:/usr/share/php/:/usr/share/php5/') - Joomla4require_once(): Failed opening required
