Themler for Joomla 4 bugs
pdg.design
pdg.design posted this 6 days ago
Dear friends.
I suggest posting a list of bugs here in Themler for Joomla 4.
So.
1, I find a double header from module menu in left sidebar in Joomla position "left".
I don't know how to remove it.
2. Then I try to ad Right sidebar - missing Right Joomla position and i can not to ad it.
Please see a video.
https://youtu.be/HdI6SSos53w
  1. Themler work with Joomla 4 in PHP8, but menu item Blog Category, List of tags and, I think menu of any Component not work I get error: 0 - 2 arguments are required, 1 given
Any solution?
Thank you!
Dear friends. I suggest posting a list of bugs here in Themler for Joomla 4. So. 1, I find a double header from module menu in left sidebar in Joomla position "left". I don't know how to remove it. 2. Then I try to ad Right sidebar - missing Right Joomla position and i can not to ad it. Please see a video. https://youtu.be/HdI6SSos53w ------------ 3. Themler work with Joomla 4 in PHP8, but menu item **Blog Category, List of tags** and, I think menu of any Component not work I get error: **0 - 2 arguments are required, 1 given** Any solution? Thank you!
Support Team posted this 5 days ago
Thank you for reporting the issues.
1. I couldn't reproduce the issue with the module header. It appears only once. Could you please specify the steps to reproduce it or attach the theme?
2. This issue is already reported to developers and is under investigation.
3. I see that you opened a separate topic for this issue with the detailed description, so we will continue communication on it there.
Hello, Thank you for reporting the issues. 1. I couldn't reproduce the issue with the module header. It appears only once. Could you please specify the steps to reproduce it or attach the theme? 2. This issue is already reported to developers and is under investigation. 3. I see that you opened a separate topic for this issue with the detailed description, so we will continue communication on it there. Sincerely, Nettie
pdg.design
pdg.design posted this 5 days ago
Hi, Nettie.
I find a solution.
We are need to set Module Style to block, and it work property.
But I find new issue. Then I open Themler to edit any template I get error, please see attach file error-bootst.jpg
And you need to fix issue wit Right side bar- Joomla position.
Thank you.
Hi, Nettie. I find a solution. We are need to set Module Style to block, and it work property. But I find new issue. Then I open Themler to edit any template I get error, please see attach file **error-bootst.jpg** And you need to fix issue wit Right side bar- Joomla position. Thank you.
