I'm really liking Themler and how easy it is to use. I believe that it has a very bright future and that a lot of web designers and coders may be faced with a challenge. However, I have a question. After you create a simple site using themler, and after you upload to wordpress, how friendly is it with SEO?
The reason I ask is because I'm going to be creating a magazine-type of layout and I don't want bulky-code. I want the site to be super fast.
So basically, can someone explain if themler uses GZIP compression and minifies CSS and Javascript? Does it produce extra CSS?
I'm really liking Themler and how easy it is to use. I believe that it has a very bright future and that a lot of web designers and coders may be faced with a challenge. However, I have a question. After you create a simple site using themler, and after you upload to wordpress, how friendly is it with SEO? The reason I ask is because I'm going to be creating a magazine-type of layout and I don't want bulky-code. I want the site to be super fast. So basically, can someone explain if themler uses GZIP compression and minifies CSS and Javascript? Does it produce extra CSS?Last edited 19 August 2015 by isaiahparadis528
