Can not to edit template -"Edit Template" button is disable
pdg.design
pdg.design posted this 09 December 2021
Hi!
New issue in Themler for Joomla 4.
If I install second template for the site, I can not to edit it, button Edit template is not active. First template is Ok,
Tested by Joomla 4, Php 7.4
Here is a video.
https://youtu.be/ZLakJ0d_hBo
Firstly was installed template "untitled", created template and import it as RussianAllo.ZIP and HebrewAllo.ZIP
After this I installed 2 this templates - RussianAllo and HebrewAllo.
"untitled" - I can to edit, but RussianAllo and HebrewAllo - "Edit Template" button is disable.
It was tetsed on few sites
Please, help me,
Thank you.
Hi! New issue in Themler for Joomla 4. If I install second template for the site, I can not to edit it, button Edit template is not active. First template is Ok, Tested by Joomla 4, Php 7.4 Here is a video. https://youtu.be/ZLakJ0d_hBo Firstly was installed template "untitled", created template and import it as RussianAllo.ZIP and HebrewAllo.ZIP After this I installed 2 this templates - RussianAllo and HebrewAllo. "untitled" - I can to edit, but RussianAllo and HebrewAllo - "Edit Template" button is disable. It was tetsed on few sites Please, help me, Thank you.
10 Comments
pdg.design
pdg.design posted this 10 December 2021
Anybody here?
Anybody here?
Support Team posted this 10 December 2021
Thank you for reporting the issues and for the video. The other two themes were previously modified and exported, right? Did you try the same with PHP 8?
Hello, Thank you for reporting the issues and for the video. The other two themes were previously modified and exported, right? Did you try the same with PHP 8? Sincerely, Nettie
pdg.design
Hi Nettie.
Yes, i created template with name "untitled". After this I exported it as ZIP (its a must to be template for RTL version of the site) and installed it as a second template, "Edit Template" button is disable.
Hi Nettie. Yes, i created template with name "untitled". After this I exported it as ZIP (its a must to be template for RTL version of the site) and installed it as a second template, "Edit Template" button is disable.
pdg.design
Checked now in PHP 8 - "Edit Template" button is disable,
Support Team posted this 15 December 2021
Sorry for delay. Indeed, for all themes except for the first one Edit Template button is disabled, this issue should be fixed and is forwarded to developers.
Hello, Sorry for delay. Indeed, for all themes except for the first one Edit Template button is disabled, this issue should be fixed and is forwarded to developers. Sincerely, Nettie
pdg.design
pdg.design posted this 15 December 2021
Thank you, Nettie,
Thank you, Nettie,
pvcmloza
pvcmloza posted this 30 June 2025
Hi! It sounds like a known issue where Themler for Joomla 4 disables the "Edit Template" button for imported or secondary templates. Meanwhile, you can try using PowerDirector APK to create tutorial videos explaining your workflow and issues clearly for support teams or forums. Also, ensure your Joomla and PHP versions are fully compatible with your Themler templates Free access here, and check for updates or patches from Themler that might fix this bug. Hope this helps!
Hi! It sounds like a known issue where Themler for Joomla 4 disables the "Edit Template" button for imported or secondary templates. Meanwhile, you can try using PowerDirector APK to create tutorial videos explaining your workflow and issues clearly for support teams or forums. Also, ensure your Joomla and PHP versions are fully compatible with your Themler templates [Free access here][1], and check for updates or patches from Themler that might fix this bug. Hope this helps! [1]: https://powerdirectormodapk.com/
should0258
should0258 posted this 01 July 2025
Ugh, this Themler bug is really starting to drive me mad! Hopefully, they fix it soon. I'm glad they at least acknowledged it. Trying to get things done when the 'Edit Template' button is disabled is like trying to drive a car with square wheels!
Ugh, this Themler bug is really starting to [drive me mad!][1] Hopefully, they fix it soon. I'm glad they at least acknowledged it. Trying to get things done when the 'Edit Template' button is disabled is like trying to drive a car with square wheels! [1]: https://drivemadgame.pro/en/game/driver-master-simulator
gargi
gargi posted this 01 July 2025
I faced a similar issue a while ago where the "Edit Template" button was disabled, and it turned out to be a problem with the theme's compatibility and local cache. Make sure you've cleared your browser cache and also check if your Themler version is fully updated. Additionally, I recommend using a CRM tool to manage and track such technical issues and customer queries. We've been using OutRight CRM in our team for managing templates and support tickets — it's helped streamline our workflow a lot. Hope this helps!
I faced a similar issue a while ago where the "Edit Template" button was disabled, and it turned out to be a problem with the theme's compatibility and local cache. Make sure you've cleared your browser cache and also check if your Themler version is fully updated. Additionally, I recommend using a [CRM tool][1] to manage and track such technical issues and customer queries. We've been using OutRight CRM in our team for managing templates and support tickets — it's helped streamline our workflow a lot. Hope this helps! [1]: https://www.outrightcrm.com/
alimrank318
alimrank318 posted this 07 October 2025
I ran into the same problem when Themler disabled the “Edit Template” button for imported templates.
Clearing cache and re-importing the theme didn’t help much, but I found a helpful guide that walks through practical fixes and customization tips.
You can check it here: Whataburger Breakfast Menu
It’s not just about menus — it also shows how to structure and manage layouts more effectively in site builders like Themler.
Hope this helps anyone still stuck with this issue!
I ran into the same problem when Themler disabled the “Edit Template” button for imported templates. Clearing cache and re-importing the theme didn’t help much, but I found a helpful guide that walks through practical fixes and customization tips. You can check it here: [Whataburger Breakfast Menu](https://whtaburgermenu.com/whataburger-breakfast-menu/) It’s not just about menus — it also shows how to structure and manage layouts more effectively in site builders like Themler. Hope this helps anyone still stuck with this issue!
