Error "0 - Unknown named parameter $title"
Pulswerk
Pulswerk posted this 14 December 2021
Dear developers,
out of nothing, I am getting an error with one of my webpages running a Themler Theme:
When I try to edit the theme in the backend, it says:
Too few arguments to function errorHandlerExportTheme(), 4 passed and exactly 5 expected
The site in question can be found here: https://www.ford-schmid.de/
Any idea what's going on here?
Dan
Dear developers, out of nothing, I am getting an error with one of my webpages running a Themler Theme: > 0 - Unknown named parameter $title When I try to edit the theme in the backend, it says: > Too few arguments to function errorHandlerExportTheme(), 4 passed and exactly 5 expected The site in question can be found here: https://www.ford-schmid.de/ Any idea what's going on here? Sincerely, Dan
31 Comments
Support Team posted this 14 December 2021
Have you updated Themler, Joomla version or PHP? Or possibly you have enabled any third-party plugin, component or module?
Hello, Have you updated Themler, Joomla version or PHP? Or possibly you have enabled any third-party plugin, component or module? Sincerely, Nettie
Pulswerk
PHP was the troublemaker. Themler templates are not compatible with PHP 8.0. Are there any plans to change this in the future?
Vitaliy WD
Vitaliy WD posted this 14 December 2021
Meanwhile PHP 8.1 released and supported by Joomla 4.0.5. PHP 8.1 have Performance Improvements. But it's nothing compared with old Bootstrap 3 that need to load separately with Themler, while Joomla 4 and fresh extensions load new Bootstrap 5.
Meanwhile PHP 8.1 released and [supported by Joomla 4.0.5][1]. PHP 8.1 have [Performance Improvements][2]. But it's nothing compared with old Bootstrap 3 that need to load separately with Themler, while Joomla 4 and fresh extensions load new Bootstrap 5. [1]: https://www.joomla.org/announcements/release-news/5851-joomla-4-0-5-and-joomla-3-10-4-are-here.html [2]: https://www.php.net/releases/8.1/en.php
I see. Indeed, the issue with Joomla 3 and PHP 8 is reported to our developers. Meanwhile please consider using an older PHP version like the latest versions of 7.x.
Themler theme for Joomla 4 supports PHP 8 (it is the recommended PHP version for Joomla 4). However, please note that the theme is still in Beta and therefore there are some issues reported to developers or under investigation - that need fixing.
Hello, I see. Indeed, the issue with Joomla 3 and PHP 8 is reported to our developers. Meanwhile please consider using an older PHP version like the latest versions of 7.x. Themler theme for Joomla 4 supports PHP 8 (it is the recommended PHP version for Joomla 4). However, please note that the theme is still in Beta and therefore there are some issues reported to developers or under investigation - that need fixing. Sincerely, Nettie
pdg.design
pdg.design posted this 14 December 2021
Nettie, please answer us - that's a timetable for next version of Themler for Joomla 4?
We are still to wait it..
Its may to be this month?
Thank you.
**Nettie**, please answer us - that's a timetable for next version of Themler for Joomla 4? We are still to wait it.. Its may to be this month? Thank you.
Support Team posted this 20 December 2021
The version with the fixes will most probably be out already in the new year.
Hello, The version with the fixes will most probably be out already in the new year. Sincerely, Nettie
ABSolutions
ABSolutions posted this 15 February 2022
Any update on this one?
AB
Any update on this one? AB
Medienagentur
Medienagentur posted this 06 September 2022
Hello Nettie, I updated today from php 7.4 to 8.0 and get still the above decribed error "0 - Unknown named parameter $title" with JOOMLA 3.10.11., when I use the login module of Joomla. Editing the theme works. The support of 7.4 ends in 3 month. When can we reckon with an update for Joomla 3 for that issue?
Support Team posted this 06 September 2022
Medienagentur,
Could you please create a new private topic and provide there temporary access to your website for investigation? The issue is not reproducible in a stable way, so we need to look closer at the issue.
**Medienagentur**, Could you please create a new private topic and provide there temporary access to your website for investigation? The issue is not reproducible in a stable way, so we need to look closer at the issue. Sincerely, Nettie
Medienagentur
Medienagentur posted this 08 September 2022
Thank you Nettie, I will do this.
Sincerly, Udo
Thank you Nettie, I will do this. Sincerly, Udo
peterdejong
peterdejong posted this 15 December 2022
Is there an update on this?
Any fix or Patch I can apply?
I'd like to update to php 8 please.
Is there an update on this? Any fix or Patch I can apply? I'd like to update to php 8 please.
SpionDaze
SpionDaze posted this 21 December 2022
After more than a year of this are we just ignoring the issue then?
This is like Christmas in Australia - NOT COOL!
Is the solution really to stay on PHP 7.x forever then hey?
We were given a massive amount of warning and time that PHP 8 was coming to town, I cannot believe we are on the naughty list.
CHOOSE YOUR ERROR MESSAGE FOLKS:
IN THE RED CORNER, coming out of nowhere and weighing in at a blank white screen for all your front-end visitors to cheer for we have the undisputed REFRAIN OF PAIN!!!!
0 - Unknown named parameter $title and Too few arguments to function errorHandlerExportTheme(), 4 passed and exactly 5 expected
AND IN THE BLUE CORNER. Subtle and discreet by nature, more popular with your public but an administrators MASTER OF DISASTER, a security risk waiting to happen and sleepless nights guaranteed
Error
We have detected that your server is using PHP 7.4.33 which is obsolete and no longer receives official security updates by its developers. The Joomla! Project recommends upgrading your site to PHP 8.0 or later which will receive security updates at least until 2023-11-26. Please ask your host to make PHP 8.0 or a later version the default version for your site. If your host is already PHP 8.0 ready please enable PHP 8.0 on your site's root and 'administrator' directories – typically you can do this yourself through a tool in your hosting control panel, but it's best to ask your host if you are unsure.
2 heavyweights go head to head
THEMLER AND PHP8 NEED TO GET IT ON
BECAUSE THEY DON'T GET ALONG!!!!!
Merry Christmas to all
And to all a good night
After more than a year of this are we just ignoring the issue then? This is like Christmas in Australia - NOT COOL! Is the solution really to stay on PHP 7.x forever then hey? We were given a massive amount of warning and time that PHP 8 was coming to town, I cannot believe we are on the naughty list. CHOOSE YOUR ERROR MESSAGE FOLKS: IN THE RED CORNER, coming out of nowhere and weighing in at a blank white screen for all your front-end visitors to cheer for we have the undisputed REFRAIN OF PAIN!!!! 0 - Unknown named parameter $title and Too few arguments to function errorHandlerExportTheme(), 4 passed and exactly 5 expected AND IN THE BLUE CORNER. Subtle and discreet by nature, more popular with your public but an administrators MASTER OF DISASTER, a security risk waiting to happen and sleepless nights guaranteed Error We have detected that your server is using PHP 7.4.33 which is obsolete and no longer receives official security updates by its developers. The Joomla! Project recommends upgrading your site to PHP 8.0 or later which will receive security updates at least until 2023-11-26. Please ask your host to make PHP 8.0 or a later version the default version for your site. If your host is already PHP 8.0 ready please enable PHP 8.0 on your site's root and 'administrator' directories – typically you can do this yourself through a tool in your hosting control panel, but it's best to ask your host if you are unsure. 2 heavyweights go head to head THEMLER AND PHP8 NEED TO GET IT ON BECAUSE THEY DON'T GET ALONG!!!!! Merry Christmas to all And to all a good night
opureusa
opureusa posted this 26 May 2025
I had the same error on my site opureaustralia.com.au using a Themler theme:
Error:
And in the backend:
After some digging, I found the issue is caused by outdated Themler PHP code that doesn't match newer PHP versions (especially PHP 8+).
✅ Here's how I fixed it:
Switch PHP version temporarily
Downgrade to PHP 7.4 from your hosting panel.
It makes the site and theme editable again.
Update Themler theme files
Open /templates/yourtheme/error.php (or similar location).
Find the errorHandlerExportTheme() function.
Make sure it accepts 5 arguments, not 4. Example fix:
php
Copy
Edit
function errorHandlerExportTheme($errno, $errstr, $errfile, $errline, $errcontext = null)
Scan all custom functions for similar argument issues if the error persists.
After fix, switch back to PHP 8.x (if needed).
I had the same error on my site [opureaustralia.com.au][1] using a Themler theme: Error: 0 - Unknown named parameter $title And in the backend: Too few arguments to function errorHandlerExportTheme(), 4 passed and exactly 5 expected After some digging, I found the issue is caused by outdated Themler PHP code that doesn't match newer PHP versions (especially PHP 8+). ✅ Here's how I fixed it: Switch PHP version temporarily Downgrade to PHP 7.4 from your hosting panel. It makes the site and theme editable again. Update Themler theme files Open /templates/yourtheme/error.php (or similar location). Find the errorHandlerExportTheme() function. Make sure it accepts 5 arguments, not 4. Example fix: php Copy Edit function errorHandlerExportTheme($errno, $errstr, $errfile, $errline, $errcontext = null) Scan all custom functions for similar argument issues if the error persists. After fix, switch back to PHP 8.x (if needed). [1]: http://opureaustralia.com.au
sitiayuni
sitiayuni posted this 22 September 2025
Thanks for sharing this issue, Dan. Errors like that can be really confusing when themes update or break. I had a similar headache once while working on a small project that had nothing to do with coding, just setting up a tv wall mounting guide, and even then theme errors popped up out of nowhere. Hope you get a smooth fix soon!
Thanks for sharing this issue, Dan. Errors like that can be really confusing when themes update or break. I had a similar headache once while working on a small project that had nothing to do with coding, just setting up a [tv wall mounting][1] guide, and even then theme errors popped up out of nowhere. Hope you get a smooth fix soon! [1]: https://superantenna.com.au/
kevin1walker23
kevin1walker23 posted this 29 April 2026
This error usually occurs when an undefined parameter is being passed in the request, often due to incorrect field mapping or API structure mismatch. Double-checking the request payload and ensuring all required parameters are properly defined can usually resolve it. You might also find useful insights on Instant record search for handling similar validation and lookup-related issues. Hope this helps in debugging the parameter error efficiently.
This error usually occurs when an undefined parameter is being passed in the request, often due to incorrect field mapping or API structure mismatch. Double-checking the request payload and ensuring all required parameters are properly defined can usually resolve it. You might also find useful insights on [Instant record search][1] for handling similar validation and lookup-related issues. Hope this helps in debugging the parameter error efficiently. [1]: https://backgroundscheck.info
kevin_brooks44
kevin_brooks44 posted this 29 April 2026
That error usually pops up when a function or method is being called with a parameter name that isn’t defined in its signature, so it’s worth double-checking the exact argument names in your codebase or documentation. I’ve run into something similar while working with property data tools, and reviewing structured sources like this Citrus County Records helped me better understand how parameters are typically organized. It might also be caused by version mismatches where older code doesn’t align with updated functions. Try tracing where $title is introduced and confirm whether it should be renamed or removed.
That error usually pops up when a function or method is being called with a parameter name that isn’t defined in its signature, so it’s worth double-checking the exact argument names in your codebase or documentation. I’ve run into something similar while working with property data tools, and reviewing structured sources like this [Citrus County Records][1] helped me better understand how parameters are typically organized. It might also be caused by version mismatches where older code doesn’t align with updated functions. Try tracing where $title is introduced and confirm whether it should be renamed or removed. [1]: https://citruscountypropertyappraiser.org
tajogej112
tajogej112 posted this 10 September 2026
You ought to be a part of a tournament for one of the highest quality blogs on-line. I am going to suggest this site! IndoCair Alternatif
You ought to be a part of a tournament for one of the highest quality blogs on-line. I am going to suggest this site! [IndoCair Alternatif](https://indocairjp.com/indocair-alternatif/)
xeniko8001
xeniko8001 posted this 23 September 2026
An impressive share, I just now given this onto a colleague who had previously been doing little analysis about this. Anf the husband the fact is bought me breakfast simply because I stumbled upon it for him.. smile. So permit me to reword that: Thnx for your treat! But yeah Thnkx for spending some time to debate this, I find myself strongly over it and enjoy reading more about this topic. If possible, as you become expertise, might you mind updating your site with more details? It truly is highly of great help for me. Huge thumb up because of this text! toto togel
An impressive share, I just now given this onto a colleague who had previously been doing little analysis about this. Anf the husband the fact is bought me breakfast simply because I stumbled upon it for him.. smile. So permit me to reword that: Thnx for your treat! But yeah Thnkx for spending some time to debate this, I find myself strongly over it and enjoy reading more about this topic. If possible, as you become expertise, might you mind updating your site with more details? It truly is highly of great help for me. Huge thumb up because of this text! [url=https://koitotodihati.com/]toto togel[/url]
povage2116
povage2116 posted this 27 September 2026
Aw, this was a really nice post. In concept I wish to put in writing like this additionally – taking time and actual effort to make an excellent article… however what can I say… I procrastinate alot and not at all appear to get something done. 코인 주소모음
Aw, this was a really nice post. In concept I wish to put in writing like this additionally – taking time and actual effort to make an excellent article… however what can I say… I procrastinate alot and not at all appear to get something done. [코인 주소모음](https://xn--v52b27q55h.net/)
xeniko8001
xeniko8001 posted this 27 September 2026
You could definitely see your skills in the work you write. The world hopes for more passionate writers like you who aren’t afraid to say how they believe. At all times follow your heart 강남풀싸롱 위치안내
You could definitely see your skills in the work you write. The world hopes for more passionate writers like you who aren’t afraid to say how they believe. At all times follow your heart [url=https://gangnamplace.isweb.co.kr/location]강남풀싸롱 위치안내[/url]
