Hello after the update to Joomla 3.10.4 & 4.0.5 the Themler editor does not open anymore. The plugin cannot be installed during a new installation. Does anyone else have the same problem? Greetings Jörg
Hi.
Joomla 3.10.4 after update work perfect,
Do you mean that you updated Joomla from 3.10 to 4? There is a separate theme needed for Joomla 4. Currently it is in Beta, please refer to this article for more information:
https://answers.themler.io/questions/212738/joomla-4-support-is-available-in-beta
Hi Nettie, no I had done the update from 4.04 to 4.05. After that, the editor does not start anymore, Note: Sorry error occurred. Your project will be restored. This then goes into an endless loop. Have also tried this on different computers Windows and Mac. The same everywhere. On the backend page I discovered the following note, which was not there before. 2 Overide should be checked. See picture attached. If you click on it, you will get to the template, where something has been overwritten by the update. Before that, the beta version worked great.
Hi Nettie, no I had done the update from 4.04 to 4.05. After that, the editor does not start anymore, Note: Sorry error occurred. Your project will be restored. This then goes into an endless loop. Have also tried this on different computers Windows and Mac. The same everywhere. On the backend page I discovered the following note, which was not there before. 2 Overide should be checked. See picture attached. If you click on it, you will get to the template, where something has been overwritten by the update. Before that, the beta version worked great.Here is some info from Joomla before the update...
Here is some info from Joomla before the update...Hello,
If you install the freshly downloaded theme anew, does the error appear with it as well?
Moin @ all, cause found. If a menu is subsequently set in h-position, the error is as described. Menu set to a different position, the editor can be opened again. Completely crazy. But that's not normal, is it? :-) 2 days worked for this realization.. Best regards Jörg
Moin @ all, cause found. If a menu is subsequently set in h-position, the error is as described. Menu set to a different position, the editor can be opened again. Completely crazy. But that's not normal, is it? :-) 2 days worked for this realization.. Best regards JörgHello Jörg,
Sorry for the inconvenience. Thank you for the results. Indeed, there is an issue with the menu in the theme for Joomla 4. Of course, it isn't normal and needs fixing, so we have forwarded the issue to our developers. This theme is in Beta, but there are several important fixes awaited in the next update.
Hello Nettie, I'm happy if it helped you. Looking forward to the next Themler version. Merry Christmas & a Happy New Year Jörg
Hello Nettie, I'm happy if it helped you. Looking forward to the next Themler version. Merry Christmas & a Happy New Year JörgThank you! For you too! We will update this topic as soon as an update is ready.
