Changing to PHP 8 throws joomla front-end offline
Ch3vr0n
Ch3vr0n posted this 18 December 2021
Yesterday while updating to 3.10.4 Akeeba backup that does an automatic pre-joomla update backup, notified me that 7.4.26 entered the "security" phase. I figured well, good enough reason to switch to PHP 8. Now the thing is. When i do that the backend on the domain works just fine but the front-end goes offline with
"0 - Unknown named parameter $title"
I have 2 other sites (that got the same warning by akeeba backup) that i switched over to PHP 8 just fine. Frontend and backend are operational. Those are using Nicepage. I know it's something in the template, because when i swap to one of the default templates in J3.10.4 like Beez3 site renders just fine.
If i change PHP back to 7.4.26 while leaving the custom template as default, the site immediately goes back up. So what gives...
Yesterday while updating to 3.10.4 Akeeba backup that does an automatic pre-joomla update backup, notified me that 7.4.26 entered the "security" phase. I figured well, good enough reason to switch to PHP 8. Now the thing is. When i do that the backend on the domain works just fine but the front-end goes offline with "0 - Unknown named parameter $title" I have 2 other sites (that got the same warning by akeeba backup) that i switched over to PHP 8 just fine. Frontend and backend are operational. Those are using Nicepage. I know it's something in the template, because when i swap to one of the default templates in J3.10.4 like Beez3 site renders just fine. If i change PHP back to 7.4.26 while leaving the custom template as default, the site immediately goes back up. So what gives...
21 Comments
bmericsson
bmericsson posted this 19 December 2021
I have exactly the same problem, No problem with Beez3 or protostar- template.
I want to follow that thread. Hope this problem can be solved relatively easily. Thank you
I have exactly the same problem, No problem with Beez3 or protostar- template. I want to follow that thread. Hope this problem can be solved relatively easily. Thank you
Vitaliy WD
Vitaliy WD posted this 19 December 2021
Seems that it's not so important for Themler team, they already answered, that this bugs will not be solved this year.. most probably during next year. It's ok, PHP 8 released just year ago. PHP 8.1 already available and supported by Joomla 4.
I cannot promise all issues to be fixed this month. Some of the issues
are still under investigation, and new issues are reported from time
to time by our customers and need checking. So the new version is
expected already in the new year. Surely there will be an announcement
about the update on the forum.
Sincerely, Nettie
Seems that it's not so important for Themler team, they already answered, that this bugs will not be solved this year.. most probably during next year. It's ok, PHP 8 released just year ago. PHP 8.1 already available and supported by Joomla 4. > Hello, > > I cannot promise all issues to be fixed this month. Some of the issues > are still under investigation, and new issues are reported from time > to time by our customers and need checking. So the new version is > expected already in the new year. Surely there will be an announcement > about the update on the forum. > > Sincerely, Nettie
Ch3vr0n
Ch3vr0n posted this 19 December 2021
The thing is, i know it's impossible to fix everything quick. But i'm not renewing for $99 just to fix the template issue. A newer bootstrap version is pretty much mandatory nowadays. As far as PHP 8.1 being released goes, well that's irrelevant. If the theme doesn't work on PHP8 it's not gonna work on 8.1 either.
pdg.design
pdg.design posted this 19 December 2021
I have same problem.
Support Team posted this 5 weeks ago
We are sorry for the issue. Indeed, Joomla 3 doesn't work with PHP 8 at the moment. The issue is forwarded to our developers. We will update this topic when an update with the fix is available.
Hello, We are sorry for the issue. Indeed, Joomla 3 doesn't work with PHP 8 at the moment. The issue is forwarded to our developers. We will update this topic when an update with the fix is available. Sincerely, Nettie
Seppe
Seppe posted this 5 weeks ago
Last weekend I updated 19 websites. For all of them I got the same security warning for PHP 7.4.... Luckily I didn't switch tot PHP 8, or I would have been on the phone for days with clients why their website is not working anymore :)
Ch3vr0n
Ch3vr0n posted this 5 weeks ago
It's a quick "fix". All it takes to get the site working again on the front-end is setting php back to 7.4. What's weird though it that the site BACKEND works just fine with php 8. This is 100% a template problem with php 8, as the stock joomla ones work just fine.
pdg.design
pdg.design posted this 4 weeks ago
I agree
I agree
Vitaliy WD
Vitaliy WD posted this 4 weeks ago
Joomla 3 work with PHP 8.1.
What's in 3.10.4?
Joomla 3.10.4 addresses several bugs, including: Bug fixes and Improvements
PHP 8.1 compatibility patches
https://www.joomla.org/announcements/release-news/5851-joomla-4-0-5-and-joomla-3-10-4-are-here.html
> Hello, > > We are sorry for the issue. Indeed, Joomla 3 doesn't work with PHP 8 at the moment. The issue is forwarded to our developers. We will update this topic when an update with the fix is available. > > Sincerely, > Nettie Joomla 3 work with PHP 8.1. > What's in 3.10.4? > Joomla 3.10.4 addresses several bugs, including: Bug fixes and Improvements > PHP 8.1 compatibility patches https://www.joomla.org/announcements/release-news/5851-joomla-4-0-5-and-joomla-3-10-4-are-here.html
Ch3vr0n
Ch3vr0n posted this 4 weeks ago
Well j3.10.4 doesn't for me with PHP 8.0. 8.1 isn't installed on my server yet but I can try it
Pulswerk
Pulswerk posted this 4 weeks ago
Stay calm, they are working on it and it is definitely an issue with Themler combined with PHP 8.0
Ch3vr0n
I am calm. Just saying that what vitaly said, is either wrong or doesn't apply for everyone
bmericsson
bmericsson posted this 2 weeks ago
How is the status right now? It feels a bit silly to NOW build pages with php 7.4
gillanubhav4
gillanubhav4 posted this 2 weeks ago
peter.lind
peter.lind posted this 2 weeks ago
I have exactly the same problem, - Themler Templates are definitely not working with PHP 8.0
pdg.design
pdg.design posted this 2 weeks ago
Stay to wait stable version...
biljiczop
biljiczop posted this 2 weeks ago
i think Joomla 3 doesn't work with PHP 8 at the moment
Ch3vr0n
Ch3vr0n posted this 2 weeks ago
You think wrong. J3 itself works just fine with PHP 8. This is a problem with the themler generated template.
Indeed, there is an issue with Themler for Joomla 3 and PHP 8. It is already forwarded to our developers but the fix isn't available yet. We are also going to test it with PHP 8.1 which is the latest released version at the moment.
We recommend to temporarily use PHP 7.4 for Themler with Joomla 3 and with Wordpress and are sorry for inconvenience.
Hello, Indeed, there is an issue with Themler for Joomla 3 and PHP 8. It is already forwarded to our developers but the fix isn't available yet. We are also going to test it with PHP 8.1 which is the latest released version at the moment. We recommend to temporarily use PHP 7.4 for Themler with Joomla 3 and with Wordpress and are sorry for inconvenience. Sincerely, Nettie
matrix630307
matrix630307 posted this 2 weeks ago
Since month the same - "...forwarded to your developers..."
not only this problem - many others too!
since month only v544 - no updates since months.
peoples: read in this forum all other problems with themler... no php8, no update bootstrap, not working with joomla 4 and and and...
my reason is at time - no pay for themler udpate!
Since month the same - "...forwarded to your developers..." not only this problem - many others too! since month only v544 - no updates since months. peoples: read in this forum all other problems with themler... no php8, no update bootstrap, not working with joomla 4 and and and... my reason is at time - no pay for themler udpate!
