Virtuemart products page - list view as default
souacz
souacz posted this 11 January 2022
How to set a list view as default in category page? I'd like to remove view mode switcher but the grid view is set as default and it is not possible to force list view...
Hi, How to set a list view as default in category page? I'd like to remove view mode switcher but the grid view is set as default and it is not possible to force list view...
athenaios83
athenaios83 posted this 11 February 2022
I'm interested too.
I suppose we may edit some jquery in the template to invert the logic and then hide the switcher through css, but I'd rather not edit the generated template files manually.
I'm interested too. I suppose we may edit some jquery in the template to invert the logic and then hide the switcher through css, but I'd rather not edit the generated template files manually.
athenaios83
Here's what we did, in case it can be helpful to someone else:
we applied a simple workaround that didn't touch the template's file: we just added a few simple lines of javascript to simulate a click on the selector, and we hid the selector with CSS
<script>  document.addEventListener('DOMContentLoaded', function(){  var element = document.querySelector("[data-layout-name='bd-griditemlist']");element.click(); });</script>
This simple script gets the list style selector and clicks on it as soon as the page is loaded, resulting in the desidered view.
Maybe it's not a clean solution but it works and it doesn't require to alter the template's files.
Here's what we did, in case it can be helpful to someone else: we applied a simple workaround that didn't touch the template's file: we just added a few simple lines of javascript to simulate a click on the selector, and we hid the selector with CSS <script> document.addEventListener('DOMContentLoaded', function(){ var element = document.querySelector("[data-layout-name='bd-griditemlist']");element.click(); });</script> This simple script gets the list style selector and clicks on it as soon as the page is loaded, resulting in the desidered view. Maybe it's not a clean solution but it works and it doesn't require to alter the template's files.
