I need export a Joomla template to use it in Joomla 4, can you tell us if we can do this operation.
Thanks!!
Thanks!!
Hi.
If you already have Joomla 3 Themler template, then you need to rebuild it from scratch with blank Themler Joomla 4 template.
Themler developers have not done and do not plan to do Joomla 3 to Joomla 4 migration.
And please note, that current Joomla 4 Themler template in Beta with a lot of bugs - not for production. Developers don't tell us when the Stable version will be rolled out.
Meanwhile, please vote for Themler 2.0 with Bootstrap 5 and support only two CMS: Joomla 4 and WordPress 5
Hi. If you already have Joomla 3 Themler template, then you need to rebuild it from scratch with blank Themler Joomla 4 template. Themler developers have not done and do not plan to do Joomla 3 to Joomla 4 migration. And please note, that current Joomla 4 Themler template in Beta with a lot of bugs - not for production. Developers don't tell us when the Stable version will be rolled out. Meanwhile, please vote for [Themler 2.0 with Bootstrap 5 and support only two CMS: Joomla 4 and WordPress 5][1] [1]: https://answers.themler.io/questions/214290/themler-2-0-with-bootstrap-5-and-support-only-two-cms-joomla-4-and-wordpress-5Hello,
Old themes are all for Joomla 3 and cannot be imported or converted for Joomla 4 automatically. The themes are completely different as if they were for different CMS's. That is why for Joomla 4 a separate theme should be downloaded and not just Joomla 3 theme with Themler update.
Here are possible ways to make creating themes easier (if they are made to re-create old themes):
- organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip
- there are Export / Import options available in the Posts tab to transfer Posts layout and styling
A new version of Themler theme for Joomla 4 is expected soon, with the bugs fixed.
The current Beta version of Themler theme for Joomla 4 is available at this link.
Ok, we'll decide the way. Thanks for your help!
Ok, we'll decide the way. Thanks for your help!You are welcome. Please feel free to contact us in any other case.
