could you explain where to find this in the css or another fix visually using themler?
TIA
Dom
!formattingIssue.jpg!Hi, I have added some text and an image in a section and for some reason after using z-index to put the picture behind the text I have been unable to remove the image. I tried putting the text behind the image using z-index to remove the image but that just made both un-editable. could you explain where to find this in the css or another fix visually using themler? TIA DomLast edited 08 February 2022 by kominid
