posted this
02 March 2022
Please find the updated theme attached. For future themes, you may consider using this workaround to update them:
- Open Themler Desktop
- Open your theme
- Make its copy under different (slightly) name via File -> Make a copy as
- Close Themler Desktop
- Open Themler desktop
- Select your CMS
- Find the copy of the theme in the list of themes there you have
- Open it and it should start updating, or at least should be opened with the red Update button on top available
1. Open Themler Desktop
2. Open your theme
3. Make its copy under different (slightly) name via File -> Make a copy as
4. Close Themler Desktop
5. Open Themler desktop
6. Select your CMS
7. Find the copy of the theme in the list of themes there you have
8. Open it and it should start updating, or at least should be opened with the red Update button on top available
