users can't see Themler menu
SW0405
SW0405 posted this 03 March 2022
We have set up additional users who are not admin users. The Themler menu is not displayed to the user. Even if he is made an administrator.
Everything works for the "old" user.
We have set up additional users who are not admin users. The Themler menu is not displayed to the user. Even if he is made an administrator. Everything works for the "old" user.
8 Comments
SW0405
If we use the new user, we get the allert "Sorry, you do not have permission to access this page."
Sorry, it's in WORDPRESS
If we use the new user, we get the allert "Sorry, you do not have permission to access this page." Sorry, it's in WORDPRESS
Support Team posted this 03 March 2022
The issue looks to be related to access levels on hte website. Is it reproducible if you use a non-Themler theme?
Hello, The issue looks to be related to access levels on hte website. Is it reproducible if you use a non-Themler theme? Sincerely, Nettie
SW0405
SW0405 posted this 04 March 2022
if we create a new user with administrator level, it is the same :-(
SW0405
Oh I think, it wasn't specific enough.
The item "Themler" at wordpress admin menu isn't available.
If I use the direct link, copied after login with an other user (Superadmin), I get the failure message...
Oh I think, it wasn't specific enough. The item "Themler" at wordpress admin menu isn't available. If I use the direct link, copied after login with an other user (Superadmin), I get the failure message...
Support Team posted this 04 March 2022
It is recommended, to have admin rights to edit with Themler. If the issue is still present, please refer to this article:
https://answers.themler.io/articles/65515/themler-themes-issues-wordpress-woocommerce
Hello, It is recommended, to have admin rights to edit with Themler. If the issue is still present, please refer to this article: https://answers.themler.io/articles/65515/themler-themes-issues-wordpress-woocommerce Sincerely, Nettie
SW0405
SW0405 posted this 06 March 2022
Hello and thank you for your answer,
for "User1" as superadmin it is possible to see the item.
"User2" is only admin and can't see.
The line: "define('DISALLOW_FILE_EDIT', false);" I had always implemented.
Hello and thank you for your answer, for "User1" as superadmin it is possible to see the item. "User2" is only admin and can't see. The line: "define('DISALLOW_FILE_EDIT', false);" I had always implemented.
galirk1232
galirk1232 posted this 2 days ago
Still problem?
Still problem?
You may not see the Themler admin Menu if you disabled Theme Editor for all users in the WP wp-config.php file by adding the following line:
define('DISALLOW_FILE_EDIT', true);
Please change true value to false.
Hello, You may not see the Themler admin Menu if you disabled Theme Editor for all users in the WP wp-config.php file by adding the following line: define('DISALLOW_FILE_EDIT', true); Please change `true` value to `false`. Sincerely, Nettie
