Artisteer To Themler
ABSolutions
ABSolutions posted this 03 March 2022
Hi - I have tried to follow the instruction to import an Artisteer theme into Themler. It fails every time. I can provide the .ARTX file, the zipped Joomla template package. Any help would be appreciated as I have a site that I need to migrate to a newer version of PHP and have to convert the template to do that.
AB
Hi - I have tried to follow the instruction to import an Artisteer theme into Themler. It fails every time. I can provide the .ARTX file, the zipped Joomla template package. Any help would be appreciated as I have a site that I need to migrate to a newer version of PHP and have to convert the template to do that. AB
12 Comments
Support Team posted this 04 March 2022
Please try this latest update, it is possible to export themes for Themler for Joomla, Wordpress and HTML with this version:
Hello, Please try this latest update, it is possible to export themes for Themler for Joomla, Wordpress and HTML with this version: www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe Sincerely, Nettie
ABSolutions
ABSolutions posted this 04 March 2022
I am running that version of Artisteer already.
AB
I am running that version of Artisteer already. AB
Support Team posted this 09 March 2022
Artisteer themes exported to Themler support now Joomla 3.x and PHP 7.x. We plan to add PHP 8 support in the future. For now please try temporarily using older PHP.
Hello, Artisteer themes exported to Themler support now Joomla 3.x and PHP 7.x. We plan to add PHP 8 support in the future. For now please try temporarily using older PHP. Sincerely, Nettie
ABSolutions
ABSolutions posted this 09 March 2022
The problem is I can't import the Artisteer theme to Themler. If fails.
AB
The problem is I can't import the Artisteer theme to Themler. If fails. AB
Support Team posted this 10 March 2022
Do you use Themler desktop or Themler on your website? If on your website, what is your CMS version and PHP version?
Hello, Do you use Themler desktop or Themler on your website? If on your website, what is your CMS version and PHP version? Sincerely, Nettie
ABSolutions
ABSolutions posted this 10 March 2022
I have tried it on both the desktop version and the online version. The site is currently running Joomla 3.10.6 and PHP 7.4.28/
AB
I have tried it on both the desktop version and the online version. The site is currently running Joomla 3.10.6 and PHP 7.4.28/ AB
Support Team posted this 30 March 2022
I have just found your topic unanswered in our system and am really sorry for this. Is the issue still actual?
Hello, I have just found your topic unanswered in our system and am really sorry for this. Is the issue still actual? Sincerely, Nettie
ABSolutions
ABSolutions posted this 30 March 2022
Hi Nettie,
Yes- it is still an issue.
AB
Hi Nettie, Yes- it is still an issue. AB
Please try the following:
  1. Open Themler Desktop
  2. Open your theme
  3. Make its copy under a (slightly) different name via File -> Make a copy as
  4. Close Themler Desktop
  5. Open Themler desktop
  6. Select your CMS
  7. Find the copy of the theme in the list of themes there you have
  8. Open it and it should start updating, or at least should be opened with the red Update button on top available
  9. Update it and try editing it.
Hello, Please try the following: 1. Open Themler Desktop 2. Open your theme 3. Make its copy under a (slightly) different name via File -> Make a copy as 4. Close Themler Desktop 5. Open Themler desktop 6. Select your CMS 7. Find the copy of the theme in the list of themes there you have 8. Open it and it should start updating, or at least should be opened with the red Update button on top available 9. Update it and try editing it. Sincerely, Nettie
Abbas Khan
Abbas Khan posted this 26 June 2025
Every successful construction job starts with understanding the true cost. We provide comprehensive and highly detailed construction estimates that give you full visibility over every stage of your project. From labor costs and equipment rentals to current material prices and contingencies, our estimating team ensures nothing is missed pipe takeoff service. Whether you're pricing a small remodel or a large-scale development, our estimates are designed to protect your budget, support your bids, and improve decision-making.
Every successful construction job starts with understanding the true cost. We provide comprehensive and highly detailed construction estimates that give you full visibility over every stage of your project. From labor costs and equipment rentals to current material prices and contingencies, our estimating team ensures nothing is missed **[pipe takeoff service][1]**. Whether you're pricing a small remodel or a large-scale development, our estimates are designed to protect your budget, support your bids, and improve decision-making. [1]: https://aconengineering.com/piping-estimating/
chinahousehold
chinahousehold posted this 28 November 2025
https://www.hssolar.cn
https://www.hssolar.cn/news-16.html
https://write.frame.gargantext.org/s/B190dmS-Wg
https://docs.localcharts.org/s/dEzcU6hX4
https://hackmd.vlsi.ict.e.titech.ac.jp/s/rkUnjXS-Ze
https://hedgedoc.syyrell.com/s/PyJOGcnAW
https://hedgedoc.stura-ilmenau.de/s/PRS_fLbdP
https://gardenaca.global-free-classified-ads.com/l-flooring-services/horizontal-carbonized-solid-bamboo-flooring-it14739567l1435.html
https://imageevent.com/bothbest/chinabambooflooring
https://my.clickthecity.com/chinabamboo
https://dmncms.net/topic/277201-bamboo-flooring-for-modern-minimalist-designs/
https://www.murfreesborovoice.com/article/93946/click-lock-bamboo-vs-traditional-tongue-and-groove-installation-speed-test
https://www.kompasiana.com/flooringbamboo6092/6928e66e34777c489b36c222/bamboo-plywood-supplier-from-bothbest-bamboo
https://codoc.jp/sites/bothbest/entries/nYgLqGg4AQ
http://www.mocyc.com/board/43097/WhyBambooIsMoreSustainableThanMapleandOak
https://chot.design/forums/ui-design/1743399/
https://ead.pge.rs.gov.br/tag/index.php?tc=1&tag=bamboodecking
https://japaneseclass.jp/notes/open/106948
https://www.hssolar.cn https://www.hssolar.cn/news-16.html https://write.frame.gargantext.org/s/B190dmS-Wg https://docs.localcharts.org/s/dEzcU6hX4 https://hackmd.vlsi.ict.e.titech.ac.jp/s/rkUnjXS-Ze https://hedgedoc.syyrell.com/s/PyJOGcnAW https://hedgedoc.stura-ilmenau.de/s/PRS_fLbdP https://gardenaca.global-free-classified-ads.com/l-flooring-services/horizontal-carbonized-solid-bamboo-flooring-it14739567l1435.html https://imageevent.com/bothbest/chinabambooflooring https://imageevent.com/bothbest https://my.clickthecity.com/chinabamboo https://dmncms.net/topic/277201-bamboo-flooring-for-modern-minimalist-designs/ https://www.murfreesborovoice.com/article/93946/click-lock-bamboo-vs-traditional-tongue-and-groove-installation-speed-test https://www.kompasiana.com/flooringbamboo6092/6928e66e34777c489b36c222/bamboo-plywood-supplier-from-bothbest-bamboo https://codoc.jp/sites/bothbest/entries/nYgLqGg4AQ http://www.mocyc.com/board/43097/WhyBambooIsMoreSustainableThanMapleandOak https://chot.design/forums/ui-design/1743399/ https://ead.pge.rs.gov.br/tag/index.php?tc=1&tag=bamboodecking https://japaneseclass.jp/notes/open/106948
xevpass
xevpass posted this 24 March 2026
It seems you're facing challenges with importing your Artisteer theme into Themler. Have you tried checking compatibility settings or seeking support from their forums? For more creative solutions and inspiration, visit ice baby quest , where innovation meets imagination!
It seems you're facing challenges with importing your Artisteer theme into Themler. Have you tried checking compatibility settings or seeking support from their forums? For more creative solutions and inspiration, visit [ice baby quest][1] , where innovation meets imagination! [1]: https://www.icebabyquest.com
