Problem with theme upgrade
tobimetzger
tobimetzger posted this 15 March 2022
I've imported my Artisteer Joomla theme into Themler.
Themler shows me that an update is available and asks me "Upgrade current theme to latest Themler?"
When I hit Backup and Upgrade it takes a second and the I'm getting the message Server error (See attached screenshot).
What does this mean and can you fix it?
Tobias
Hi, I've imported my Artisteer Joomla theme into Themler. Themler shows me that an update is available and asks me "Upgrade current theme to latest Themler?" When I hit Backup and Upgrade it takes a second and the I'm getting the message Server error (See attached screenshot). What does this mean and can you fix it? Thanks, Tobias !CapturFiles-15-02-2022-04.02.25.png!
12 Comments
Support Team posted this 16 March 2022
This may be because a theme is pretty old. Please try the following:
  1. Open Themler Desktop
  2. Open your theme
  3. Make its copy under different (slightly) name via File -> Make a copy as
  4. Close Themler Desktop
  5. Open Themler desktop
  6. Select your CMS
  7. Find the copy of the theme in the list of themes there you have
  8. Open it and it should start updating, or at least should be opened with the red Update button on top available
Hello, This may be because a theme is pretty old. Please try the following: 1. Open Themler Desktop 2. Open your theme 3. Make its copy under different (slightly) name via File -> Make a copy as 4. Close Themler Desktop 5. Open Themler desktop 6. Select your CMS 7. Find the copy of the theme in the list of themes there you have 8. Open it and it should start updating, or at least should be opened with the red Update button on top available Sincerely, Nettie
rosy23dam
rosy23dam posted this 16 November 2023
While I understand the basis of your argument, I find myself at odds with your position due to Pokemon Infinite Fusion the inherent contradictions and inconsistencies it presents.
While I understand the basis of your argument, I find myself at odds with your position due to [Pokemon Infinite Fusion][1] the inherent contradictions and inconsistencies it presents. [1]: https://pokemoninfinitefusion.io
patrickrall
patrickrall posted this 08 May 2024
It seems that when trying to update your Artisteer theme to the latest version of Themler, you are encountering a server error. This could be due to several reasons, such as connection problems, incorrect configurations, or incompatibilities between versions.
To resolve this issue, I would recommend performing some basic troubleshooting steps:
Check your internet connection to make sure you are connected correctly.
Make sure Themler settings are set correctly, including proper access permissions.
Try updating at a different time, as server issues may be temporary.
If the problem persists, consider contacting Themler technical support for specialized assistance.
I hope these steps help you resolve the issue and you can update your theme successfully. Good luck!
prestamos faciles en 15 minutos
It seems that when trying to update your Artisteer theme to the latest version of Themler, you are encountering a server error. This could be due to several reasons, such as connection problems, incorrect configurations, or incompatibilities between versions. To resolve this issue, I would recommend performing some basic troubleshooting steps: Check your internet connection to make sure you are connected correctly. Make sure Themler settings are set correctly, including proper access permissions. Try updating at a different time, as server issues may be temporary. If the problem persists, consider contacting Themler technical support for specialized assistance. I hope these steps help you resolve the issue and you can update your theme successfully. Good luck! [prestamos faciles en 15 minutos][1] [1]: https://www.productosbancarios.net/prestamos-en-15-minutos-sin-papeleos/
studwork1742
studwork1742 posted this 08 May 2024
Feeling constantly tired and unwell, I wondered if hormones were the cause. I needed detailed and understandable information to help me navigate. This led me to https://ways2well.com/blog/hormone-replacement-therapy-in-austin-texas-what-to-expect-and-how-to-choose-provider, a resource that broke down the complex topic of hormone therapy into understandable parts. The site not only told me about the therapy itself, but also provided a directory of service providers. It was exactly what I needed to get me on the road to better health.
Feeling constantly tired and unwell, I wondered if hormones were the cause. I needed detailed and understandable information to help me navigate. This led me to [https://ways2well.com/blog/hormone-replacement-therapy-in-austin-texas-what-to-expect-and-how-to-choose-provider][1], a resource that broke down the complex topic of hormone therapy into understandable parts. The site not only told me about the therapy itself, but also provided a directory of service providers. It was exactly what I needed to get me on the road to better health. [1]: https://ways2well.com/blog/hormone-replacement-therapy-in-austin-texas-what-to-expect-and-how-to-choose-provider
fsadasdasda
fsadasdasda posted this 11 May 2024
As a sunglasses enthusiast, it can be a challenge to stay on top of the latest trends. But guess what? I found a resource that's become my go-to for everything sunglasses related. It's so comprehensive and detailed, I feel like I have insider knowledge about what's going to be hot in the upcoming summer season. Here is the link: https://optyx.com/news/spring-summer-sunglass-trends-2024/. I cannot stress enough how much easier this has made my shopping experience. I can now pick out the perfect pair that not only suits my style but also aligns with the latest fashion trends. Trust me, if you're into eyewear, this is a resource you don't want to miss.
grthfejdwks23
grthfejdwks23 posted this 17 May 2024
I've been researching different cosmetic surgery options and came across a fantastic guide that covers everything you need to know about fat transfer breast augmentation. The guide https://partingtonps.com/breast-surgery/fat-transfer-breast-augmentation/ is incredibly detailed, covering the procedure, recovery process, and potential outcomes. It's been a crucial part of my decision-making process and I highly recommend it to anyone considering this type of procedure. Definitely worth your time!
voipturks
voipturks posted this 19 May 2024
Privacy marka vozol likitleri şimdi yayında, hemen vozol pufflarınıza uyumlu vozol likitleri satın alabilirsiniz.
Privacy marka vozol likitleri şimdi yayında, hemen vozol pufflarınıza uyumlu [vozol likit][1]leri satın alabilirsiniz. [1]: https://buharkeyf01.com/salt-nikotin-likit-pod-e-likit/privacy-vozol-likit
etiltarimsal
etiltarimsal posted this 27 May 2024
Vozol Nedir?
Vozol, Türkiye’nin öncü elektronik sigara markalarından biri olarak, yüksek kalite, üstün performans ve güvenlik standartlarına sahip geniş bir ürün yelpazesi sunmaktadır. Vozol’un sunduğu bu çeşitlilik, sigara içenlere mükemmel bir alternatif sunarken, sağlığa ve çevreye duyarlı bir seçeneği de beraberinde getirir. Vozol ürünleri, tütün dumanı ve zararlı kimyasallardan tamamen arındırılmıştır ve bu özellikleriyle sigara içmeyi bırakmak isteyenler için ideal bir tercihtir. Türkiye’nin dört bir yanında rahatlıkla bulunabilen Vozol ürünleri, elektronik sigara kullanıcıları arasında da büyük bir popülerlik kazanmıştır. Eğer elektronik sigara deneyiminizi mükemmel bir seviyeye taşımak ve kaliteden ödün vermeden sigara alışkanlığınızı değiştirmek istiyorsanız, Vozol ürünlerini tercih etmek, doğru bir adım olacaktır.
[Vozol Nedir?][1] [Vozol,][2] Türkiye’nin öncü elektronik sigara markalarından biri olarak, yüksek kalite, üstün performans ve güvenlik standartlarına sahip geniş bir ürün yelpazesi sunmaktadır. Vozol’un sunduğu bu çeşitlilik, sigara içenlere mükemmel bir alternatif sunarken, sağlığa ve çevreye duyarlı bir seçeneği de beraberinde getirir. Vozol ürünleri, tütün dumanı ve zararlı kimyasallardan tamamen arındırılmıştır ve bu özellikleriyle sigara içmeyi bırakmak isteyenler için ideal bir tercihtir. Türkiye’nin dört bir yanında rahatlıkla bulunabilen Vozol ürünleri, elektronik sigara kullanıcıları arasında da büyük bir popülerlik kazanmıştır. Eğer elektronik sigara deneyiminizi mükemmel bir seviyeye taşımak ve kaliteden ödün vermeden sigara alışkanlığınızı değiştirmek istiyorsanız, [Vozol][3] ürünlerini tercih etmek, doğru bir adım olacaktır. [1]: https://www.etiltarimsal.com/vozolpuff [2]: https://www.etiltarimsal.com/vozolpuff [3]: https://www.etiltarimsal.com/vozolpuff
Briel
Briel posted this 23 June 2024
The server error during the theme upgrade in Themler likely indicates an issue with your server's configuration or compatibility with the upgrade process, and reviewing the server logs can provide more https://hauntthehousegame.com information to help resolve the problem
herrylauu0
herrylauu0 posted this 05 September 2024
Once you’ve grown large enough, focus on swallowing entire blocks of the city Hole IO or targeting other players’ holes. This ensures you stay on top of the leaderboard and secure your win.
Once you’ve grown large enough, focus on swallowing entire blocks of the city [Hole IO][1] or targeting other players’ holes. This ensures you stay on top of the leaderboard and secure your win. [1]: https://holegame.io/
ahmetseher3434
ahmetseher3434 posted this 07 September 2024
IQOS Nedir?
IQOS, Philip Morris International tarafından üretilen, tütünü yakmak yerine ısıtan bir elektronik cihazdır. "I Quit Ordinary Smoking" (Sıradan Sigarayı Bırakıyorum) kelimelerinin baş harflerinden oluşur.
Nasıl Çalışır?
Isıtma, Yakma Değil: Klasik sigaralarda tütün yakılırken, IQOS'ta özel olarak tasarlanmış tütün çubukları belirli bir sıcaklıkta ısıtılır. Bu sayede yanma olmadığı için kül ve duman oluşumu da minimum seviyeye iner.
Gerçek Tütün Tadı: IQOS, tütünü yakmadan ısıttığı için, kullanıcılara gerçek tütün tadını daha farklı bir deneyimle sunmayı hedefler.
Daha Az Zararlı Mı?
Tütün Endüstrisinin İddiası: Üretici şirketler, IQOS'un sigaraya göre daha az zararlı olduğunu iddia eder. Bu iddialar, tütünün yanmaması ve dolayısıyla bazı zararlı maddelerin daha az oluşması gerçeğine dayanır.
Bilimsel Çalışmalar: Bilimsel çalışmalar, IQOS'un sigaraya göre risklerini tam olarak ortaya koymak için devam etmektedir. Ancak, Dünya Sağlık Örgütü gibi kuruluşlar, ısıtılan tütün ürünlerinin diğer tütün ürünlerine göre daha az zararlı olduğunu gösteren yeterli kanıt olmadığını belirtmektedir.
Bağımlılık: IQOS, nikotin içerdiği için bağımlılık yapma potansiyeli taşımaktadır. Bu nedenle, sigarayı bırakmak isteyen kişiler için her zaman ilk tercih olmamalıdır.
Kimler İçin Uygun?
Sigarayı Bırakamayanlar: Sigarayı bırakmakta zorlanan yetişkin sigara kullanıcıları, IQOS'u bir alternatif olarak düşünebilir.
Duman ve Külden Rahatsız Olanlar: IQOS, duman ve kül oluşturmadığı için bu konuda hassasiyeti olan kişiler için daha uygun olabilir.
Önemli Notlar:
Tütün Ürünüdür: HEETS, bir tütün ürünüdür ve nikotin içerir. Nikotin bağımlılık yapıcı bir maddedir.
Sağlık Riskleri: Herhangi bir tütün ürününün kullanımı sağlık risklerini beraberinde getirir.
Yasal Düzenlemeler: IQOS'un satış ve kullanımı ülkelere göre farklı yasal düzenlemelere tabidir.
Sonuç:
IQOS, sigaraya alternatif olarak sunulan bir üründür. Ancak, daha az zararlı olduğu yönündeki iddialar kesin olarak kanıtlanmamıştır. Sigarayı bırakmak isteyen kişilerin öncelikle doktorlarına danışmaları ve nikotin bağımlılığından kurtulmak için tıbbi destek almaları önemlidir.
**IQOS Nedir?** [IQOS][1], Philip Morris International tarafından üretilen, tütünü yakmak yerine ısıtan bir elektronik cihazdır. "I Quit Ordinary Smoking" (Sıradan Sigarayı Bırakıyorum) kelimelerinin baş harflerinden oluşur. Nasıl Çalışır? Isıtma, Yakma Değil: Klasik sigaralarda tütün yakılırken, IQOS'ta özel olarak tasarlanmış tütün çubukları belirli bir sıcaklıkta ısıtılır. Bu sayede yanma olmadığı için kül ve duman oluşumu da minimum seviyeye iner. Gerçek Tütün Tadı: IQOS, tütünü yakmadan ısıttığı için, kullanıcılara gerçek tütün tadını daha farklı bir deneyimle sunmayı hedefler. Daha Az Zararlı Mı? Tütün Endüstrisinin İddiası: Üretici şirketler, IQOS'un sigaraya göre daha az zararlı olduğunu iddia eder. Bu iddialar, tütünün yanmaması ve dolayısıyla bazı zararlı maddelerin daha az oluşması gerçeğine dayanır. Bilimsel Çalışmalar: Bilimsel çalışmalar, IQOS'un sigaraya göre risklerini tam olarak ortaya koymak için devam etmektedir. Ancak, Dünya Sağlık Örgütü gibi kuruluşlar, ısıtılan tütün ürünlerinin diğer tütün ürünlerine göre daha az zararlı olduğunu gösteren yeterli kanıt olmadığını belirtmektedir. Bağımlılık: IQOS, nikotin içerdiği için bağımlılık yapma potansiyeli taşımaktadır. Bu nedenle, sigarayı bırakmak isteyen kişiler için her zaman ilk tercih olmamalıdır. Kimler İçin Uygun? Sigarayı Bırakamayanlar: Sigarayı bırakmakta zorlanan yetişkin sigara kullanıcıları, IQOS'u bir alternatif olarak düşünebilir. Duman ve Külden Rahatsız Olanlar: IQOS, duman ve kül oluşturmadığı için bu konuda hassasiyeti olan kişiler için daha uygun olabilir. Önemli Notlar: Tütün Ürünüdür: [HEETS][2], bir tütün ürünüdür ve nikotin içerir. Nikotin bağımlılık yapıcı bir maddedir. Sağlık Riskleri: Herhangi bir tütün ürününün kullanımı sağlık risklerini beraberinde getirir. Yasal Düzenlemeler: IQOS'un satış ve kullanımı ülkelere göre farklı yasal düzenlemelere tabidir. Sonuç: IQOS, sigaraya alternatif olarak sunulan bir üründür. Ancak, daha az zararlı olduğu yönündeki iddialar kesin olarak kanıtlanmamıştır. Sigarayı bırakmak isteyen kişilerin öncelikle doktorlarına danışmaları ve nikotin bağımlılığından kurtulmak için tıbbi destek almaları önemlidir. [1]: https://www.muzzu.net/ [2]: https://www.muzzu.net/heets/
packnbagofficial
packnbagofficial posted this 11 November 2025
Hi Tobias, it sounds like there might be a compatibility or server-side issue when upgrading your Artisteer theme in Themler. You could try clearing your cache or re-uploading the theme files before upgrading again. It’s a bit like checking RSC boxes for sale — making sure everything is in good shape before you make the switch helps avoid unwanted surprises.
Hi Tobias, it sounds like there might be a compatibility or server-side issue when upgrading your Artisteer theme in Themler. You could try clearing your cache or re-uploading the theme files before upgrading again. It’s a bit like checking [RSC boxes for sale][1] — making sure everything is in good shape before you make the switch helps avoid unwanted surprises. [1]: https://packnbag.com.au/collections/rsc-boxes
