posted this
13 April 2022
Themler theme is set default, it doesn't overwrite any other themes, if you do not physically replace the theme folders or add a new one with the same name. On the other hand, there should be automatical backup themes created for example, when Themler theme is updated. Do you see any of them in your Themes section in Wordpress or if you access the website via FTP?
