debug mode
doganayemrah
doganayemrah posted this 10 May 2022
Hello, to be able to install the following plugin. How can I enable 'debug mode' for the theme? for Joomla
thanks
https://www.extnbakers.com/extensions/eb-whatsapp-chat
Hello, to be able to install the following plugin. How can I enable 'debug mode' for the theme? for Joomla thanks https://www.extnbakers.com/extensions/eb-whatsapp-chat
jeanmarcvieux
jeanmarcvieux posted this 10 May 2022
For this module it's just recommandation you can display it where you want, and call it with custom button or link.
You can display this module in custom position. Just create a position by typing a custom name in the position dropdown. Hit enter then save. (Your new position is created).
You can also create a position in template footer and assign it to the module.
Hello, For this module it's just recommandation you can display it where you want, and call it with custom button or link. You can display this module in custom position. Just create a position by typing a custom name in the position dropdown. Hit enter then save. (Your new position is created). You can also create a position in template footer and assign it to the module.
doganayemrah
doganayemrah posted this 18 May 2022
I solved the problem.
