Access to theme editor
jeanmarcvieux
jeanmarcvieux posted this 27 May 2022
I encouter an issue that I have never seen before (all my themler themes are involved).
Do you think Its on hosting side ?
PHP verion : 7.4
Joomla : 3.10
Themler : v.547
Did you already see this kind of issue ?
Best regards
Jean-Marc
Site
[PHP_ERROR]{"message":"\n\nOS: Linux webdb15.lwspanel.com 5.10.0-14-amd64 #1 SMP Debian 5.10.113-1 (2022-04-29) x86_64\nPHP: 7.4.29\nerror handler: strpos(): Non-string needles will be interpreted as strings in the future. Use an explicit chr() call to preserve the current behavior\nArray\n(\n [path] => /htdocs/dev/mystery/cms/templates/untitled/plugins/button\n [mode] => 493\n [nested] => 0\n [parent] => /htdocs/dev/mystery/cms/templates/untitled/plugins\n [obd] => /HTDOCS:/htdocs:/var/www/intelartifice.fr/htdocs:/var/www/intelartifice.fr/tmp:/var/www/intelartifice.fr/exec_dir:/var/www/intelartifice.fr/php-session:/var/lib/lws/:/usr/base/var/lib/lws:/var/lib/apps/:/usr/base/var/lib/apps:/htdocs:/tmp:/exec_dir:/php-session:/usr/share/php:/etc/pki/tls/certs:/etc/ssl/certs:/var/www/intelartifice.fr/log/access.log:/var/www/intelartifice.fr/log/access.log:/var/www/intelartifice.fr/log/error.log:/var/www/intelartifice.fr/log/error.log\n [obdSeparator] => :\n [obdArray] => Array\n (\n [0] => /HTDOCS\n [1] => /htdocs\n [2] => /var/www/intelartifice.fr/htdocs\n [3] => /var/www/intelartifice.fr/tmp\n [4] => /var/www/intelartifice.fr/exec_dir\n [5] => /var/www/intelartifice.fr/php-session\n [6] => /var/lib/lws/\n [7] => /usr/base/var/lib/lws\n [8] => /var/lib/apps/\n [9] => /usr/base/var/lib/apps\n [10] => /htdocs\n [11] => /tmp\n [12] => /exec_dir\n [13] => /php-session\n [14] => /usr/share/php\n [15] => /etc/pki/tls/certs\n [16] => /etc/ssl/certs\n [17] => /var/www/intelartifice.fr/log/access.log\n [18] => /var/www/intelartifice.fr/log/access.log\n [19] => /var/www/intelartifice.fr/log/error.log\n [20] => /var/www/intelartifice.fr/log/error.log\n )\n\n [inBaseDir] => \n [test] => /HTDOCS\n)\n Callstack: \n -> strpos('/htdocs/dev/mystery/cms/templates/untitled/plugins/button', false)\n -> Joomla\Filesystem\Folder::create('/htdocs/dev/mystery/cms/templates/untitled/plugins/button')\n -> Joomla\Filesystem\File::write('/htdocs/dev/mystery/cms/templates/untitled/plugins//button/index.html', '
Hello, I encouter an issue that I have never seen before (all my themler themes are involved). Do you think Its on hosting side ? PHP verion : 7.4 Joomla : 3.10 Themler : v.547 Did you already see this kind of issue ? Best regards Jean-Marc Site [PHP_ERROR]{"message":"\n\nOS: Linux webdb15.lwspanel.com 5.10.0-14-amd64 #1 SMP Debian 5.10.113-1 (2022-04-29) x86_64\nPHP: 7.4.29\nerror handler: strpos(): Non-string needles will be interpreted as strings in the future. Use an explicit chr() call to preserve the current behavior\nArray\n(\n [path] => \/htdocs\/dev\/mystery\/cms\/templates\/untitled\/plugins\/button\n [mode] => 493\n [nested] => 0\n [parent] => \/htdocs\/dev\/mystery\/cms\/templates\/untitled\/plugins\n [obd] => \/HTDOCS:\/htdocs:\/var\/www\/intelartifice.fr\/htdocs:\/var\/www\/intelartifice.fr\/tmp:\/var\/www\/intelartifice.fr\/exec_dir:\/var\/www\/intelartifice.fr\/php-session:\/var\/lib\/lws\/:\/usr\/base\/var\/lib\/lws:\/var\/lib\/apps\/:\/usr\/base\/var\/lib\/apps:\/htdocs:\/tmp:\/exec_dir:\/php-session:\/usr\/share\/php:\/etc\/pki\/tls\/certs:\/etc\/ssl\/certs:\/var\/www\/intelartifice.fr\/log\/access.log:\/var\/www\/intelartifice.fr\/log\/access.log:\/var\/www\/intelartifice.fr\/log\/error.log:\/var\/www\/intelartifice.fr\/log\/error.log\n [obdSeparator] => :\n [obdArray] => Array\n (\n [0] => \/HTDOCS\n [1] => \/htdocs\n [2] => \/var\/www\/intelartifice.fr\/htdocs\n [3] => \/var\/www\/intelartifice.fr\/tmp\n [4] => \/var\/www\/intelartifice.fr\/exec_dir\n [5] => \/var\/www\/intelartifice.fr\/php-session\n [6] => \/var\/lib\/lws\/\n [7] => \/usr\/base\/var\/lib\/lws\n [8] => \/var\/lib\/apps\/\n [9] => \/usr\/base\/var\/lib\/apps\n [10] => \/htdocs\n [11] => \/tmp\n [12] => \/exec_dir\n [13] => \/php-session\n [14] => \/usr\/share\/php\n [15] => \/etc\/pki\/tls\/certs\n [16] => \/etc\/ssl\/certs\n [17] => \/var\/www\/intelartifice.fr\/log\/access.log\n [18] => \/var\/www\/intelartifice.fr\/log\/access.log\n [19] => \/var\/www\/intelartifice.fr\/log\/error.log\n [20] => \/var\/www\/intelartifice.fr\/log\/error.log\n )\n\n [inBaseDir] => \n [test] => \/HTDOCS\n)\n Callstack: \n -> strpos('\/htdocs\/dev\/mystery\/cms\/templates\/untitled\/plugins\/button', false)\n -> Joomla\\Filesystem\\Folder::create('\/htdocs\/dev\/mystery\/cms\/templates\/untitled\/plugins\/button')\n -> Joomla\\Filesystem\\File::write('\/htdocs\/dev\/mystery\/cms\/templates\/untitled\/plugins\/\/button\/index.html', '
9 Comments
Support Team posted this 27 May 2022
Hello Jean-Marc,
What was changed before the issue appeared? Any plugin/component installed/updated, Joomla or PHP updated, server provider changed? Any manual changes in theme files?
Hello Jean-Marc, What was changed before the issue appeared? Any plugin/component installed/updated, Joomla or PHP updated, server provider changed? Any manual changes in theme files? Sincerely, Nettie
jeanmarcvieux
Hello Nettie,
Nope, nothing change. All site with themler on the server have the same issue.
I moved on of them and miracle no issue. I guess this server side, I asked to my hosting service, they don't understand too.
Anyway, I'm working on the other VM waiting I find the soluce.
Jean-Marc
Hello Nettie, Nope, nothing change. All site with themler on the server have the same issue. I moved on of them and miracle no issue. I guess this server side, I asked to my hosting service, they don't understand too. Anyway, I'm working on the other VM waiting I find the soluce. Jean-Marc
Support Team posted this 30 May 2022
Hi Jean-Marc,
Please find the latest version of Themler for Joomla default theme attached. Please try installing it and let us know if the issue is reproducible with it as well.
Hi Jean-Marc, Please find the latest version of Themler for Joomla default theme attached. Please try installing it and let us know if the issue is reproducible with it as well. Sincerely, Nettie
jeanmarcvieux
jeanmarcvieux posted this 30 May 2022
Hello NEttie,
Thanks for the template updated. But finally i'm sure that is hosting side. I've migrated the site on two different environments and I didn't have any error.
I'll give you some news when my host is set.
Hello NEttie, Thanks for the template updated. But finally i'm sure that is hosting side. I've migrated the site on two different environments and I didn't have any error. I'll give you some news when my host is set.
Hi Jean-Marc,
Thanks for details. We will be waiting for your further results.
Hi Jean-Marc, Thanks for details. We will be waiting for your further results. Sincerely, Nettie
jeanmarcvieux
jeanmarcvieux posted this 31 May 2022
Hello Nettie,
My website host says it's template editor problem with some deprecated fonction.
Honestly I don't understand why on another host or VPS all goes well.
Anyway, I put here the message error with deprecated argument at the end of the message. May be could you have some more information and why not give me a solution.
THanks again
Site
[PHP_ERROR]{"message":"\n\nOS: Linux webdb15.lwspanel.com 5.10.0-14-amd64 #1 SMP Debian 5.10.113-1 (2022-04-29) x86_64\nPHP: 7.4.29\nerror handler: strpos(): Non-string needles will be interpreted as strings in the future. Use an explicit chr() call to preserve the current behavior\nArray\n(\n [path] => /htdocs/dev/wellpharm/templates/untitled/plugins/button\n [mode] => 493\n [nested] => 2\n [parent] => /htdocs/dev/wellpharm/templates/untitled/plugins\n [obd] => /HTDOCS:/htdocs:/var/www/intelartifice.fr/htdocs:/var/www/intelartifice.fr/tmp:/var/www/intelartifice.fr/exec_dir:/var/www/intelartifice.fr/php-session:/var/lib/lws/:/usr/base/var/lib/lws:/var/lib/apps/:/usr/base/var/lib/apps:/htdocs:/tmp:/exec_dir:/php-session:/usr/share/php:/etc/pki/tls/certs:/etc/ssl/certs:/var/www/intelartifice.fr/log/access.log:/var/www/intelartifice.fr/log/access.log:/var/www/intelartifice.fr/log/error.log:/var/www/intelartifice.fr/log/error.log\n [obdSeparator] => :\n [obdArray] => Array\n (\n [0] => /HTDOCS\n [1] => /htdocs\n [2] => /var/www/intelartifice.fr/htdocs\n [3] => /var/www/intelartifice.fr/tmp\n [4] => /var/www/intelartifice.fr/exec_dir\n [5] => /var/www/intelartifice.fr/php-session\n [6] => /var/lib/lws/\n [7] => /usr/base/var/lib/lws\n [8] => /var/lib/apps/\n [9] => /usr/base/var/lib/apps\n [10] => /htdocs\n [11] => /tmp\n [12] => /exec_dir\n [13] => /php-session\n [14] => /usr/share/php\n [15] => /etc/pki/tls/certs\n [16] => /etc/ssl/certs\n [17] => /var/www/intelartifice.fr/log/access.log\n [18] => /var/www/intelartifice.fr/log/access.log\n [19] => /var/www/intelartifice.fr/log/error.log\n [20] => /var/www/intelartifice.fr/log/error.log\n )\n\n [inBaseDir] => \n [test] => /HTDOCS\n)\n Callstack: \n -> strpos('/htdocs/dev/wellpharm/templates/untitled/plugins/button', false)\n -> Joomla\Filesystem\Folder::create('/htdocs/dev/wellpharm/templates/untitled/plugins/button', 493)\n -> Joomla\Filesystem\Folder::create('/htdocs/dev/wellpharm/templates/untitled/plugins/button/language', 493)\n -> Joomla\Filesystem\Folder::create('/htdocs/dev/wellpharm/templates/untitled/plugins/button/language/en-GB')\n -> Joomla\Filesystem\File::write('/htdocs/dev/wellpharm/templates/untitled/plugins//button/language/en-GB/en-GB.plg_editors-xtd_themle...', 'PLG_EDITORS-XTD_THEMLERBUTTON=\"Button - Themler Content Editor\"\nPLG_EDITORS-XTD_THEMLERBUTTON_XML_DE...')\n -> Joomla\Archive\Zip::extractNative('/htdocs/dev/wellpharm/templates/untitled/plugins/button.zip', '/htdocs/dev/wellpharm/templates/untitled/plugins/')\n -> Joomla\Archive\Zip::extract('/htdocs/dev/wellpharm/templates/untitled/plugins/button.zip', '/htdocs/dev/wellpharm/templates/untitled/plugins/')\n -> Joomla\Archive\Archive::extract('/htdocs/dev/wellpharm/templates/untitled/plugins/button.zip', '/htdocs/dev/wellpharm/templates/untitled/plugins/')\n -> JArchive::extract('/htdocs/dev/wellpharm/templates/untitled/plugins/button.zip', '/htdocs/dev/wellpharm/templates/untitled/plugins/')\n -> JFormFieldPlugins::_checkPlugins('untitled')\n -> JFormFieldPlugins::getInput()\n -> Joomla\CMS\Form\FormField::renderField()\n -> include('/htdocs/dev/wellpharm/layouts/joomla/edit/fieldset.php')\n -> Joomla\CMS\Layout\FileLayout::render(TemplatesViewStyle(...) { ... })\n -> Joomla\CMS\Layout\LayoutHelper::render('joomla.edit.fieldset', TemplatesViewStyle(...) { ... })\n -> include('/htdocs/dev/wellpharm/administrator/components/com_templates/views/style/tmpl/edit.php')\n -> Joomla\CMS\MVC\View\HtmlView::loadTemplate(NULL)\n -> Joomla\CMS\MVC\View\HtmlView::display(NULL)\n -> TemplatesViewStyle::display()\n -> Joomla\CMS\MVC\Controller\BaseController::display()\n -> TemplatesController::display()\n -> Joomla\CMS\MVC\Controller\BaseController::execute('')\n -> require_once('/htdocs/dev/wellpharm/administrator/components/com_templates/templates.php')\n -> Joomla\CMS\Component\ComponentHelper::executeComponent('/htdocs/dev/wellpharm/administrator/components/com_templates/templates.php')\n -> Joomla\CMS\Component\ComponentHelper::renderComponent('com_templates')\n -> Joomla\CMS\Application\AdministratorApplication::dispatch()\n -> Joomla\CMS\Application\AdministratorApplication::doExecute()\n -> Joomla\CMS\Application\CMSApplication::execute()\n\n\n","type":"E_DEPRECATED","file":"/htdocs/dev/wellpharm/libraries/vendor/joomla/filesystem/src/Folder.php","line":193}[PHP_ERROR]
Hello Nettie, My website host says it's template editor problem with some deprecated fonction. Honestly I don't understand why on another host or VPS all goes well. Anyway, I put here the message error with deprecated argument at the end of the message. May be could you have some more information and why not give me a solution. THanks again Site [PHP_ERROR]{"message":"\n\nOS: Linux webdb15.lwspanel.com 5.10.0-14-amd64 #1 SMP Debian 5.10.113-1 (2022-04-29) x86_64\nPHP: 7.4.29\nerror handler: strpos(): Non-string needles will be interpreted as strings in the future. Use an explicit chr() call to preserve the current behavior\nArray\n(\n [path] => \/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button\n [mode] => 493\n [nested] => 2\n [parent] => \/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\n [obd] => \/HTDOCS:\/htdocs:\/var\/www\/intelartifice.fr\/htdocs:\/var\/www\/intelartifice.fr\/tmp:\/var\/www\/intelartifice.fr\/exec_dir:\/var\/www\/intelartifice.fr\/php-session:\/var\/lib\/lws\/:\/usr\/base\/var\/lib\/lws:\/var\/lib\/apps\/:\/usr\/base\/var\/lib\/apps:\/htdocs:\/tmp:\/exec_dir:\/php-session:\/usr\/share\/php:\/etc\/pki\/tls\/certs:\/etc\/ssl\/certs:\/var\/www\/intelartifice.fr\/log\/access.log:\/var\/www\/intelartifice.fr\/log\/access.log:\/var\/www\/intelartifice.fr\/log\/error.log:\/var\/www\/intelartifice.fr\/log\/error.log\n [obdSeparator] => :\n [obdArray] => Array\n (\n [0] => \/HTDOCS\n [1] => \/htdocs\n [2] => \/var\/www\/intelartifice.fr\/htdocs\n [3] => \/var\/www\/intelartifice.fr\/tmp\n [4] => \/var\/www\/intelartifice.fr\/exec_dir\n [5] => \/var\/www\/intelartifice.fr\/php-session\n [6] => \/var\/lib\/lws\/\n [7] => \/usr\/base\/var\/lib\/lws\n [8] => \/var\/lib\/apps\/\n [9] => \/usr\/base\/var\/lib\/apps\n [10] => \/htdocs\n [11] => \/tmp\n [12] => \/exec_dir\n [13] => \/php-session\n [14] => \/usr\/share\/php\n [15] => \/etc\/pki\/tls\/certs\n [16] => \/etc\/ssl\/certs\n [17] => \/var\/www\/intelartifice.fr\/log\/access.log\n [18] => \/var\/www\/intelartifice.fr\/log\/access.log\n [19] => \/var\/www\/intelartifice.fr\/log\/error.log\n [20] => \/var\/www\/intelartifice.fr\/log\/error.log\n )\n\n [inBaseDir] => \n [test] => \/HTDOCS\n)\n Callstack: \n -> strpos('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button', false)\n -> Joomla\\Filesystem\\Folder::create('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button', 493)\n -> Joomla\\Filesystem\\Folder::create('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button\/language', 493)\n -> Joomla\\Filesystem\\Folder::create('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button\/language\/en-GB')\n -> Joomla\\Filesystem\\File::write('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/\/button\/language\/en-GB\/en-GB.plg_editors-xtd_themle...', 'PLG_EDITORS-XTD_THEMLERBUTTON=\"Button - Themler Content Editor\"\nPLG_EDITORS-XTD_THEMLERBUTTON_XML_DE...')\n -> Joomla\\Archive\\Zip::extractNative('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button.zip', '\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/')\n -> Joomla\\Archive\\Zip::extract('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button.zip', '\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/')\n -> Joomla\\Archive\\Archive::extract('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button.zip', '\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/')\n -> JArchive::extract('\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/button.zip', '\/htdocs\/dev\/wellpharm\/templates\/untitled\/plugins\/')\n -> JFormFieldPlugins::_checkPlugins('untitled')\n -> JFormFieldPlugins::getInput()\n -> Joomla\\CMS\\Form\\FormField::renderField()\n -> include('\/htdocs\/dev\/wellpharm\/layouts\/joomla\/edit\/fieldset.php')\n -> Joomla\\CMS\\Layout\\FileLayout::render(TemplatesViewStyle(...) { ... })\n -> Joomla\\CMS\\Layout\\LayoutHelper::render('joomla.edit.fieldset', TemplatesViewStyle(...) { ... })\n -> include('\/htdocs\/dev\/wellpharm\/administrator\/components\/com_templates\/views\/style\/tmpl\/edit.php')\n -> Joomla\\CMS\\MVC\\View\\HtmlView::loadTemplate(NULL)\n -> Joomla\\CMS\\MVC\\View\\HtmlView::display(NULL)\n -> TemplatesViewStyle::display()\n -> Joomla\\CMS\\MVC\\Controller\\BaseController::display()\n -> TemplatesController::display()\n -> Joomla\\CMS\\MVC\\Controller\\BaseController::execute('')\n -> require_once('\/htdocs\/dev\/wellpharm\/administrator\/components\/com_templates\/templates.php')\n -> Joomla\\CMS\\Component\\ComponentHelper::executeComponent('\/htdocs\/dev\/wellpharm\/administrator\/components\/com_templates\/templates.php')\n -> Joomla\\CMS\\Component\\ComponentHelper::renderComponent('com_templates')\n -> Joomla\\CMS\\Application\\AdministratorApplication::dispatch()\n -> Joomla\\CMS\\Application\\AdministratorApplication::doExecute()\n -> Joomla\\CMS\\Application\\CMSApplication::execute()\n\n\n","type":"E_DEPRECATED","file":"\/htdocs\/dev\/wellpharm\/libraries\/vendor\/joomla\/filesystem\/src\/Folder.php","line":193}[PHP_ERROR]
Support Team posted this 02 June 2022
Most likely, it is related to PHP used on the server. Theoretically, you may try downgrading PHP to 7.3 or 7.2 there to see if there is any difference. On the other hand, Themler for Joomla 3.10 supports PHP 7.4, but some particular server settings may influence the issue...
Hello, Most likely, it is related to PHP used on the server. Theoretically, you may try downgrading PHP to 7.3 or 7.2 there to see if there is any difference. On the other hand, Themler for Joomla 3.10 supports PHP 7.4, but some particular server settings may influence the issue... Sincerely, Nettie
caris040
caris040 posted this 01 January 2026
https://droomit.com/read-blog/5506
https://www.doconvo.com/blogs/667/AB-731-Certification-Exam-Preparation-with-CertsOut
https://lebanonhub.app/blogs/770179/Why-Choose-CertsOut-for-AB-731-Exam-Preparation
https://www.login.ps/blogs/130218/Why-Choose-CertsOut-for-AB-731-Exam-Preparation
https://hardcoredumper.com/showthread.php?tid=187286
https://droomit.com/read-blog/5506 https://www.doconvo.com/blogs/667/AB-731-Certification-Exam-Preparation-with-CertsOut https://lebanonhub.app/blogs/770179/Why-Choose-CertsOut-for-AB-731-Exam-Preparation https://www.login.ps/blogs/130218/Why-Choose-CertsOut-for-AB-731-Exam-Preparation https://hardcoredumper.com/showthread.php?tid=187286
tdee9812
tdee9812 posted this 24 February 2026
Enquiry Medical is a modern private clinic management software designed to simplify daily operations for healthcare providers. This practice management software for private clinics streamlines appointment scheduling, video consultations, 24/7 online bookings, billing, and secure patient records in one cloud-based platform.
Enquiry Medical is a modern [private clinic management software][1] designed to simplify daily operations for healthcare providers. This practice management software for private clinics streamlines appointment scheduling, video consultations, 24/7 online bookings, billing, and secure patient records in one cloud-based platform. [1]: https://enquirymedical.com/
