Server Error
cgerauy
cgerauy posted this 11 June 2022
I am trying to change an image in a slider.
When I select the new image i gives me a Server Error: generator render result is undefined hhtps://generator-de.themler.io/render
It is impossible even to dismiss the error.
Trying to access that url gives this message: {"status":"not initialized"}
Please, How can I fix this?
Thanks in advance.
I am trying to change an image in a slider. When I select the new image i gives me a Server Error: generator render result is undefined hhtps://generator-de.themler.io/render It is impossible even to dismiss the error. Trying to access that url gives this message: {"status":"not initialized"} Please, How can I fix this? Thanks in advance.
48 Comments
A12 Web Studio
A12 Web Studio posted this 13 June 2022
Hi there,
I have the same problem
Can you help us?
Hi there, I have the same problem Can you help us?
SleeboomJ
SleeboomJ posted this 13 June 2022
I have the same issue since today 13 june 2022!
Please help me fixing this problem soon.
kind regards,
Jan
Hi I have the same issue since today 13 june 2022! Please help me fixing this problem soon. kind regards, Jan
Pulswerk
Pulswerk posted this 13 June 2022
Same here, I can not work on my template right now.
apps5
apps5 posted this 13 June 2022
Same here on Joomla. Online and Offline same Problem!
YCW
YCW posted this 13 June 2022
Same htps://generator-de.themler.io/render error
goldentrip.www
goldentrip.www posted this 13 June 2022
Dear Themler support. Maybe you should write some comment about this situiation...? Everyone has the same problem from 3 days right now...
enanzer
enanzer posted this 13 June 2022
The problem exists since Friday evening, until today no improvement in sight.
Themler support, it would be about time to show a reaction...
The problem exists since Friday evening, until today no improvement in sight. Themler support, it would be about time to show a reaction...
order21
order21 posted this 13 June 2022
Themler support, need a solution asap.
Same here on Joomla. Themler support, need a solution asap.
herman
herman posted this 13 June 2022
Also have the same problem since Sunday 12 June
copywriter
copywriter posted this 13 June 2022
The same problem ,it is needs to be solved promptly ...I can't work on any project, which is really a problem !!!!!
@ITS
@ITS posted this 13 June 2022
Same Problem.
Please fix it ! Urgend !
Same Problem. Please fix it ! Urgend !
Seagull Experts®
Seagull Experts® posted this 13 June 2022
Team Themler.
Facing same issue.
Team Themler. Facing same issue.
@ITS
I need remove one Slider (the first)
Please Support ASAP !
Can i remove in the Code without Themler Editor ? Where?
I need remove one Slider (the first) Please Support ASAP ! Can i remove in the Code without Themler Editor ? Where?
tactwire360
tactwire360 posted this 13 June 2022
Same issue here, I also want to point out how they blatantly ignored a ticket of mine a few years ago that actually is related to this. Back in 2018, I pointed out that it was absolutely horrendous that we had to be signed in and authenticated to billion in order to save or export our templates, they responded by saying there was nothing wrong with my subscription and I replied again and never got another one. I will post the content of those posts here.
Posted by me in a private support ticket October 7 2018
I e-mailed what is below to you on 8/10/2018 to support@billiondigital.com. I forgot about it until now since I started getting messages from Artisteer about a new product that they are making and it made me remember:
We pay for your top tier package and were ground to a halt when your web-server went down and we were not able to authenticate to "Verify" our license. I find it absolutely unacceptable that if your server goes down that we cannot save any changes or export our templates. Your license structure needs to be re-made. I e-mailed what is below to you on 8/10/2018 to support@billiondigital.com. I forgot about it until now since I started getting messages from Artisteer about a new product that they are making and it made me remember:
This was their reply on October 9 2018
Hi David,
I'm not sure that I fully understand your request.
You have an active Themler Pro subscription and in general the moment your make a purchase your license is already 'verified' so there is no need for any further actions.
Sometimes we may experience technical issues but they only affect using Themler and not your subscription status.
Ivan
Posted by me as a reply on October 9 2018
Then you really don't understand. Back on 8/9/2018, you had a server outage. We could not log in to the licensing server through our websites to authenticate our subscription so we were unable to make changes to our sites. That is the e-mail I sent you on 8/10/2018 that I never got a response from. I am asking you to do something different in licensing than having to authenticate to a external server like that. I actually made that pretty clear in the e-mail and post above. You should know how your licensing server operates, and if it goes down it affects all of your customers. We mostly work on our stuff at all hours, depending on the request and the time needed to perform it. I do hope this post is clear enough for you.
They did not reply after this
This is not the first time that this has happened, and I really wish I would have opened a ticket each and every time that it did, but I was so frustrated with their slowness and apparent lack of understanding of the issue. The response to our message comes across as someone that does not understand how the licensing of their product works, I have been infuriated that this requires an ACTIVE Internet connection for something that I have paid for and relies on THEIR server to be in operation perpetually in order for us to function as a business. I would be fine with some type of license fine that can be installed into the editor so we can at least work offline and NOT be reliant on their server. Yes, this product works great when all the stars are in alignment, but they are so focused on such a bad licensing design it turns a decent product into an expensive paperweight that quickly, especially when they do not respond to urgent issues over the weekend and it takes them even this long at the start of the week to even respond, saying that we are working on it.
Same issue here, I also want to point out how they blatantly ignored a ticket of mine a few years ago that actually is related to this. Back in 2018, I pointed out that it was absolutely horrendous that we had to be signed in and authenticated to billion in order to save or export our templates, they responded by saying there was nothing wrong with my subscription and I replied again and never got another one. I will post the content of those posts here. Posted by me in a private support ticket October 7 2018 > I e-mailed what is below to you on 8/10/2018 to support@billiondigital.com. I forgot about it until now since I started getting messages from Artisteer about a new product that they are making and it made me remember: > > >We pay for your top tier package and were ground to a halt when your web-server went down and we were not able to authenticate to "Verify" our license. I find it absolutely unacceptable that if your server goes down that we cannot save any changes or export our templates. Your license structure needs to be re-made. I e-mailed what is below to you on 8/10/2018 to support@billiondigital.com. I forgot about it until now since I started getting messages from Artisteer about a new product that they are making and it made me remember: >We pay for your top tier package and were ground to a halt when your web-server went down and we were not able to authenticate to "Verify" our license. I find it absolutely unacceptable that if your server goes down that we cannot save any changes or export our templates. Your license structure needs to be re-made. This was their reply on October 9 2018 > Hi David, >I'm not sure that I fully understand your request. You have an active Themler Pro subscription and in general the moment your make a purchase your license is already 'verified' so there is no need for any further actions. >Sometimes we may experience technical issues but they only affect using Themler and not your subscription status. >Please let us know if you have any further questions. >Thanks, >Ivan Posted by me as a reply on October 9 2018 >Then you really don't understand. Back on 8/9/2018, you had a server outage. We could not log in to the licensing server through our websites to authenticate our subscription so we were unable to make changes to our sites. That is the e-mail I sent you on 8/10/2018 that I never got a response from. I am asking you to do something different in licensing than having to authenticate to a external server like that. I actually made that pretty clear in the e-mail and post above. You should know how your licensing server operates, and if it goes down it affects all of your customers. We mostly work on our stuff at all hours, depending on the request and the time needed to perform it. I do hope this post is clear enough for you. >Thank you, They did not reply after this - This is not the first time that this has happened, and I really wish I would have opened a ticket each and every time that it did, but I was so frustrated with their slowness and apparent lack of understanding of the issue. The response to our message comes across as someone that does not understand how the licensing of their product works, I have been infuriated that this requires an ACTIVE Internet connection for something that I have paid for and relies on THEIR server to be in operation perpetually in order for us to function as a business. I would be fine with some type of license fine that can be installed into the editor so we can at least work offline and NOT be reliant on their server. Yes, this product works great when all the stars are in alignment, but they are so focused on such a bad licensing design it turns a decent product into an expensive paperweight that quickly, especially when they do not respond to urgent issues over the weekend and it takes them even this long at the start of the week to even respond, saying that we are working on it.
@ITS
So..
temporary solutions for all
I was tested - the Slider was only a Problem with Server-Connection with "Template Home"
You can remove and insert a Slider maybe on "Page Home" - here is no Server-Connection Problem.
for existing Slider, when you only remove a Slider Image.. you can remove Slides with the "Theme File Editor" (for Wordpress).
** Design > Theme-File-Editor > on right side in "templates" > Home Page Template (templates/front_1.php)**
Here can you remove the Slider(s) under < div class>
maybe the Slide with ID 10
            <div class=" bd-slide-10 bd-background-width  bd-slide item"  data-target="_self" >
    <div class="bd-container-inner">
        <div class="bd-container-inner-wrapper">
        </div>
    </div>
</div>
So.. temporary solutions for all I was tested - the Slider was only a Problem with Server-Connection with "Template Home" You can remove and insert a Slider maybe on "Page Home" - here is no Server-Connection Problem. for existing Slider, when you only remove a Slider Image.. you can remove Slides with the "Theme File Editor" (for Wordpress). ** Design > Theme-File-Editor > on right side in "templates" > Home Page Template (templates/front_1.php)** Here can you remove the Slider(s) under &lt; div class&gt; maybe the Slide with ID 10 <div class=" bd-slide-10 bd-background-width bd-slide item" data-target="_self" > <div class="bd-container-inner"> <div class="bd-container-inner-wrapper"> </div> </div> </div>
Seppe
Seppe posted this 13 June 2022
they probably have no exact timeframe when to fix it....
cynthia4
cynthia4 posted this 13 June 2022
Same problem here. Have you stopped giving support?
Hi, Same problem here. Have you stopped giving support?
tactwire360
My business partner is finally fed up and is now willing to discuss alternatives.
> Hi, > > Same problem here. Have you stopped giving support? My business partner is finally fed up and is now willing to discuss alternatives.
Pulswerk
Let's give the developers a bit of time. If your business partner considers alternativies, you should start considering other business partners who aren't looking for alternatives just because you didn't find a solution within 24 hours.
> > My business partner is finally fed up and is now willing to discuss alternatives. Let's give the developers a bit of time. If your business partner considers alternativies, you should start considering other business partners who aren't looking for alternatives just because you didn't find a solution within 24 hours.
goldentrip.www
The problem is somewhere else... Support didn't answer to anyone from 72 hours.
