Server Error
cgerauy
cgerauy posted this 11 June 2022
I am trying to change an image in a slider.
When I select the new image i gives me a Server Error: generator render result is undefined hhtps://generator-de.themler.io/render
It is impossible even to dismiss the error.
Trying to access that url gives this message: {"status":"not initialized"}
Please, How can I fix this?
Thanks in advance.
I am trying to change an image in a slider. When I select the new image i gives me a Server Error: generator render result is undefined hhtps://generator-de.themler.io/render It is impossible even to dismiss the error. Trying to access that url gives this message: {"status":"not initialized"} Please, How can I fix this? Thanks in advance.
48 Comments
tactwire360
tactwire360 posted this 13 June 2022
The problem is somewhere else... Support didn't answer to anyone from 72 hours.
I have not had them reply on a weekend day, and while it would have been great for them to reply to at least let people know they were working on it, but if you read my post above, I currently don't have that much faith in them.
> The problem is somewhere else... Support didn't answer to anyone from 72 hours. I have not had them reply on a weekend day, and while it would have been great for them to reply to at least let people know they were working on it, but if you read my post above, I currently don't have that much faith in them.
ideosiete
ideosiete posted this 13 June 2022
I hope this problem is resolved I can't upload images. How long have I been several days.
ideosiete
Try with this: smartslider 3
Axumedia
Axumedia posted this 13 June 2022
This seems to be a general issue on the server platform of themler. Here in the Netherlands I have the same issues.
The issue is getting worse and still no solution or reaction from Themler.
This seems to be a general issue on the server platform of themler. Here in the Netherlands I have the same issues. The issue is getting worse and still no solution or reaction from Themler.
ddobi
ddobi posted this 14 June 2022
I have the same problem, impossible to make themler work, it's blocked, no response from support for three days
kedud
kedud posted this 14 June 2022
It's not only slider, when I try add some new (not change), i also get this error.
aleks-karvelis
aleks-karvelis posted this 14 June 2022
При любых действиях выдает ошибку сервера. Тех поддержка молчит.
With any actions, it issues a server error. Tech support is silent.
При любых действиях выдает ошибку сервера. Тех поддержка молчит. With any actions, it issues a server error. Tech support is silent.
copywriter
copywriter posted this 14 June 2022
The support responded in another thread that developers are working on the problem. So let's hope it's really just a problem and Themler will continue to work. It's a great tool, I haven't found anything adequate for it yet.
Support Team posted this 14 June 2022
We are sorry for the temporary server issue. Our developers are already working at it and I will update this topic as soon as it is fixed.
Hello, We are sorry for the temporary server issue. Our developers are already working at it and I will update this topic as soon as it is fixed. Sincerely, Nettie
cgerauy
cgerauy posted this 15 June 2022
Dear Support,
I reported this issue 6 days ago and you took 5 days to show up.
It is clear that you are in a serious problem, and it’s also clear that this is not the best way to handle it.
In any crisis, information is key. Please, tell us what is happening and an estimated time to solve the problem.
We are not only your customers but your partners. We all also have projects and clients to respond to. Give us information so we can handle the situation with our customers.
Thanks in advance,
Dear Support, I reported this issue 6 days ago and you took 5 days to show up. It is clear that you are in a serious problem, and it’s also clear that this is not the best way to handle it. In any crisis, information is key. Please, tell us what is happening and an estimated time to solve the problem. We are not only your customers but your partners. We all also have projects and clients to respond to. Give us information so we can handle the situation with our customers. Thanks in advance,
laertsky
laertsky posted this 15 June 2022
Everything worked!!!!
Support Team posted this 16 June 2022
The issue is fixed. Just re-run Themler and re-load the theme.
If the issue is still present, for your website you may need to clear browser cache and re-run the theme.
For Themler desktop, if the issue is still present, please please try this way:
1) close Themler
4) start Themler again
Your existing themes will be inside the old Themler directory, you will need to zip-compress and import each of them.
As a rule, the issue shouldn't be present now by default, so please follow the steps above only in case you still see the message with "Server Error
generator render result is undefined https://generator-de.themler.io/render" or a very similar one.
Hello, The issue is fixed. Just re-run Themler and re-load the theme. If the issue is still present, for your website you may need to clear browser cache and re-run the theme. For Themler desktop, if the issue is still present, please please try this way: 1) close Themler 2) open Windows Explorer and type %LocalAppData% in the address bar 3) find & rename Themler directory 4) start Themler again Your existing themes will be inside the old Themler directory, you will need to zip-compress and import each of them. As a rule, the issue shouldn't be present now by default, so please follow the steps above only in case you still see the message with "Server Error generator render result is undefined https://generator-de.themler.io/render" or a very similar one. Sincerely, Nettie
cagota5135
cagota5135 posted this 16 May 2024
Verify the generator servicing. Please confirm that the generator service (https://generator-de.themler.io/render) is operational and free from any problems or outages duck life. To rule out any local connectivity issues, try viewing the URL from an other device or network.
Verify the generator servicing. Please confirm that the generator service (https://generator-de.themler.io/render) is operational and free from any problems or outages [duck life][1]. To rule out any local connectivity issues, try viewing the URL from an other device or network. [1]: https://ducklife.online/
trangthi19876
trangthi19876 posted this 18 September 2024
Refresh the Page: Sometimes, a simple refresh can resolve temporary issues.
Clear Browser Cache: Clearing the cache can help eliminate any corrupted files that might be causing the error.
Check Image Format: Ensure that the new image you are trying to upload is in a supported format (e.g., JPEG, PNG) and not too large in size.
Reinitialize the Generator: If you have access to the generator settings, try reinitializing or resetting it to see if that resolves the issue.
Fnaf 1
Check for Updates: Ensure that you are using the latest version of the software or platform hosting the slider.
Refresh the Page: Sometimes, a simple refresh can resolve temporary issues. Clear Browser Cache: Clearing the cache can help eliminate any corrupted files that might be causing the error. Check Image Format: Ensure that the new image you are trying to upload is in a supported format (e.g., JPEG, PNG) and not too large in size. Reinitialize the Generator: If you have access to the generator settings, try reinitializing or resetting it to see if that resolves the issue. [Fnaf 1][1] Check for Updates: Ensure that you are using the latest version of the software or platform hosting the slider. [1]: https://fnaf1.io/
vijaykumarsonkar844
vijaykumarsonkar844 posted this 18 February 2025
Viewers can watch matches as they happen on the field thanks to SportsFire's lag-free live TV experience. Because the Android operating system can connect to mobile devices and TVs, users can easily watch their favorite match from anywhere. SportsFire Apk
Viewers can watch matches as they happen on the field thanks to SportsFire's lag-free live TV experience. Because the Android operating system can connect to mobile devices and TVs, users can easily watch their favorite match from anywhere. [SportsFire Apk][1] [1]: https://sportsfire.dev/
vijaykumarsonkar844
Use the Dofu Sports APK to watch NFL, NBA, NHL, MLB, and NCAAF live streaming and scores for free.
Use the [Dofu Sports][1] APK to watch NFL, NBA, NHL, MLB, and NCAAF live streaming and scores for free. [1]: https://dofusports.org/
vijaykumarsonkar844
A feature-rich streaming app, Rapid Streamz provides access to live TV channels, sports, movies, and all other types of entertainment from different nations. Because of its user-friendly design and large library, it attracts new users and allows for endless streaming.
A feature-rich streaming app, [Rapid Streamz][1] provides access to live TV channels, sports, movies, and all other types of entertainment from different nations. Because of its user-friendly design and large library, it attracts new users and allows for endless streaming. [1]: https://rapidstreamz.vip/
vijaykumarsonkar844
vijaykumarsonkar844 posted this 02 March 2025
With a huge collection of films, TV series, and live channels at your fingertips, Blink Streamz APK is a ground-breaking app that aims to completely transform your entertainment experience. This app guarantees that you will never run out of entertainment to watch, regardless of your preference for action-packed blockbusters, compelling dramas, or live sporting events, thanks to its user-friendly layout and vast selection of content.
Blink Streamz's flexibility with a variety of devices is one of its best qualities; you can enjoy high-quality streaming on smartphones, tablets, and smart TVs. Finding new favorites is made simple by the app's intuitive navigation and tailored suggestions. Its powerful streaming technology ensures a continuous watching experience by reducing buffering.
With a huge collection of films, TV series, and live channels at your fingertips, [Blink Streamz][1] APK is a ground-breaking app that aims to completely transform your entertainment experience. This app guarantees that you will never run out of entertainment to watch, regardless of your preference for action-packed blockbusters, compelling dramas, or live sporting events, thanks to its user-friendly layout and vast selection of content. Blink Streamz's flexibility with a variety of devices is one of its best qualities; you can enjoy high-quality streaming on smartphones, tablets, and smart TVs. Finding new favorites is made simple by the app's intuitive navigation and tailored suggestions. Its powerful streaming technology ensures a continuous watching experience by reducing buffering. [1]: https://blinkstreamz.app/
victor04052024
victor04052024 posted this 23 July 2025
Your article is excellent. I really enjoyed reading your essay. This is a terrific resource for me Baseball Bros IO.
Your article is excellent. I really enjoyed reading your essay. This is a terrific resource for me [Baseball Bros IO][1]. [1]: https://baseball-game.io
caris040
caris040 posted this 07 January 2026
https://7sage.com/discussion/52842/zdte-dumps-zscaler-digital-transformation-engineer-certification-exam-guide-by-certsout
https://www.muvizu.com/wiki/wiki/1031/ad0-e724-dumps-adobe-commerce-developer-professional-certification-exam-gui
https://www.muvizu.com/wiki/wiki/1032/all-isaca-certification-exams-complete-exam-preparation-with-certsout
https://www.yelp.com/topic/san-francisco-how-to-pass-the-api-571-corrosion-and-materials-exam-in-2026-complete-preparation-guide
https://www.yelp.com/topic/san-francisco-new-year-bundleapps-review-2026-30-offer-all-otos-links-price-2
https://www.qatarliving.com/en/post/certsout-ns0-528-dumps-your-ultimate-exam-preparation-solution-1767679865257
https://droomit.com/read-blog/6160
https://www.qatarliving.com/en/post/kubernetes-administrator-cka-certified-kubernetes-administrator-program-by-certsout-1767589146673
https://7sage.com/discussion/52845/zdxa-certification-exam-preparation-with-certsout
https://www.instagram.com/p/DTHePqPjHXW/
https://www.instagram.com/p/DTHenIdDPkc/
https://steemit.com/exam/@shivamamin/formal-pen-and-paper-examinations
https://steemit.com/howto/@farrahyoung/how-to-pass-your-exams-with-ease
https://portfolium.com/entry/ncie-data-protection-ns0-528-exam-dumps-certsout
https://portfolium.com/entry/autodesk-certified-professional-ns0-528-exam-dumps
https://stackblitz.com/@caris040/collections/f5cab1-exam-preparation-by-certsout-new-year-sale-70-off
https://stackblitz.com/@caris040/collections/4a0-d01-exam-dumps-by-certsout-new-year-sale-70-off
https://www.pearltrees.com/jenismith147/item772051437
https://www.pearltrees.com/jenismith147/item772051490
https://my.talladega.edu/ICS/portletview/Academics/BUS/BUS__368/2015_SU-BUS__368-S2F/Blog_43.jnz?portlet=Blog_43&screen=View+Post&screenType=next&&Id=1c27ed92-4759-4725-ad51-4d2d9fbdddcd
https://my.talladega.edu/ICS/portletview/Academics/BUS/BUS__368/2015_SU-BUS__368-S2F/Blog_43.jnz?portlet=Blog_43&screen=View+Post&screenType=next&&Id=9963f9e5-0fca-47cf-a21f-9c6cfd51aa8a
http://www.arwen-undomiel.com/forum/viewtopic.php?f=29&t=348086
https://roshchinskij.forum24.ru/?1-14-0-00000118-000-0-0-1767675300
https://themighty.com/u/wgucertsout/
https://www.riachaonet.com.br/portal/secretaria-solicita-a-camara-regularizacao-da-getulio-vargas-da-situacao-de-rua-para-avenida/#comment-630114
https://blog.fusion.ng/2024/06/12/what-nigerian-parents-need-to-know-about-homeschooling/comment-page-168/
https://www.decouvrir-chateaugiron.fr/entreprises/certsout-vcp-vcf-administrator-2v0-17-25-exam-preparation-guide
https://www.chambers.com.au/forum/view_post.php?frm=2&pstid=11825
https://healingxchange.ning.com/forum/topics/elevate-your-global-perspective-with-a-uk-education
https://www.scoop.it/topic/hannah-smith-by-dumpscollection-com-gmail-com/p/4169581244/2026/01/06/real-salesforce-agentforce-specialist-exam-questions-answers-certsout
https://www.freewebmarks.com/story/real-comptia-sy0-701-exam-questions-answers-certsout
https://www.pbookmarking.com/story/real-vmware-2v0-13-25-exam-questions-answers-certsout
https://revcon201certsout.quora.com/
https://securesoftwaredesign.quora.com/
https://pt0003certsout.quora.com/
https://7sage.com/discussion/52842/zdte-dumps-zscaler-digital-transformation-engineer-certification-exam-guide-by-certsout https://www.muvizu.com/wiki/wiki/1031/ad0-e724-dumps-adobe-commerce-developer-professional-certification-exam-gui https://www.muvizu.com/wiki/wiki/1032/all-isaca-certification-exams-complete-exam-preparation-with-certsout https://www.yelp.com/topic/san-francisco-how-to-pass-the-api-571-corrosion-and-materials-exam-in-2026-complete-preparation-guide https://www.yelp.com/topic/san-francisco-new-year-bundleapps-review-2026-30-offer-all-otos-links-price-2 https://www.qatarliving.com/en/post/certsout-ns0-528-dumps-your-ultimate-exam-preparation-solution-1767679865257 https://droomit.com/read-blog/6160 https://www.qatarliving.com/en/post/kubernetes-administrator-cka-certified-kubernetes-administrator-program-by-certsout-1767589146673 https://7sage.com/discussion/52845/zdxa-certification-exam-preparation-with-certsout https://www.instagram.com/p/DTHePqPjHXW/ https://www.instagram.com/p/DTHenIdDPkc/ https://steemit.com/exam/@shivamamin/formal-pen-and-paper-examinations https://steemit.com/howto/@farrahyoung/how-to-pass-your-exams-with-ease https://portfolium.com/entry/ncie-data-protection-ns0-528-exam-dumps-certsout https://portfolium.com/entry/autodesk-certified-professional-ns0-528-exam-dumps https://stackblitz.com/@caris040/collections/f5cab1-exam-preparation-by-certsout-new-year-sale-70-off https://stackblitz.com/@caris040/collections/4a0-d01-exam-dumps-by-certsout-new-year-sale-70-off https://www.pearltrees.com/jenismith147/item772051437 https://www.pearltrees.com/jenismith147/item772051490 https://my.talladega.edu/ICS/_portletview_/Academics/BUS/BUS__368/2015_SU-BUS__368-S2F/Blog_43.jnz?portlet=Blog_43&screen=View+Post&screenType=next&&Id=1c27ed92-4759-4725-ad51-4d2d9fbdddcd https://my.talladega.edu/ICS/_portletview_/Academics/BUS/BUS__368/2015_SU-BUS__368-S2F/Blog_43.jnz?portlet=Blog_43&screen=View+Post&screenType=next&&Id=9963f9e5-0fca-47cf-a21f-9c6cfd51aa8a http://www.arwen-undomiel.com/forum/viewtopic.php?f=29&t=348086 https://roshchinskij.forum24.ru/?1-14-0-00000118-000-0-0-1767675300 https://themighty.com/u/wgucertsout/ https://www.riachaonet.com.br/portal/secretaria-solicita-a-camara-regularizacao-da-getulio-vargas-da-situacao-de-rua-para-avenida/#comment-630114 https://blog.fusion.ng/2024/06/12/what-nigerian-parents-need-to-know-about-homeschooling/comment-page-168/ https://www.decouvrir-chateaugiron.fr/entreprises/certsout-vcp-vcf-administrator-2v0-17-25-exam-preparation-guide https://www.chambers.com.au/forum/view_post.php?frm=2&pstid=11825 https://healingxchange.ning.com/forum/topics/elevate-your-global-perspective-with-a-uk-education https://www.scoop.it/topic/hannah-smith-by-dumpscollection-com-gmail-com/p/4169581244/2026/01/06/real-salesforce-agentforce-specialist-exam-questions-answers-certsout https://www.freewebmarks.com/story/real-comptia-sy0-701-exam-questions-answers-certsout https://www.pbookmarking.com/story/real-vmware-2v0-13-25-exam-questions-answers-certsout https://revcon201certsout.quora.com/ https://securesoftwaredesign.quora.com/ https://pt0003certsout.quora.com/
