Hi.
I want open new templates, or upgrade old and I have this errror (in attached picture).
I have to made something andf this is still to same..
Pls help
Hi.
Pls help
Urgent!
I too!
Please solve this issue,
Thank you!
It is a server error at Themler, nothing to do with browser cache or cookies. Themler would have to react to it, there are countless users who are affected! So you can do nothing more in Themler.
It is a server error at Themler, nothing to do with browser cache or cookies. Themler would have to react to it, there are countless users who are affected! So you can do nothing more in Themler.Hello,
We are sorry for the temporary server issue. Our developers are already working at it and I will update this topic as soon as it is fixed.
The issue is fixed. Just re-run Themler and re-load the theme.
If the issue is still present, for your website you may need to clear browser cache and re-run the theme.
For Themler desktop, if the issue is still present, please please try this way:
1) close Themler
4) start Themler again
Your existing themes will be inside the old Themler directory, you will need to zip-compress and import each of them.
As a rule, the issue shouldn't be present now by default, so please follow the steps above only in case you still see the message with "Server Error
generator render result is undefined https://generator-de.themler.io/render" or a very similar one.
