I am getting this error message when I try to edit in the template. Please see attached image.
SIncerely,
Cynthia
SIncerely,
Cynthia
We are sorry for the temporary server issue. Our developers are already working at it and I will update this topic as soon as it is fixed.
Any idea when it will be fixed? Right now I can't edit the template.
Hi, Any idea when it will be fixed? Right now I can't edit the template.Hello,
The issue is fixed. Just re-run Themler and re-load the theme.
If the issue is still present, for your website you may need to clear browser cache and re-run the theme.
For Themler desktop, if the issue is still present, please please try this way:
1) close Themler
4) start Themler again
Your existing themes will be inside the old Themler directory, you will need to zip-compress and import each of them.
As a rule, the issue shouldn't be present now by default, so please follow the steps above only in case you still see the message with "Server Error
generator render result is undefined https://generator-de.themler.io/render" or a very similar one.
Hi, I had no problem accessing the themes and all that but I had a different question which has not been answered. There is white space between the static module and the first blog post that is very visible when the screen size is MacBook Air size for example. How do I get rid of it? I even sent you a link (in a separate message) but no reply.
Hi, I had no problem accessing the themes and all that but I had a different question which has not been answered. There is white space between the static module and the first blog post that is very visible when the screen size is MacBook Air size for example. How do I get rid of it? I even sent you a link (in a separate message) but no reply.Hello,
We will answer you in separate topics.
