Server error not found: https://generator-de.themler.io/render
How to solve?
Hello, Server error not found: https://generator-de.themler.io/render How to solve?
How to solve?
Hello, Server error not found: https://generator-de.themler.io/render How to solve?It looks like it's on a specific page. I want to create the Blog page, Wordpress. When editing the layout, the number of columns, the error apears.
I updated also with beta update. No difference.
Regards Michel
It looks like it's on a specific page. I want to create the Blog page, Wordpress. When editing the layout, the number of columns, the error apears. I updated also with beta update. No difference. Regards MichelThe support responded in another thread that developers are working on the problem. So let's hope it's really just a problem and Themler will continue to work. It's a great tool, I haven't found anything adequate for it yet.
The support responded in another thread that developers are working on the problem. So let's hope it's really just a problem and Themler will continue to work. It's a great tool, I haven't found anything adequate for it yet.Hello,
We are sorry for the temporary server issue. Our developers are already working at it and I will update this topic as soon as it is fixed.
The issue is fixed. Just re-run Themler and re-load the theme.
If the issue is still present, for your website you may need to clear browser cache and re-run the theme.
For Themler desktop, if the issue is still present, please please try this way:
1) close Themler
4) start Themler again
Your existing themes will be inside the old Themler directory, you will need to zip-compress and import each of them.
As a rule, the issue shouldn't be present now by default, so please follow the steps above only in case you still see the message with "Server Error
generator render result is undefined https://generator-de.themler.io/render" or a very similar one.
The website generator-de.themler.io/render is a simple online tool for creating different text styles. One popular option is the Creepy text generator, which makes scary and horror-style text for fun designs, social media, or games. It is easy to use—just type your text and get instant results in a creepy style. https://cursedtextgenerator.us/
