quando provo a fare modifiche mi dice_
ERRORE SERVER
Not found
https://generator-de.themler.io/render
e si blocca!!!!
che vuol dire?
Grazie
ERRORE SERVER
Not found
e si blocca!!!!
che vuol dire?
Grazie
We are sorry for the temporary server issue. Our developers are already working at it and I will update this topic as soon as it is fixed.
The issue is fixed. Just re-run Themler and re-load the theme.
If the issue is still present, for your website you may need to clear browser cache and re-run the theme.
For Themler desktop, if the issue is still present, please please try this way:
1) close Themler
4) start Themler again
Your existing themes will be inside the old Themler directory, you will need to zip-compress and import each of them.
As a rule, the issue shouldn't be present now by default, so please follow the steps above only in case you still see the message with "Server Error
generator render result is undefined https://generator-de.themler.io/render" or a very similar one.
ok grazie il problema รจ risolto
ok grazie il problema è risolto
