Migration to Joomla 4
info1139
info1139 posted this 14 June 2022
I have more than 50 Joomla Themler sites. How to migrate the template to Joomla 4 version?
Regards Michel
Hello, I have more than 50 Joomla Themler sites. How to migrate the template to Joomla 4 version? Regards Michel
20 Comments
Support Team posted this 17 June 2022
Old themes are all for Joomla 3 and cannot be imported or converted for Joomla 4 automatically. The themes are completely different as if they were for different CMS's. That is why for Joomla 4 a separate theme should be downloaded and not just Joomla 3 theme with Themler update.
Here are possible ways to make creating themes easier (if they are made to re-create old themes):
- organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip
- there are Export / Import options available in the Posts tab to transfer Posts layout and styling
There is a separate Themler theme for Joomla 4. Currently it is in Beta. Please refer to this article for details: https://answers.themler.io/questions/212738/joomla-4-support-is-available-in-beta
There are several issues in it that should be fixed in the future update, so please try it with one theme first.
Hello, Old themes are all for Joomla 3 and cannot be imported or converted for Joomla 4 automatically. The themes are completely different as if they were for different CMS's. That is why for Joomla 4 a separate theme should be downloaded and not just Joomla 3 theme with Themler update. Here are possible ways to make creating themes easier (if they are made to re-create old themes): - organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip - there are Export / Import options available in the Posts tab to transfer Posts layout and styling There is a separate Themler theme for Joomla 4. Currently it is in Beta. Please refer to this article for details: https://answers.themler.io/questions/212738/joomla-4-support-is-available-in-beta There are several issues in it that should be fixed in the future update, so please try it with one theme first. Sincerely, Nettie
info1139
info1139 posted this 17 June 2022
Hello Nettie,
Ok, i'am going to try the import/export in the Sections, so i hope the work for the new theme in Joomla 4 is then minimal.
When is the Joomla 4 template ready for use (not Beta). I'm noticing that PHP 7.4 is EOL (28 Nov 2022), so i must migrate all sites before this date to PHP 8 and Joomla 4, that's a short time....
Regards Michel
Hello Nettie, Ok, i'am going to try the import/export in the Sections, so i hope the work for the new theme in Joomla 4 is then minimal. When is the Joomla 4 template ready for use (not Beta). I'm noticing that PHP 7.4 is EOL (28 Nov 2022), so i must migrate all sites before this date to PHP 8 and Joomla 4, that's a short time.... Regards Michel
Support Team posted this 21 June 2022
Hello Michel,
In the latest update as of Friday some fixes has been included, but we are still working at full Joomla 4 compatibility of Themler theme. On the other hand, main fixes to support PHP 8 with Joomla 3.x has been included into the mentioned update, so you may consider trying some of the themes with PHP 8. We recommend making a backup in any case.
Hello Michel, In the latest update as of Friday some fixes has been included, but we are still working at full Joomla 4 compatibility of Themler theme. On the other hand, main fixes to support PHP 8 with Joomla 3.x has been included into the mentioned update, so you may consider trying some of the themes with PHP 8. We recommend making a backup in any case. Sincerely, Nettie
info1139
info1139 posted this 21 June 2022
Hello Nettie,
Just the normal update, or must i choose the Beta update where PHP 8 for Joomla 3 is included?
Regards Michel
Hello Nettie, Just the normal update, or must i choose the Beta update where PHP 8 for Joomla 3 is included? Regards Michel
Yes, please enable Beta update notifications, you may then check to make sure you have v.547. You may disable the notifications any time later.
Hello, Yes, please enable Beta update notifications, you may then check to make sure you have v.547. You may disable the notifications any time later. Sincerely, Nettie
info1139
Hello Nettie,
I updated a site to Themler 5.4.7 with Joomla 3.10.9 and PHP 8.0.x but it chrashes with 0 - Unknown named parameter $title
No server logs. I changed the template to a default Joomla one and there is no error.
How to solve?
Regards Michel
Hello Nettie, I updated a site to Themler 5.4.7 with Joomla 3.10.9 and PHP 8.0.x but it chrashes with 0 - Unknown named parameter $title No server logs. I changed the template to a default Joomla one and there is no error. How to solve? Regards Michel
Support Team posted this 22 June 2022
Hello Michel,
Have you updated PHP version first or Themler theme first?
Hello Michel, Have you updated PHP version first or Themler theme first? Sincerely, Nettie
info1139
info1139 posted this 23 June 2022
I think, but not 100% sure, first updated themler, then PHP version.
How to solve?
Regards Michel
I think, but not 100% sure, first updated themler, then PHP version. How to solve? Regards Michel
info1139
info1139 posted this 06 July 2022
Hello Nettie,
What's the status of this thread?
Regards Michel
Hello Nettie, What's the status of this thread? Regards Michel
info1139
info1139 posted this 18 July 2022
Hello Nettie,
Updated now to v556 and there is no error with PHP 8.0.x
Ticket can be closed.
Regards Michel
Hello Nettie, Updated now to v556 and there is no error with PHP 8.0.x Ticket can be closed. Regards Michel
Support Team posted this 18 July 2022
Hello Michel,
Thanks for letting us know. Please feel free to contact us in any other case.
Hello Michel, Thanks for letting us know. Please feel free to contact us in any other case. Sincerely, Nettie
hebemiley
hebemiley posted this 07 November 2024
Migrating templates from Joomla 3 to Joomla 4 can be challenging, especially if you have more than 50 sites. Here are the key steps you should consider:
1. Check template compatibility: Make sure your current templates are compatible with Joomla 4. If you're using popular templates, check if there's a version available that supports Joomla 4. If not, you'll need to consider alternative Sprunked templates or updating your own templates.
2. Switch to the default template: During the migration, it is recommended to switch to the default Joomla 4 template, which is called Cassiopeia. If your template is not compatible, Joomla 4 will automatically switch to Cassiopeia.
Migrating templates from Joomla 3 to Joomla 4 can be challenging, especially if you have more than 50 sites. Here are the key steps you should consider: 1. Check template compatibility: Make sure your current templates are compatible with Joomla 4. If you're using popular templates, check if there's a version available that supports Joomla 4. If not, you'll need to consider alternative [Sprunked][1] templates or updating your own templates. 2. Switch to the default template: During the migration, it is recommended to switch to the default Joomla 4 template, which is called Cassiopeia. If your template is not compatible, Joomla 4 will automatically switch to Cassiopeia. [1]: https://sprunkedgame.com
donaldtev.en19.9.1
donaldtev.en19.9.1 posted this 11 November 2024
Migrating to Joomla 4 has been a smooth transition for my projects, offering improved speed and security. I appreciate its enhanced user interface and new features like a more flexible template system. The streamlined workflow and robust extensions make it a great choice for both developers and site administrators. Spectra Precision LL300N Laser Level w/ HL450 Receiver
Migrating to Joomla 4 has been a smooth transition for my projects, offering improved speed and security. I appreciate its enhanced user interface and new features like a more flexible template system. The streamlined workflow and robust extensions make it a great choice for both developers and site administrators. [Spectra Precision LL300N Laser Level w/ HL450 Receiver][1] [1]: https://allterracentral.com/field-supplies.html/lasers/laser-levels.html
gecam31691
gecam31691 posted this 12 November 2024
MiOcado is a dedicated online portal designed for employees of Ocado, a leading online grocery retailer. This digital platform provides a convenient and secure way to access essential information and tools, streamlining various aspects of work life.
https://www.miocado.co.uk/
MiOcado is a dedicated online portal designed for employees of Ocado, a leading online grocery retailer. This digital platform provides a convenient and secure way to access essential information and tools, streamlining various aspects of work life. https://www.miocado.co.uk/
Abbas Khan
Abbas Khan posted this 25 December 2025
The Manav Sampada UP Login 2025 process is very easy and secure, and to log in, users need to visit the official website where they will find the login option on the homepage, and employees must enter their User ID, Password, and Captcha code correctly to access their dashboard, and once logged in, they can view their complete service profile including name, designation, department, posting location, and employee M Sampada, and this login system is protected with strong security features to ensure that employee data remains safe and confidential.
The Manav Sampada UP Login 2025 process is very easy and secure, and to log in, users need to visit the official website where they will find the login option on the homepage, and employees must enter their User ID, Password, and Captcha code correctly to access their dashboard, and once logged in, they can view their complete service profile including name, designation, department, posting location, and employee **[M Sampada][1]**, and this login system is protected with strong security features to ensure that employee data remains safe and confidential. [1]: https://upmanavsampada.org/
chinahousehold
chinahousehold posted this 11 January 2026
https://paidforarticles.in/how-high-efficiency-modules-improve-returns-for-commercial-projects-933296
http://www.mocyc.com/board/43183/HowAutomatedProductionEnsuresGreaterModuleReliability
https://www.cssauw.org/forum/thread-41096-1-1
https://kumu.io/bothbest/temperature-coefficients-explained-for-everyday-consumers
https://bambooflooring.alboompro.com/post/low-lid-solar-panels-how-they-deliver-more-energy-from-day-one
https://www.auseka.com.au/blog/heat-resistant-solar-panels-top-features-to-look-for
https://kadrmaskreations.com/forum/topic/what-makes-a-solar-panel-high-performance-in-real-conditions/
https://www.bizthistown.com/discussions/how-robotics-and-automation-reduce-defects-in-solar-panels
https://sngine.fr/blogs/23156/Solar-Module-Efficiency-Myths-Every-Buyer-Should-Know
https://www.edufex.com/forums/discussion/general/the-hidden-role-of-automation-in-producing-high-efficiency-panels
https://arizonaadam.com/forum/topic/why-lower-temperature-coefficients-matter-in-hot-climates/
https://www.uscgq.com/forum/posts.php?forum=&id=629883
https://bothbestbambooflooring.tawk.help/article/the-benefits-of-n-type-topcon-modules-for-residential-systems
https://pad.degrowth.net/s/bO2jpZrqV
https://hedgedoc.louisgallet.fr/s/2ymAH4C7mL
https://notes.medien.rwth-aachen.de/s/CRi-wpwZVC
https://tutos.cemea.org/s/TNI5zw6z3
https://docs.juze-cr.de/s/_ufGG8qUZ
https://stuv.othr.de/pad/s/nmkgmRktF
https://hpad.dataone.org/s/LI3Wy9wiZ
https://docs.trybrass.com/discuss/6960b9a4bebd12ab8faf674c
https://docs.btfs.io/v2.3.4/discuss/6960b9edcd51d41dd7d1a2d2
https://docs.genny.lovo.ai/discuss/6960baa969308a7396952dea
https://developer.clip.mx/discuss/6960bb09eb474ad5b36f4c2c
https://paidforarticles.in/how-high-efficiency-modules-improve-returns-for-commercial-projects-933296 http://www.mocyc.com/board/43183/HowAutomatedProductionEnsuresGreaterModuleReliability https://www.cssauw.org/forum/thread-41096-1-1 https://kumu.io/bothbest/temperature-coefficients-explained-for-everyday-consumers https://bambooflooring.alboompro.com/post/low-lid-solar-panels-how-they-deliver-more-energy-from-day-one https://www.auseka.com.au/blog/heat-resistant-solar-panels-top-features-to-look-for https://kadrmaskreations.com/forum/topic/what-makes-a-solar-panel-high-performance-in-real-conditions/ https://www.bizthistown.com/discussions/how-robotics-and-automation-reduce-defects-in-solar-panels https://sngine.fr/blogs/23156/Solar-Module-Efficiency-Myths-Every-Buyer-Should-Know https://www.edufex.com/forums/discussion/general/the-hidden-role-of-automation-in-producing-high-efficiency-panels https://arizonaadam.com/forum/topic/why-lower-temperature-coefficients-matter-in-hot-climates/ https://www.uscgq.com/forum/posts.php?forum=&id=629883 https://bothbestbambooflooring.tawk.help/article/the-benefits-of-n-type-topcon-modules-for-residential-systems https://pad.degrowth.net/s/bO2jpZrqV https://hedgedoc.louisgallet.fr/s/2ymAH4C7mL https://notes.medien.rwth-aachen.de/s/CRi-wpwZVC https://tutos.cemea.org/s/TNI5zw6z3 https://docs.juze-cr.de/s/_ufGG8qUZ https://stuv.othr.de/pad/s/nmkgmRktF https://hpad.dataone.org/s/LI3Wy9wiZ https://docs.trybrass.com/discuss/6960b9a4bebd12ab8faf674c https://docs.btfs.io/v2.3.4/discuss/6960b9edcd51d41dd7d1a2d2 https://docs.genny.lovo.ai/discuss/6960baa969308a7396952dea https://developer.clip.mx/discuss/6960bb09eb474ad5b36f4c2c
praveencoaching30
praveencoaching30 posted this 16 March 2026
In its relentless pursuit of inclusive and equitable education, the Government of India has supercharged its financial aid machinery through the Public Financial Management System (PFMS).
In its relentless pursuit of inclusive and equitable education, the Government of India has supercharged its financial aid machinery through the Public Financial Management System ([PFMS][1]). [1]: https://pfmsportall.com/
praveencoaching30
Embrace the digital transformation of your government service. By mastering the Manav Sampada UP eHRMS portal with this 2026 guide, you ensure efficient, transparent, and secure access to your career management, leaving paperwork and delays behind.
Embrace the digital transformation of your government service. By mastering the [Manav Sampada UP][1] eHRMS portal with this 2026 guide, you ensure efficient, transparent, and secure access to your career management, leaving paperwork and delays behind. [1]: https://manavsampadaup.co.in/
praveencoaching30
E Uparjan पोर्टल ने न केवल फसल खरीद प्रक्रिया को सरल बनाया है, बल्कि किसानों को उनके हकदार MSP की गारंटी भी दी है। E Uparjan Registration online और E Uparjan Slot Booking Online की सुविधाओं का लाभ उठाकर हर किसान एक पारदर्शी और निष्पक्ष व्यवस्था का हिस्सा बन सकता है।
[E Uparjan][1] पोर्टल ने न केवल फसल खरीद प्रक्रिया को सरल बनाया है, बल्कि किसानों को उनके हकदार MSP की गारंटी भी दी है। E Uparjan Registration online और E Uparjan Slot Booking Online की सुविधाओं का लाभ उठाकर हर किसान एक पारदर्शी और निष्पक्ष व्यवस्था का हिस्सा बन सकता है। [1]: https://euparjan.in/
kalpananandi04
kalpananandi04 posted this 2 weeks ago
The Annapurna Bhandar Status is a state government welfare programme launched by West Bengal. Under this scheme, eligible women receive a monthly financial assistance of ₹3,000 directly into their bank accounts. The purpose of this scheme is to support women who do not have any fixed income source, government salary, or pension — essentially making it a lifeline for economically vulnerable households across the state.
The [Annapurna Bhandar Status][1] is a state government welfare programme launched by West Bengal. Under this scheme, eligible women receive a monthly financial assistance of ₹3,000 directly into their bank accounts. The purpose of this scheme is to support women who do not have any fixed income source, government salary, or pension — essentially making it a lifeline for economically vulnerable households across the state. [1]: https://annapurnabhandarwb.in/annapurna-bhandar-status-check-2026-how-to-check-your-application-status-online/
