Big space between texts section
cynthia4
cynthia4 posted this 2 weeks ago
I can't seem to get rid of the white space between the first post and the static posts. And when I look at the same page on a smaller screen the first post has gone behind the static posts. What am I doing wrong?
https://lions.se/index.php/en/
Hi, I can't seem to get rid of the white space between the first post and the static posts. And when I look at the same page on a smaller screen the first post has gone behind the static posts. What am I doing wrong? https://lions.se/index.php/en/
cynthia4
Hi again,
The white space appears only on a smaller screen for instance the size of a Macbook Air. I managed to solve the problem with the text hiding behind the static module.
Hi again, The white space appears only on a smaller screen for instance the size of a Macbook Air. I managed to solve the problem with the text hiding behind the static module.
I'm not sure if this the white space you mean but it can be related to the post images not displaying and so the gap appears. If this is not what you mean, please provide a screenshot with the white space and where it is present.
Hello, I'm not sure if this the white space you mean but it can be related to the post images not displaying and so the gap appears. If this is not what you mean, please provide a screenshot with the white space and where it is present. Sincerely, Nettie
cynthia4
cynthia4 posted this 1 weeks ago
Here are two screenshots of one with white space and one without. The one without is a slightly larger screen than the one with. I don't know the size of it but you can try it yourself on www.lions.se on the first page. And there are no images missing.
Hi, Here are two screenshots of one with white space and one without. The one without is a slightly larger screen than the one with. I don't know the size of it but you can try it yourself on www.lions.se on the first page. And there are no images missing.
