Great News - Themler v.547 Update
Support Team posted this 17 June 2022
Great news - Themler v.547 update is ready!
Changes in this version include:
  • Shortcodes support for Joomla 3 and PHP 8
  • Error processing support for Joomla 3 and PHP 8
  • Module rendering support for Joomla 3 and PHP 8
  • Minor fixes for Joomla 4
Themler for Joomla 4 default updated theme will be available next week. It should be then re-downloaded from https://themler.io/Download/Joomla4 and installed on your website.
This means that there are some changes yet to be done for full PHP 8 support for Joomla 3 but in general it should work, and there are more fixes to be included for Joomla 4. All this is expected in the following updates.
Themler Team
Great news - Themler v.547 update is ready! Changes in this version include: - Shortcodes support for Joomla 3 and PHP 8 - Error processing support for Joomla 3 and PHP 8 - Module rendering support for Joomla 3 and PHP 8 - Minor fixes for Joomla 4 Themler for Joomla 4 default updated theme will be available next week. It should be then re-downloaded from https://themler.io/Download/Joomla4 and installed on your website. This means that there are some changes yet to be done for full PHP 8 support for Joomla 3 but in general it should work, and there are more fixes to be included for Joomla 4. All this is expected in the following updates. Themler Team
36 Comments
AKSearch
AKSearch posted this 17 June 2022
Joomla 3.10.9
I updated a simple Joomla 3 site to v.547. When I switched the php version to 8.0, the site would no longer load and I received the following error messages.
Frontend:
0 - Unknown named parameter $title
Backend in Themler:
0 - Too few arguments to function errorHandlerPreviewTheme(), 4 passed and exactly 5 expected
I switched it back to php 7.4 and everything works again.
WordPress 6.0
I also updated a simple WordPress 6.0 site to v.547. I switched the site to php version to 8.0 and so far everything appears to be working, but is still generating PHP warning messages.
PHP Warnings
PHP Warning: Trying to access array offset on value of type null in /home/XXXX/public_html/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 302
PHP Warning: Cannot modify header information - headers already sent in /home/XXXX/public_html/wp-content/themes/XXXX/functions.php on line 4
PHP Warning: Trying to access array offset on value of type null in /home/XXXX/public_html/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 291
PHP Warning: Undefined array key "post" in /home/XXXX/public_html/wp-content/themes/XXXX/export/export.php on line 294
PHP Warning: A non-numeric value encountered in /home/XXXX/public_html/wp-content/themes/XXXX/export/editorHelper.php on line 406
**Joomla 3.10.9** I updated a simple Joomla 3 site to v.547. When I switched the php version to 8.0, the site would no longer load and I received the following error messages. Frontend: 0 - Unknown named parameter $title Backend in Themler: 0 - Too few arguments to function errorHandlerPreviewTheme(), 4 passed and exactly 5 expected I switched it back to php 7.4 and everything works again. **WordPress 6.0** I also updated a simple WordPress 6.0 site to v.547. I switched the site to php version to 8.0 and so far everything appears to be working, but is still generating PHP warning messages. **PHP Warnings** PHP Warning: Trying to access array offset on value of type null in /home/XXXX/public_html/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 302 PHP Warning: Cannot modify header information - headers already sent in /home/XXXX/public_html/wp-content/themes/XXXX/functions.php on line 4 PHP Warning: Trying to access array offset on value of type null in /home/XXXX/public_html/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 291 PHP Warning: Undefined array key "post" in /home/XXXX/public_html/wp-content/themes/XXXX/export/export.php on line 294 PHP Warning: A non-numeric value encountered in /home/XXXX/public_html/wp-content/themes/XXXX/export/editorHelper.php on line 406
Support Team posted this 20 June 2022
Did you update the theme right away on the website or imported it in Themler desktop first?
Hello, Did you update the theme right away on the website or imported it in Themler desktop first? Sincerely, Nettie
Виктор
Виктор posted this 21 June 2022
Здравствуйте, как можно обновить Themler v.547 если я ей пользуюсь долгое время, вероятно для обновления нужна новая версия Themler v.548, и затем проверить работу сайта на Joomla 3 и PHP 8.
Support Team posted this 21 June 2022
Здравствуйте,
Для обновления темы достаточно нажать на Updates(1) вверху темы. Лучше сделать это до обновления PHP. После этого можно пробовать тему с Joomla 3 и PHP 8. Мы рекомендуем в любом случае сделать перед этим бэкап, потому что еще не все проблемы совместимости исправлены в этой версии.
Здравствуйте, Для обновления темы достаточно нажать на Updates(1) вверху темы. Лучше сделать это до обновления PHP. После этого можно пробовать тему с Joomla 3 и PHP 8. Мы рекомендуем в любом случае сделать перед этим бэкап, потому что еще не все проблемы совместимости исправлены в этой версии. Sincerely, Nettie
Виктор
Nettie, у меня нет обновления темы Updates(1).
Nettie, у меня нет обновления темы Updates(1).!Updates.jpg!
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 22 June 2022
I get the same error messages as @AKSearch
I updated the template directly from the website.
Joomla 3.10.10, Themler 547, PHP8
Sincerely, Thorsten
Hello, I get the same error messages as @AKSearch I updated the template directly from the website. Joomla 3.10.10, Themler 547, PHP8 Sincerely, Thorsten
Support Team posted this 22 June 2022
Hi Thorsten,
Have you updated the theme first, and then PHP to 8, or vice versa?
Hi Thorsten, Have you updated the theme first, and then PHP to 8, or vice versa? Sincerely, Nettie
Hi Viktor,
You may need to enable Beta update notifications in your profile.
Hi Viktor, You may need to enable Beta update notifications in your profile. Sincerely, Nettie
AKSearch
AKSearch posted this 22 June 2022
I updated Themler to v.547 on the live website with Joomla 3.10.9 and php 7.4 and everything appeared to go fine. I then changed the php version to 8.0 and received the above listed error message. After reverting back to php 7.4 everything started working again.
> Hello, > > Did you update the theme right away on the website or imported it in Themler desktop first? > > Sincerely, > Nettie I updated Themler to v.547 on the live website with Joomla 3.10.9 and php 7.4 and everything appeared to go fine. I then changed the php version to 8.0 and received the above listed error message. After reverting back to php 7.4 everything started working again.
Виктор
Виктор posted this 23 June 2022
Nettie, в моём профиле "Получить бета-обновления" стоит галочка, и всё же обновлений нет.
marcin8
marcin8 posted this 23 June 2022
I have the same error "0 - Unknown named parameter $title".
When I disable modules that use "position-xxx", the site works fine with PHP8.
You can only use "hmenu" for the website to work properly.
I have the same error "0 - Unknown named parameter $title". When I disable modules that use "position-xxx", the site works fine with PHP8. You can only use "hmenu" for the website to work properly.
Web-Art Creative Design
Web-Art Creative Design posted this 23 June 2022
Nettie.
Will the update fix bugs for Wordpress themes for php.8 and php8.1 ???
Nettie. Will the update fix bugs for Wordpress themes for php.8 and php8.1 ???
Support Team posted this 23 June 2022
I have reported the error with Joomla 3 to our developers. It should be fixed soon.
Hello, I have reported the error with Joomla 3 to our developers. It should be fixed soon. Sincerely, Nettie
Hello Viktor,
Please try to clear browser cache and then toggle the option to enable Beta updates on and off and then on again. This can help.
Hello Viktor, Please try to clear browser cache and then toggle the option to enable Beta updates on and off and then on again. This can help. Sincerely, Nettie
The update doesn't include fixes for Wordpress and PHP 8 yet. This is expected in the future updates.
Hi, The update doesn't include fixes for Wordpress and PHP 8 yet. This is expected in the future updates. Sincerely, Nettie
Виктор
Виктор posted this 24 June 2022
Nettie, по вашей рекомендации: очистить кеш браузера, а затем включите и выключите бета-обновления, а затем снова включите параметр.
Не помогло.
Буду ждать полной версии, спасибо.
Nettie, по вашей рекомендации: *очистить кеш браузера, а затем включите и выключите бета-обновления, а затем снова включите параметр.* **Не помогло.** Буду ждать полной версии, спасибо.
Support Team posted this 24 June 2022
Hello Michiel,
An update with more fixes for Joomla 4 including the menu fix is expected really soon. Please follow update notifications for the theme but I will also update this topic and create a new one as soon as the update it out.
Hello Michiel, An update with more fixes for Joomla 4 including the menu fix is expected really soon. Please follow update notifications for the theme but I will also update this topic and create a new one as soon as the update it out. Sincerely, Nettie
Добрый день, Виктор,
Немного странно, потому что обычно такое помогает - чистить кеш и перезапустить тему. Может ли быть, что эта тема очень старая? Версию можно проверить через Help (?) в правом верхнем углу темы >> About.
Добрый день, Виктор, Немного странно, потому что обычно такое помогает - чистить кеш и перезапустить тему. Может ли быть, что эта тема очень старая? Версию можно проверить через Help (?) в правом верхнем углу темы >> About. Sincerely, Nettie
Werbeagentur Schulz-Design posted this 24 June 2022
Hello Nettie,
Of course I first updated the theme, then cleared the cache and only then the PHP version.
Thorsten
Hello Nettie, > Have you updated the theme first, and then PHP to 8, or vice versa? Of course I first updated the theme, then cleared the cache and only then the PHP version. Sincerely, Thorsten
jantahu8
jantahu8 posted this 24 June 2022
