themler with joomla 4
MercurioWeb WebStudio
MercurioWeb WebStudio posted this 04 July 2022
Hi i updated joomla to version 4.1.5, but there is a compatibility problem with themler theme. How can I update themler? The error that comes up is "Attempted to call an undefined method named" isAdmin "of class" Joomla \ CMS \ Application \ SiteApplication "."
36 Comments
Support Team posted this 05 July 2022
There is a separate Themler theme for Joomla 4. Currently it is in Beta. It is available as a separate download at https://themler.io/download
Hello, There is a separate Themler theme for Joomla 4. Currently it is in Beta. It is available as a separate download at https://themler.io/download Sincerely, Nettie
MercurioWeb WebStudio posted this 05 July 2022
I tried to install your Blank theme for J4. Now It appear this error:
0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params
I tried to install your Blank theme for J4. Now It appear this error: 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params
MercurioWeb WebStudio posted this 15 July 2022
Hi, is there any news regarding the bug I reported? Thank You
BillyBob
BillyBob posted this 16 July 2022
I'm getting the same error unless I disable the mod that uses the hmenu position. To echo Mercurio, any fix for this bug?
MercurioWeb WebStudio posted this 17 July 2022
no BillyBob still no solution. Here the assistance is slow and the bug fixes and updates are done after a long time. I am about to abandon Themler because it cannot work like this, I haven't done so yet because I still have several websites on which I have installed a themler theme, however due to themler I cannot update the websites to joomla4. I'm sorry because the basic software is good, but I've already found alternatives.
if the menu is active, the error appears. There is some conflict between the main menu and the template for joomla 4
asik5
asik5 posted this 17 July 2022
"I'm sorry because the basic software is good, but I've already found alternatives."
can you reveal which one?
> "I'm sorry because the basic software is good, but I've already found alternatives." can you reveal which one?
Now I'm trying, for example, []
> > "I'm sorry because the basic software is good, but I've already found alternatives." > > can you reveal which one? Now I'm trying, for example, []
BillyBob
BillyBob posted this 19 July 2022
I considered [], but unless I'm mistaken ALL content editing is pretty much template side. I didn't dive into that much, but to me it doesn't seem like an alternative to Themler's options to use CMS to control content. Although Themler's development did seem to try and integrate template content, it was easy to avoid.
The "top" 5 alternatives I've seen are more page builders (i.e. []) versus template builders. I've dipped my toes into Cassiopeia (default Joomla 4 template) and the info available on that is vast. I'm thinking now maybe a simple Cassiopeia template with major Smart Slider 3 integration might be a good solution. A lot of redesign and CSS tweaks but I don't know of any other options presently.
I considered [], but unless I'm mistaken ALL content editing is pretty much template side. I didn't dive into that much, but to me it doesn't seem like an alternative to Themler's options to use CMS to control content. Although Themler's development did seem to try and integrate template content, it was easy to avoid. The "top" 5 alternatives I've seen are more page builders (i.e. []) versus template builders. I've dipped my toes into Cassiopeia (default Joomla 4 template) and the info available on that is vast. I'm thinking now maybe a simple Cassiopeia template with major Smart Slider 3 integration might be a good solution. A lot of redesign and CSS tweaks but I don't know of any other options presently.
Support Team posted this 19 July 2022
Please make sure to update the theme for Joomla 4 to the latest Themler Beta v. 556. Let us know if the issue is still present.
Hello, Please make sure to update the theme for Joomla 4 to the latest Themler Beta v. 556. Let us know if the issue is still present. Sincerely, Nettie
MercurioWeb WebStudio posted this 19 July 2022
I can't log in to themler to update, because when I try to do it I get the following error message "Sorry, an error has occurred. Please clear your browser cache."
> Hello, > > Please make sure to update the theme for Joomla 4 to the latest Themler Beta v. 556. Let us know if the issue is still present. > > Sincerely, > Nettie I can't log in to themler to update, because when I try to do it I get the following error message "Sorry, an error has occurred. Please clear your browser cache."
BillyBob
Hi Nettie, yes I double checked and I already have v556 beta installed. The hmenu position still seems to be bug.
"0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params"
Any information you can provide would be great and thank you.
Hi Nettie, yes I double checked and I already have v556 beta installed. The hmenu position still seems to be bug. *"0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params"* Any information you can provide would be great and thank you.
Support Team posted this 20 July 2022
If you download the new default Themler theme for Joomla 4 from our website, can you update it?
Hello, If you download the new default Themler theme for Joomla 4 from our website, can you update it? Sincerely, Nettie
As for the menu issue - could you please attach the theme in a new private topic so that we could check it on our end?
Hello, As for the menu issue - could you please attach the theme in a new private topic so that we could check it on our end? Sincerely, Nettie
MercurioWeb WebStudio posted this 20 July 2022
Hello, the template used is the one for joomla 4 downloaded from your site https://themler.io/download
I'm testing the theme locally using xampp
> Hello, > > As for the menu issue - could you please attach the theme in a new private topic so that we could check it on our end? > > Sincerely, > Nettie Hello, the template used is the one for joomla 4 downloaded from your site https://themler.io/download I'm testing the theme locally using xampp
if I download the theme for joomla 4 from here https://themler.io/download I import it into themler for desktop, update it, export it again in zip format and then I import it to the site the error in the image in attachment comes out
> Hello, > > If you download the new default Themler theme for Joomla 4 from our website, can you update it? > > Sincerely, > Nettie if I download the theme for joomla 4 from here https://themler.io/download I import it into themler for desktop, update it, export it again in zip format and then I import it to the site the error in the image in attachment comes out
BillyBob
BillyBob posted this 20 July 2022
Hi Nettie,
I was able to download your beta template and update to v556 and with hmenu position enabled the same error persists which is; 0 – Cannot access protected property Joomla/CMS/Menu/MenuItem::@params
I will upload the template to you in private here in a second and thank you for looking at this! :)
Hi Nettie, I was able to download your beta template and update to v556 and with hmenu position enabled the same error persists which is; **0 – Cannot access protected property Joomla/CMS/Menu/MenuItem::@params** I will upload the template to you in private here in a second and thank you for looking at this! :) *Hello, If you download the new default Themler theme for Joomla 4 from our website, can you update it? Sincerely, Nettie* *Hello, As for the menu issue - could you please attach the theme in a new private topic so that we could check it on our end? Sincerely, Nettie*
Support Team posted this 21 July 2022
BillyBob,
Thank you, we will continue communication in the private topic.
**BillyBob**, Thank you, we will continue communication in the private topic. Sincerely, Nettie
MercurioWeb WebStudio,
Unfortunately, with Themler desktop this way of updating will not work, as there is only Joomla 3 there at the moment. So just install the theme from our website on your Joomla 4 and update it right there to v.556.
The way with updating through Themler desktop is recommended for Joomla 3 themes.
**MercurioWeb WebStudio**, Unfortunately, with Themler desktop this way of updating will not work, as there is only Joomla 3 there at the moment. So just install the theme from our website on your Joomla 4 and update it right there to v.556. The way with updating through Themler desktop is recommended for Joomla 3 themes. Sincerely, Nettie
MercurioWeb WebStudio posted this 21 July 2022
BillyBob,
I would also need to know the resolution of the problem, so I ask you to communicate also to me the method to solve it. Thank you
> **BillyBob**, > > Thank you, we will continue communication in the private topic. > > Sincerely, > Nettie I would also need to know the resolution of the problem, so I ask you to communicate also to me the method to solve it. Thank you
