themler with joomla 4
MercurioWeb WebStudio
MercurioWeb WebStudio posted this 04 July 2022
Hi i updated joomla to version 4.1.5, but there is a compatibility problem with themler theme. How can I update themler? The error that comes up is "Attempted to call an undefined method named" isAdmin "of class" Joomla \ CMS \ Application \ SiteApplication "."
37 Comments
BillyBob
BillyBob posted this 22 July 2022
To add to the discussion, I tried 3 ways till Sunday (American expression) to upgrade from latest J3 to J4 to include the Themler upgrade path, for troubleshooting purposes, and I've noted it's best to start with a clean J4 install before installing Themler.
MercurioWeb WebStudio posted this 22 July 2022
MercurioWeb WebStudio,
Unfortunately, with Themler desktop this way of updating will not work, as there is only Joomla 3 there at the moment. So just install the theme from our website on your Joomla 4 and update it right there to v.556.
The way with updating through Themler desktop is recommended for Joomla 3 themes.
Hi Nettie, as explained above, I cannot update themler from my website because when I try to enter themler I get the following error message: "Sorry, an error has occurred. Please clear your browser cache." Anyway, the theme I have installed is the one downloaded from your site https://themler.io/download. So it should be inclusive of the latest update.
> **MercurioWeb WebStudio**, > > Unfortunately, with Themler desktop this way of updating will not work, as there is only Joomla 3 there at the moment. So just install the theme from our website on your Joomla 4 and update it right there to v.556. > > The way with updating through Themler desktop is recommended for Joomla 3 themes. > > Sincerely, > Nettie Hi Nettie, as explained above, I cannot update themler from my website because when I try to enter themler I get the following error message: "Sorry, an error has occurred. Please clear your browser cache." Anyway, the theme I have installed is the one downloaded from your site https://themler.io/download. So it should be inclusive of the latest update.
Sinergia Innovaciones
Sinergia Innovaciones posted this 22 July 2022
is Iit possible to migrate the joomla 3 template to joomla 4?
I have several sites with joomla 3 but I still can't successfully migrate the Themler template to joomla 4.
Diana
Hello, is Iit possible to migrate the joomla 3 template to joomla 4? I have several sites with joomla 3 but I still can't successfully migrate the Themler template to joomla 4. Regards Diana
BillyBob
BillyBob posted this 23 July 2022
Diana
Presently no, I'm not one of the developers but I've been down that conversion road and it was a no go.
> Hello, > > is Iit possible to migrate the joomla 3 template to joomla 4? > I have several sites with joomla 3 but I still can't successfully migrate the Themler template to joomla 4. > > Regards > Diana Presently no, I'm not one of the developers but I've been down that conversion road and it was a no go.
Seppe
Seppe posted this 24 July 2022
Diana
You can follow it here:
https://answers.themler.io/questions/216910/migration-to-joomla-4
> Hello, > > is Iit possible to migrate the joomla 3 template to joomla 4? > I have several sites with joomla 3 but I still can't successfully migrate the Themler template to joomla 4. > > Regards > Diana You can follow it here: https://answers.themler.io/questions/216910/migration-to-joomla-4
Support Team posted this 25 July 2022
Old themes are all for Joomla 3 and cannot be imported or converted for Joomla 4 automatically. The themes are completely different as if they were for different CMS's. That is why for Joomla 4 a separate theme should be downloaded and not just Joomla 3 theme with Themler update.
Here are possible ways to make creating themes easier (if they are made to re-create old themes):
- organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip
- there are Export / Import options available in the Posts tab to transfer Posts layout and styling
There is a separate Themler theme for Joomla 4 at https://themler.io/Download. Currently it is in Beta. Please update it to the latest Themler version as it includes some fixes.
Hello, Old themes are all for Joomla 3 and cannot be imported or converted for Joomla 4 automatically. The themes are completely different as if they were for different CMS's. That is why for Joomla 4 a separate theme should be downloaded and not just Joomla 3 theme with Themler update. Here are possible ways to make creating themes easier (if they are made to re-create old themes): - organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip - there are Export / Import options available in the Posts tab to transfer Posts layout and styling There is a separate Themler theme for Joomla 4 at https://themler.io/Download. Currently it is in Beta. Please update it to the latest Themler version as it includes some fixes. Sincerely, Nettie
Please try installing the theme attached. It is a theme for Joomla 4 updated to v.556.
**MercurioWeb WebStudio,** Please try installing the theme attached. It is a theme for Joomla 4 updated to v.556. Sincerely, Nettie
asik5
asik5 posted this 25 July 2022
what about homepage pagination?
MercurioWeb WebStudio posted this 26 July 2022
Hi Nettie, I have installed and enabled the attached theme, but when I activate the main menu of the site I always get this error message "0 - Cannot access protected property Joomla \ CMS \ Menu \ MenuItem :: $ params"
> **MercurioWeb WebStudio,** > > Please try installing the theme attached. It is a theme for Joomla 4 updated to v.556. > > Sincerely, > Nettie Hi Nettie, I have installed and enabled the attached theme, but when I activate the main menu of the site I always get this error message "0 - Cannot access protected property Joomla \ CMS \ Menu \ MenuItem :: $ params"
BillyBob
BillyBob posted this 27 July 2022
Importing sections and layout settings sounds like a good time saver for recreating existing templates and thank you for that info.
I did provide my Themler theme, admin Joomla backend access & FTP access in our private thread if that can help ID our current J4.1.5 hmenu display issue.
- there are Export / Import options available in the Posts tab to transfer Posts layout and styling:
Importing sections and layout settings sounds like a good time saver for recreating existing templates and thank you for that info. I did provide my Themler theme, admin Joomla backend access & FTP access in our private thread if that can help ID our current J4.1.5 hmenu display issue. > Here are possible ways to make creating themes easier (if they are > made to re-create old themes): > - organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip > - there are Export / Import options available in the Posts tab to transfer Posts layout and styling:
BillyBob
BillyBob posted this 09 August 2022
Any updates from community or others?
MercurioWeb WebStudio posted this 09 August 2022
also I am waiting for an answer to solve my problem. Unfortunately assistance here is so ... slow and often not conclusive
> Any updates from community or others? also I am waiting for an answer to solve my problem. Unfortunately assistance here is so ... slow and often not conclusive
BillyBob
BillyBob posted this 27 August 2022
Still wathcing for updates and on a positive note, next weekend is going to be a great time to grill outdoors. Here anyways.
MercurioWeb WebStudio posted this 28 August 2022
great!! :-)
> Still wathcing for updates and on a positive note, next weekend is going to be a great time to grill outdoors. Here anyways. great!! :-)
elia20
elia20 posted this 28 August 2022
Same issue
> > **MercurioWeb WebStudio,** > > > > Please try installing the theme attached. It is a theme for Joomla 4 updated to v.556. > > > > Sincerely, > > Nettie > > Hi Nettie, I have installed and enabled the attached theme, but when I activate the main menu of the site I always get this error message "0 - Cannot access protected property Joomla \ CMS \ Menu \ MenuItem :: $ params" Same issue
BillyBob
BillyBob posted this 21 September 2022
Havn't checked for a bit but see we are still at the stop sign. With the announced PHP 7.x and Joomla 3.x end of life dates, one could argue that the developers are under the gun but, not that much under the gun because there still a lot of time left on the clock. Which sucks for those having to make the decision whether it's worth renewing or not. I'm not complaining to complain, but minimal communications from the powers that be, would be appropriate here.
chinahousehold
chinahousehold posted this 11 January 2026
https://bothbest.weebly.com/blog/the-environmental-benefits-of-choosing-bamboo-plywood-for-your-home
https://forum.kryptronic.com/profile.php?id=215440
https://expatguidekorea.com/profile/bothbest/
https://cuchichi.es/author/chinabamboo/
https://www.mymeetbook.com/bothbest
https://toptohigh.com/author/bothbest-9101/
https://cone.skima.jp/creators/profile/portfolios/detail?id=2918
https://forum.codeigniter.com/member.php?action=profile&uid=215507
http://forum.modulebazaar.com/forums/user/bothbest/
https://hackerspace.govhack.org/profiles/hssolar
https://worldaid.eu.org/discussion/profile.php?id=1313082
https://jsfiddle.net/6qadjfzw/
https://kickofflabs.com/waitlist/600w-topcon-solar-panel
https://www.bloggportalen.se/BlogPortal/view/BlogDetails?id=281798
https://vintage.theplasticsexchange.com/public/Links/LinksDetail.aspx?Id=5099
https://clearvoice.com/cv/homesunsolar
https://www.senscritique.com/hssolar
https://library.zortrax.com/members/homesun-solar/
https://s.id/hssolar
https://www.hssolar.cn/news-38.html
https://topsitenet.com/profile/hssolar/1529417/
https://forumtransportu.pl/forum/temat/27211
https://ziuma.com/Thread-The-Science-Behind-Ultra-Thin-Silicon-and-Higher-Conversion-Rates
https://naya.com.np/post/p1767940294rnmwp
https://hssolar.tawk.help/article/how-temperature-coefficient-impacts-real-world-solar-output
https://www.xcspa.com/why-ultra-thin-wafers-are-changing-the-future-of-solar/
https://ameblo.jp/japanbamboo/entry-12952857198.html
https://velog.io/@bothbest/Why-Temperature-Matters-More-Than-You-Realize-in-Solar-Energy
https://bothbest.weebly.com/blog/the-environmental-benefits-of-choosing-bamboo-plywood-for-your-home https://forum.kryptronic.com/profile.php?id=215440 https://expatguidekorea.com/profile/bothbest/ https://cuchichi.es/author/chinabamboo/ https://www.mymeetbook.com/bothbest https://toptohigh.com/author/bothbest-9101/ https://cone.skima.jp/creators/profile/portfolios/detail?id=2918 https://forum.codeigniter.com/member.php?action=profile&uid=215507 http://forum.modulebazaar.com/forums/user/bothbest/ https://hackerspace.govhack.org/profiles/hssolar https://worldaid.eu.org/discussion/profile.php?id=1313082 https://jsfiddle.net/6qadjfzw/ https://kickofflabs.com/waitlist/600w-topcon-solar-panel https://www.bloggportalen.se/BlogPortal/view/BlogDetails?id=281798 https://vintage.theplasticsexchange.com/public/Links/LinksDetail.aspx?Id=5099 https://clearvoice.com/cv/homesunsolar https://www.senscritique.com/hssolar https://library.zortrax.com/members/homesun-solar/ https://s.id/hssolar https://www.hssolar.cn/news-38.html https://topsitenet.com/profile/hssolar/1529417/ https://forumtransportu.pl/forum/temat/27211 https://ziuma.com/Thread-The-Science-Behind-Ultra-Thin-Silicon-and-Higher-Conversion-Rates https://naya.com.np/post/p1767940294rnmwp https://hssolar.tawk.help/article/how-temperature-coefficient-impacts-real-world-solar-output https://www.xcspa.com/why-ultra-thin-wafers-are-changing-the-future-of-solar/ https://ameblo.jp/japanbamboo/entry-12952857198.html https://velog.io/@bothbest/Why-Temperature-Matters-More-Than-You-Realize-in-Solar-Energy
