0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params
info1139
info1139 posted this 07 July 2022
0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params when hmenu module position is active. Depublish and there is no error (but also no menu bar)
In a ealier post of this problem the solution was to use PHP 7.x, but my site is on that. How to solve?
Regards Michel
Hello, 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params when hmenu module position is active. Depublish and there is no error (but also no menu bar) In a ealier post of this problem the solution was to use PHP 7.x, but my site is on that. How to solve? Regards Michel
174 Comments
Pierre665
Pierre665 posted this 25 November 2022
"temporary inconvenience"
info1139
info1139 posted this 28 November 2022
Hello Nettie,
When is the next release?
Regards Michel
Hello Nettie, When is the next release? Regards Michel
info1139
info1139 posted this 07 December 2022
Hello Nettie,
When is the new release expected?
And/or is there a manual update available to solve the issue (change this code in this file etc etc) in the meantime?
Regards Michel
Hello Nettie, When is the new release expected? And/or is there a manual update available to solve the issue (change this code in this file etc etc) in the meantime? Regards Michel
info1139
info1139 posted this 18 December 2022
Themler, are you dead? You give me no other solution than to leave Themler. Show stopping bugs, no solutions, no workaround, no answers (beside, it's in the next release, WHEN???), now way to contact....and so on, and so on....and so on....
How can we build on the team behind Artisteer, Themler, Nicepage?? Artisteer is dead, Themler is dead.
Goodbye Themler, i loved you very much, but it's a shame, that Themler is leaving Themler, but forget it's customers....
Themler, are you dead? You give me no other solution than to leave Themler. Show stopping bugs, no solutions, no workaround, no answers (beside, it's in the next release, WHEN???), now way to contact....and so on, and so on....and so on.... How can we build on the team behind Artisteer, Themler, Nicepage?? Artisteer is dead, Themler is dead. Goodbye Themler, i loved you very much, but it's a shame, that Themler is leaving Themler, but forget it's customers....
Morpheus0101
Morpheus0101 posted this 22 December 2022
Hello Michel,
Indeed, there is an issue with Joomla 4.2 and Themler. The issue shoudl be fixed in teh next update.
We are sorry for temporary inconvenience.
A month has passed since this reply. Can you provide a patch to fix this? I am sure it is something your developers could solve quite quickly with a couple of lines of code?
Please update
Arhon
> Hello Michel, > > Indeed, there is an issue with Joomla 4.2 and Themler. The issue shoudl be fixed in teh next update. > We are sorry for temporary inconvenience. > > Sincerely, > Nettie A month has passed since this reply. Can you provide a patch to fix this? I am sure it is something your developers could solve quite quickly with a couple of lines of code? Please update Arhon
Morpheus0101
Morpheus0101 posted this 23 December 2022
Regards Michel
I have the same issue. I purchased a cheep third-party responsive menu extension which has helped me out. I managed to achieve the same thing I needed with a few tweaks.
The one I am using is "JUX Responsive Menu". There are a number of similar extensions out there. I am using Joomla 4.2.6. I am also using PHP 7.2 as Themler has issues with displaying blogs on version 8, but that's another story. Hopefully this will get fixed too.
On principle we shouldn't need to buy this, however....
Hope this helps
> Hello, > > 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params when hmenu module position is active. Depublish and there is no error (but also no menu bar) > > In a ealier post of this problem the solution was to use PHP 7.x, but my site is on that. How to solve? > > Regards Michel I have the same issue. I purchased a cheep third-party responsive menu extension which has helped me out. I managed to achieve the same thing I needed with a few tweaks. The one I am using is "JUX Responsive Menu". There are a number of similar extensions out there. I am using Joomla 4.2.6. I am also using PHP 7.2 as Themler has issues with displaying blogs on version 8, but that's another story. Hopefully this will get fixed too. On principle we shouldn't need to buy this, however.... Hope this helps
NIGEFA1990
NIGEFA1990 posted this 27 March 2023
there is already a solution here
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 27 March 2023
same Problem here!
http://2023.hannover-meeting.de/
Hello, same Problem here! http://2023.hannover-meeting.de/
I have now found out that it is due to submenu items related to the template.
Will the problem be solved?
I have now found out that it is due to submenu items related to the template. Will the problem be solved?
Werbeagentur Schulz-Design posted this 31 March 2023
It is clearly shown to us that they don't give a shit about us! No answer to questions. No bug fixes. No further development.
Support Team posted this 31 March 2023
We are sorry for the issue with the submenu, We will investigate it and will ask developers to prioritise issuing the update with the fix.
Hello, We are sorry for the issue with the submenu, We will investigate it and will ask developers to prioritise issuing the update with the fix. Sincerely, Nettie
Werbeagentur Schulz-Design posted this 05 April 2023
Hello Nettie,
This is good news and I hope that it will be acknowledged and implemented soon.
Thanks in advance.
Themler is a good product and you shouldn't give up on it! I tried Nicepage again, but it's unsuitable for web designers.
Thorsten
Webdesign Hannover
Hello Nettie, > We will investigate it and will ask developers to prioritise issuing the update with the fix. This is good news and I hope that it will be acknowledged and implemented soon. Thanks in advance. Themler is a good product and you shouldn't give up on it! I tried Nicepage again, but it's unsuitable for web designers. Sincerely, Thorsten [Webdesign Hannover][1] [1]: http://www.schulzdesign.info/webdesign-hannover
lily16720
lily16720 posted this 10 April 2023
This is a fantastic piece of writing. For a writing prompt, this is easily in my top five. The quality and inspiration of your work is just remarkable. You have my gratitude.
cut mover game
This is a fantastic piece of writing. For a writing prompt, this is easily in my top five. The quality and inspiration of your work is just remarkable. You have my gratitude. [cut mover game][1] [1]: https://cutmovergame.com
Werbeagentur Schulz-Design posted this 11 April 2023
Hello Nettie,
Two weeks ago you announced that the bug would be fixed here. Since then (again) nothing has happened. How is this going to continue? We paid for a service that is not kept. This can also have legal consequences for you!
We cannot continue our work, which causes us enormous damage, which we can also claim from you through international courts.
That does not have to be. When will the bug be fixed?
Hello Nettie, Two weeks ago you announced that the bug would be fixed here. Since then (again) nothing has happened. How is this going to continue? We paid for a service that is not kept. This can also have legal consequences for you! We cannot continue our work, which causes us enormous damage, which we can also claim from you through international courts. That does not have to be. When will the bug be fixed?
devidpaul402
devidpaul402 posted this 26 October 2024
Here's a comment you could use in response to Michel's issue:
"Hi Michel, it sounds like you're encountering a frustrating issue with the Joomla menu module. The error you're seeing, 'Cannot access protected property,' typically indicates a problem with the way the menu parameters are being accessed. Since you're already using PHP 7.x, here are a few suggestions to try:
  1. Check Extensions: Ensure that all your extensions are compatible with your Joomla version and PHP 7.x. Sometimes, outdated extensions can cause conflicts.
  2. Update Joomla: Make sure your Joomla installation is up to date, as newer versions often contain bug fixes that could resolve this issue.
  3. Error Reporting: Enable error reporting in Joomla to see if you can get more detailed information about the issue.
  4. Menu Item Settings: Review the settings for the menu items associated with the hmenu module to see if any parameters are misconfigured.
If these steps don’t resolve the issue, you might want to consider reaching out to the Joomla community forums for additional insights. Good luck!" for more visit Incredibox Sprunki
Here's a comment you could use in response to Michel's issue: "Hi Michel, it sounds like you're encountering a frustrating issue with the Joomla menu module. The error you're seeing, 'Cannot access protected property,' typically indicates a problem with the way the menu parameters are being accessed. Since you're already using PHP 7.x, here are a few suggestions to try: 1. **Check Extensions**: Ensure that all your extensions are compatible with your Joomla version and PHP 7.x. Sometimes, outdated extensions can cause conflicts. 2. **Update Joomla**: Make sure your Joomla installation is up to date, as newer versions often contain bug fixes that could resolve this issue. 3. **Error Reporting**: Enable error reporting in Joomla to see if you can get more detailed information about the issue. 4. **Menu Item Settings**: Review the settings for the menu items associated with the hmenu module to see if any parameters are misconfigured. If these steps don’t resolve the issue, you might want to consider reaching out to the Joomla community forums for additional insights. Good luck!" for more visit [Incredibox Sprunki][1] [1]: https://sprunkin.com/
delhirussianescortscom
delhirussianescortscom posted this 08 November 2024
Hi Michel,
This issue with accessing a protected property can be frustrating! Since you’re already on PHP 7.x, the error might be related to compatibility between your Joomla version, template, or extensions. Here are a few steps you could try:
Update Joomla and Extensions: Make sure you’re on the latest version of Joomla and that all extensions (including the hmenu module) are up-to-date, as updates often fix compatibility issues.
Check Template Overrides: Sometimes, template overrides can cause issues with modules. Try switching to a default Joomla template to see if the problem persists.
Inspect Module Configuration: Go into the hmenu module settings and see if there are any options related to caching or parameters. Resetting some settings might resolve the issue.
Error Logs: Review your server error logs. They might provide additional information on what’s causing the protected property issue.
Hope this helps! Let us know if you find a solution or need further assistance. Delhi Escort Service
Hi Michel, This issue with accessing a protected property can be frustrating! Since you’re already on PHP 7.x, the error might be related to compatibility between your Joomla version, template, or extensions. Here are a few steps you could try: Update Joomla and Extensions: Make sure you’re on the latest version of Joomla and that all extensions (including the hmenu module) are up-to-date, as updates often fix compatibility issues. Check Template Overrides: Sometimes, template overrides can cause issues with modules. Try switching to a default Joomla template to see if the problem persists. Inspect Module Configuration: Go into the hmenu module settings and see if there are any options related to caching or parameters. Resetting some settings might resolve the issue. Error Logs: Review your server error logs. They might provide additional information on what’s causing the protected property issue. Hope this helps! Let us know if you find a solution or need further assistance. [Delhi Escort Service][1] [1]: https://www.delhirussianescorts.com/delhi-escorts-service.php
Hi Michel,
piviya2749
piviya2749 posted this 08 November 2024
Minecraft MOD Apk is very famous among gamers because it offers extra features and enhanced gameplay without spending money. The majority of players like the freedom and customization it offers compared to the regular game. The ease of downloading and installation also make it famous in the gamers. It is broadly shared and recommended in the gaming community.
[Minecraft MOD Apk][1] is very famous among gamers because it offers extra features and enhanced gameplay without spending money. The majority of players like the freedom and customization it offers compared to the regular game. The ease of downloading and installation also make it famous in the gamers. It is broadly shared and recommended in the gaming community. [1]: https://minecraftpeapk.net/
jeneka7616
jeneka7616 posted this 08 November 2024
https://gachanebula.app/ is the Android package file for the most famous sandbox game on mobiles. It allows users to download games on their mobiles. Mod versions of Minecraft give extra features, including enhanced features, unlocked items, and custom skin for more fun.
amnaseo6
amnaseo6 posted this 20 November 2024
I’m excited to uncover this page. I need to to thank you for ones time for this particularly fantastic read!! I definitely really liked every part of it and i also have you saved to fav to look at new information in your site. Block Blast Solver
I’m excited to uncover this page. I need to to thank you for ones time for this particularly fantastic read!! I definitely really liked every part of it and i also have you saved to fav to look at new information in your site. [Block Blast Solver][1] [1]: https://blockblastsolver.org/
