"Error" when starting Themler with PHP8
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 28 July 2022
Since updating to Themler v550 and 556 I have the problem that I only get an 'Error' message when I try to start Themler from the Joomla backend.
I then always have to change to PHP 7.4 first and can then edit the template. Then I can switch back to PHP 8.
This happens to me on both Firefox and Chrome.
However, this is very tedious and certainly not wanted.
Thorsten
Since updating to Themler v550 and 556 I have the problem that I only get an 'Error' message when I try to start Themler from the Joomla backend. I then always have to change to PHP 7.4 first and can then edit the template. Then I can switch back to PHP 8. This happens to me on both Firefox and Chrome. However, this is very tedious and certainly not wanted. Sincerely, Thorsten [Werbeagentur Schulz-Design][1] [1]: https://www.schulzdesign.info
24 Comments
I believe it has to do with templateDetails.xml.
For some it works, for some it doesn't.
Have rows changed?
If yes, which?
Thanks and best regards
Thorsten
I believe it has to do with templateDetails.xml. For some it works, for some it doesn't. Have rows changed? If yes, which? Thanks and best regards Thorsten
Werbeagentur Schulz-Design posted this 01 August 2022
No Answer?
I have now found out that all websites hosted with STRATO cannot be opened. As described, only an 'Error' message appears and you can only start Themler if you switch to PHP 7.4 on the server side.
https://www.strato.de/
Hello, No Answer? I have now found out that all websites hosted with STRATO cannot be opened. As described, only an 'Error' message appears and you can only start Themler if you switch to PHP 7.4 on the server side. https://www.strato.de/
Werbeagentur Schulz-Design posted this 08 August 2022
Thank you for the (non-existent) help.
I found the problem: It's the cache.
If the cache is enabled in the backend, the error message appears.
If the cache is disabled you can start Themler-Online.
Kind regards
Thorsten
Hello, Thank you for the (non-existent) help. I found the problem: It's the cache. If the cache is enabled in the backend, the error message appears. If the cache is disabled you can start Themler-Online. Kind regards Thorsten
Werbeagentur Schulz-Design posted this 12 August 2022
Unfortunately the problem still exists!
Why is nobody answering?
PHP 7.4 support ends in November.
My host will then disable the PHP 7.4.
If the problem isn't solved by then, I can no longer edit the templates.
I tried it with different browsers.
I ask you to fix the error.
Thanks.
Unfortunately the problem still exists! Why is nobody answering? PHP 7.4 support ends in November. My host will then disable the PHP 7.4. If the problem isn't solved by then, I can no longer edit the templates. I tried it with different browsers. I ask you to fix the error. Thanks.
New error message: 'Error: Path cannot be empty: Path cannot be empty'
Other websites only showed 'Error'
New error message: 'Error: Path cannot be empty: Path cannot be empty' Other websites only showed 'Error'
emperor
emperor posted this 12 August 2022
So enabling/disabling cache does not solve the problem any more? Does error appears also on websites with other hosting providers (other than Strato)? Are you using Joomla 3 or 4? You may check discussion here: https://forum.joomla.org/viewtopic.php?t=987397 (very similar problem with Nicepage)
Well, I assume that was a rhetorical question ;)
It is a major issue, maybe they will release a new version with fixes before that, but two months ago I sadly resigned on Themler completely - and it was good decision for me.
> Unfortunately the problem still exists! So enabling/disabling cache does not solve the problem any more? Does error appears also on websites with other hosting providers (other than Strato)? Are you using Joomla 3 or 4? You may check discussion here: https://forum.joomla.org/viewtopic.php?t=987397 (very similar problem with Nicepage) > Why is nobody answering? Well, I assume that was a rhetorical question ;) > PHP 7.4 support ends in November. > My host will then disable the PHP 7.4. It is a major issue, maybe they will release a new version with fixes before that, but two months ago I sadly resigned on Themler completely - and it was good decision for me.
Support Team posted this 12 August 2022
Sorry for delay in response. Just to confirm - the issue is present only with Joomla 3 or 4 and PHP 8 and with CMS cache enabled, right? Also with the default theme?
Hello, Sorry for delay in response. Just to confirm - the issue is present only with Joomla 3 or 4 and PHP 8 and with CMS cache enabled, right? Also with the default theme? Sincerely, Nettie
Werbeagentur Schulz-Design posted this 16 August 2022
Hello Nettie,
many thanks for your response.
It took a while because I had to test the points extensively first.
The problem seems to only exist with Joomla 3. With J4 and the beta, I haven't found any problem so far. So far, I only have a test installation.
The problem exists with all hosts and also with the blank theme. If the cache is enabled, an error message appears. Sometimes only 'Error', sometimes 'Error: Path cannot be empty: Path cannot be empty'
If you deactivate the cache, you can load Themler online.
It would be nice if that could be fixed.
Thorsten
Hello Nettie, many thanks for your response. It took a while because I had to test the points extensively first. The problem seems to only exist with Joomla 3. With J4 and the beta, I haven't found any problem so far. So far, I only have a test installation. The problem exists with all hosts and also with the blank theme. If the cache is enabled, an error message appears. Sometimes only 'Error', sometimes 'Error: Path cannot be empty: Path cannot be empty' If you deactivate the cache, you can load Themler online. It would be nice if that could be fixed. Thanks and best regards Thorsten
copywriter
copywriter posted this 16 August 2022
It is this problem solvin with PHP 8 in a WordPress too? I had much questions, but it wasn't answered on anyone.
Werbeagentur Schulz-Design posted this 24 August 2022
the problem is still there. Is there already a solution?
Many greetings
Thorsten
Hello, the problem is still there. Is there already a solution? Many greetings Thorsten
Support Team posted this 25 August 2022
Hello Thorsten,
Sorry for delay. Do I understand it right that the issue with caching happens with Joomla 3 and PHP 8 only? It doesn't happen on the same website with PHP 7.4 even with caching enabled?
Hello Thorsten, Sorry for delay. Do I understand it right that the issue with caching happens with Joomla 3 and PHP 8 only? It doesn't happen on the same website with PHP 7.4 even with caching enabled? Sincerely, Nettie
Werbeagentur Schulz-Design posted this 25 August 2022
It is exactly like that.
Thank for the feedback. I will forward the issue to our developers. Meanwhile I would recommend to work in Themler either with CMS caching disabled or temporarily use PHP 7.x.
Hello, Thank for the feedback. I will forward the issue to our developers. Meanwhile I would recommend to work in Themler either with CMS caching disabled or temporarily use PHP 7.x. Sincerely, Nettie
Werbeagentur Schulz-Design posted this 14 August 2024
the problem still exists.
Unfortunately, PHP 7.4 is no longer usable.
Is there a chance that at least the bugs in the BETA will be fixed?
Best regards
Thorsten
Hello, the problem still exists. Unfortunately, PHP 7.4 is no longer usable. Is there a chance that at least the bugs in the BETA will be fixed? Best regards Thorsten [Werbeagentur Schulz-Design][1] [1]: http://www.schulzdesign.info
Support Team posted this 14 August 2024
Hello Thorsten,
I have answered you in a different topic relating a Joomla theme. The latest Themler version supports PHP 8.x, so this shouldn't be the issue.
Hello Thorsten, I have answered you in a different topic relating a Joomla theme. The latest Themler version supports PHP 8.x, so this shouldn't be the issue. Sincerely, Nettie
ellajohn1623
ellajohn1623 posted this 15 August 2024
I am always astounded by your great knowledge and focus. I am very grateful to you because you are my primary source of motivation. space waves game free
I am always astounded by your great knowledge and focus. I am very grateful to you because you are my primary source of motivation. [space waves][1] game free [1]: https://space-waves.io
Werbeagentur Schulz-Design posted this 15 August 2024
Thanks, I also replied to you in the post.
Problems only occur after migrating from Joomla. There are no problems with a fresh installation of Joomla 5.
By the way: the problems also occur when I migrate a newly installed Joomla 4 website to Joomla 5. So not just when I migrate from Joomla 3 to 4 or 5.
So it definitely has something to do with migration.
Best regards
Thorsten
> The latest Themler version supports PHP 8.x, so this shouldn't be the issue. Thanks, I also replied to you in the post. Problems only occur after migrating from Joomla. There are no problems with a fresh installation of Joomla 5. By the way: the problems also occur when I migrate a newly installed Joomla 4 website to Joomla 5. So not just when I migrate from Joomla 3 to 4 or 5. So it definitely has something to do with migration. Best regards Thorsten [Werbeagentur Schulz-Design][1] [1]: http://www.schulzdesign.info
arjundelhi123456
arjundelhi123456 posted this 18 January 2025
Your immense knowledge and attention to detail never cease to amaze me. Since you are my main source of inspiration, I am really appreciative of you. Sportsfire
Your immense knowledge and attention to detail never cease to amaze me. Since you are my main source of inspiration, I am really appreciative of you. [Sportsfire][1] [1]: https://sportsfire.dev/
watchonlinedramas
watchonlinedramas posted this 18 January 2025
Blink Streamz is the best free live TV streaming app that combines the greatest aspects of sports and entertainment, making it an essential tool for any Android user looking for the best TV viewing experience. https://blinkstreamz.app/
[Blink Streamz][1] is the best free live TV streaming app that combines the greatest aspects of sports and entertainment, making it an essential tool for any Android user looking for the best TV viewing experience. https://blinkstreamz.app/ [1]: https://blinkstreamz.app/
urbanwaycab
urbanwaycab posted this 3 weeks ago
For anyone new to GTA modding, OpenIV is a reliable starting point with detailed documentation and community links. You can access the official source here: https://openiv.org/
. I found many useful tutorials there.
For anyone new to GTA modding, OpenIV is a reliable starting point with detailed documentation and community links. You can access the official source here: https://openiv.org/ . I found many useful tutorials there.
