Favicon does not change at upload
dragana
dragana posted this 28 July 2022
I have a favicon I want to change but when I upload the new one at settings it doesn't change. What folder is the favicon in, so I can upload it manually?
dragana
dragana posted this 16 April 2023
Who doesn't anyone answer this?
lennyburkdoll
Is Solution
lennyburkdoll posted this 4 days ago
The favicon is typically located in the root directory of your website. You can manually replace it by uploading the new favicon.ico file to the root directory of your website using an FTP client or through your website's file manager. Make sure to clear your browser cache to see the updated favicon.
Best regard
lennyburkdoll
Hello, The favicon is typically located in the root directory of your website. You can manually replace it by uploading the new favicon.ico file to the root directory of your website using an FTP client or through your website's file manager. Make sure to clear your browser cache to see the updated favicon. Best regard lennyburkdoll
dragana
dragana posted this 4 days ago
Thank you!
ยจ> Hello,
Best regard
lennyburkdoll
Best regard
lennyburkdoll
Best regard
lennyburkdoll
Thank you! ¨> Hello, > > The favicon is typically located in the root directory of your website. You can manually replace it by uploading the new favicon.ico file to the root directory of your website using an FTP client or through your website's file manager. Make sure to clear your browser cache to see the updated favicon. > > > Best regard > lennyburkdoll > Hello, > > The favicon is typically located in the root directory of your website. You can manually replace it by uploading the new favicon.ico file to the root directory of your website using an FTP client or through your website's file manager. Make sure to clear your browser cache to see the updated favicon. > > > Best regard > lennyburkdoll > Hello, > > The favicon is typically located in the root directory of your website. You can manually replace it by uploading the new favicon.ico file to the root directory of your website using an FTP client or through your website's file manager. Make sure to clear your browser cache to see the updated favicon. > > > Best regard > lennyburkdoll
lennyburkdoll
The favicon is typically located in the root directory of your website. You can manually replace it by uploading the new favicon.ico file to the root directory of your website using an FTP client or through your website's file manager. Make sure to clear your browser cache to see the updated favicon. PFMLogin.com
Best regard
lennyburkdoll
I hope my suggestion is work for you if any query must tell me. i will help you.
> Hello, > > The favicon is typically located in the root directory of your website. You can manually replace it by uploading the new favicon.ico file to the root directory of your website using an FTP client or through your website's file manager. Make sure to clear your browser cache to see the updated favicon. [PFMLogin.com][1] > > > Best regard > lennyburkdoll I hope my suggestion is work for you if any query must tell me. i will help you. [1]: https://www.pfmlogin.net/
