Virtuemart Category erro 500
Fabiano
Fabiano posted this 05 August 2022
Hello! I installed a VirtueMart plugin for a Joomla 4 site, but for some reason the category view doesn't want to appear. "500 - behavior:: modal not found." writes an error. Why can it be?
What I tried.
- The category view appears with the basic template.
- I disabled all other plugins so it's not a hindrance.
- For debugging it says: I attached.
Hello! I installed a VirtueMart plugin for a Joomla 4 site, but for some reason the category view doesn't want to appear. "500 - behavior:: modal not found." writes an error. Why can it be? What I tried. - The category view appears with the basic template. - I disabled all other plugins so it's not a hindrance. - For debugging it says: I attached.
geri108
geri108 posted this 13 August 2022
I asked the same question 1 mounth ago, but i didn't got answer.
Dear Themler. When will arrive the answer??? I will loose my partner and the money...
I asked the same question 1 mounth ago, but i didn't got answer. Dear Themler. When will arrive the answer??? I will loose my partner and the money...
Fabiano
Fabiano posted this 16 August 2022
What did it see? we need an answer. urgent themler
Fabiano
Fabiano posted this 11 October 2022
Hello I need a position on this error that is happening with virtuamart 4 in joomla 4?
Can you help?
Hello I need a position on this error that is happening with virtuamart 4 in joomla 4? Can you help?
Support Team posted this 11 October 2022
We are sorry for delay in response. I have forwarded the issue to our developers for investigation and recommend to use PHP 7.x in the meantime. The issue will be fixed in the next update.
Hello, We are sorry for delay in response. I have forwarded the issue to our developers for investigation and recommend to use PHP 7.x in the meantime. The issue will be fixed in the next update. Sincerely, Nettie
