Joomla 4! and Themler and Multilanguage
nobody
nobody posted this 31 August 2022
Themler Beta for Joomla 4! work, but only if you do not activate multilinguale functions in Joomla4!
Any idea to become now templates converted for Joomla4! because support for Joomla 3.x.x ended ?
Otherwise any idea to rebuild Joomla 3.x.x tempales asap new for Joomla4! and make so avaiable for my clients/customers?
Themler Beta for Joomla 4! work, but only if you **do not activate multilinguale functions** in Joomla4! Any idea to become now templates converted for Joomla4! because support for Joomla 3.x.x ended ? Otherwise any idea to rebuild Joomla 3.x.x tempales asap new for Joomla4! and make so avaiable for my clients/customers?
nobody
If anybody want to have an account for check this, send me a PM.
If support team need a backend account - send me a mail, I'll give you persmission to the working site
If anybody want to have an account for check this, send me a PM. If support team need a backend account - send me a mail, I'll give you persmission to the working site
Support Team posted this 31 August 2022
I see that you described a workaround in another topic. Does the issue persist if you disable language plugins, then update Themler to the latest v.556 and then enable them anew?
Sincerely.,
Hello, I see that you described a workaround in another topic. Does the issue persist if you disable language plugins, then update Themler to the latest v.556 and then enable them anew? Sincerely., Nettie
nobody
Yes, the problem persists even after updating to the latest Themler BETA. There is a 404 error as soon as the language plugins are switched on again when calling Themler Edit from the Joomla backend.
As long as the language plugins are enabled, it is not possible to edit the template or reload an existing one.
If the language plugins (i.e. only 1 language is active) are switched off, you can edit, reload, etc.
After edit and safe, you can switch on the plugins - work (without the possibilitie to edit)
You can see this on following sites
https://slot2.td.co.at
https://slot3.td.co.at
If you need a backend acount write me a Email or PM or change the ticket to private.
Best regards from Tyrol / Austria - Reinhard
Yes, the problem persists even after updating to the latest Themler BETA. There is a 404 error as soon as the language plugins are switched on again when calling Themler Edit from the Joomla backend. As long as the language plugins are enabled, it is not possible to edit the template or reload an existing one. If the language plugins (i.e. only 1 language is active) are switched off, you can edit, reload, etc. After edit and safe, you can switch on the plugins - work (without the possibilitie to edit) You can see this on following sites https://slot2.td.co.at https://slot3.td.co.at If you need a backend acount write me a Email or PM or change the ticket to private. Best regards from Tyrol / Austria - Reinhard
